Old 03-06-2012, 09:21   #1 (permalink)
tanveeranjum's Avatar
Member: 386511
Thanks Meter: 305
nokia 1280 flashing problem help me plz what i do?
here is info
MXKEY Serial: [FT SCR2000 0] - C08133A
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Connection status: UHCI:HUB:HUB:USB 1.10 (Full-speed)
Driver: UFS2XX, ver: 3.8.14.0 , NTMP ver: 2.8.14.0
Module ver: 1.0.0.18624(06-08-2011), Library ver: 1.0.0.12274(06-08-2011)
Do not disconnect or abort this operation otherwise phone will be damaged.
Device synchronized.
CPU: XGOLD 110
Sending EBL Loader ...OK
Sending EBL ...OK
Getting EBL Version ...
Boot mode: 0xCC
EBL version major/minor: 10.19
EBL version : Default_RAM_Bootloader
Set baud rate to: 921.60 Kbps
Flash ID: 00EC 2254 [Samsung K8S6415ETC,64 Mbits]
Processing file: rm647_006.510
Downloading item CODE:hw_b2_rm647_r06.510.fls, num block: 3, size: 4.04 MB
Erasing area 0x00800000-0x00A0FFFE ...OK
Programming ...
flashing terminated !
Old 03-06-2012, 09:25   #2 (permalink)
.::ZUBER::.'s Avatar
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
bro. post full logs of buscheck then only it can be solve.
Old 03-06-2012, 09:28   #3 (permalink)
Member: 386511
Thanks Meter: 305
MXKEY Serial: [FT SCR2000 0] - C081133A
CPU: XGOLD 110
Sending EBL ...OK
Boot mode: 0xCC
phone not responding please rest the phone manually then click ok to continue!!!!!!!!!!!!1
Old 03-06-2012, 09:47   #4 (permalink)
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
CPU: XGOLD 110
Sending EBL ...OK
Boot mode: 0xCC
bro. download & update mxkey software to v3.5 rev1.8, your problem will be solve, you are using old version & better to have HTI box, work with more power. post after update & have a good day.
Old 03-06-2012, 10:06   #5 (permalink)
easir.comilla_e's Avatar
Member: 1488757
Thanks Meter: 98
here is info
CPU: XGOLD 110
Sending EBL ...OK
Boot mode: 0xCC
Programming ...
Bro Here Your Nokia 1280 RM_647 Flash File
1280 RM_647_4.20 Urdu+Euro By ******host.zip
Old 03-06-2012, 10:29   #6 (permalink)
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
bro. did he ask for urdu+euro file, by the way phone is xgold & you are giving downgraded file 4.20, his version is 6.51 which is latest. he is already asking for help & you are putting him more trouble. so dont misguide.
Old 03-06-2012, 10:33   #7 (permalink)
Member: 1488757
Thanks Meter: 98
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 4], SN: C086CBB7
Using device: USB ROM and HTI, FW ver: 00.50, SN: 000144E9
Connection status: UHCI:HUB:HUB::USB 2.00 (Full-speed)
Driver: NMWCD, ver: 7.1.32.70
Module ver: 1.0.0.19798(05-01-2012), Library ver: 1.0.0.13703(05-01-2012)
Processing MCU file: rm303__10.10.mcusw
[BB5,BB5 ALGORITHM] size: 17.07 MB
Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable, Battery back to device(make sure to have fully charged battery).
Insert Charger or Press phone's power button(if flashing doesnt start automatically)
Waiting for USB ROM device ...
Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 2673BC70
CMT SYSTEM ASIC ID: 000000010000022600010006010C192101013000
CMT EM0 ID: 00000296
CMT EM1 ID: 00000B22
CMT PUBLIC ID: 20C0010AA5807D56FB7BF0160EE96B8E4C1C34EC
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
CMT ROM ID: 273F6D55DFAAF68F
Flashing CMT Update Server Data, ULO: 0x3900 bytes
Update Server code succesfully sent to phone.
Flashing CMT Update Server Data, UPDAPP: 0x48480 bytes
Flashing CMT Update Server Data, PASUBTOC: 0x56F40 bytes
Waiting for USB device removal ...
Device connected: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, PORT_ID: 19D09CA
Verifying communication to device OK.
Erase size: 18 MB
CMT FLASH,NOR area [00000000-000006BF] erased in 0.953 s
CMT FLASH,NOR area [000006C0-0001FFFF] erased in 0.031 s
CMT FLASH,NOR area [00040000-000BFFFF] erased in 3.828 s
CMT FLASH,NOR area [000C0000-0013FFFF] erased in 0.094 s
CMT FLASH,NOR area [00140000-010DFFFF] erased in 1 min 40.875 s
CMT FLASH,NOR area [010E0000-0121FFFF] erased in 8.328 s
Flash programming ...
CMT NOLO block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT PASUBTOC block sent
Selecting first CMT PAPUB block with matching RootKey.
CMT PAPUBKEYS: 3E96DE42 [RAP Certificate 90 v1] sent
CMT UPDAPP block sent
CMT DSP0 block sent
CMT MCUSW block sent
Programming completed in 1 min 59.719 s
Processing PPM file: rm303__10.10.ppm_i
[BB5,BB5 ALGORITHM] size: 6.05 MB
Erase size: 6.50 MB
CMT FLASH,NOR area [01220000-0189FFFF] erased in 36.922 s
Programming completed in 45.750 s
Processing CNT file: rm303__10.10.image_i_red
[BB5,BB5 ALGORITHM] page size: 128 K size: 8.64 MB
Erase size: 39.12 MB
CMT FLASH,NOR area [018A0000-01B1FFFF] erased in 33.093 s
CMT FLASH,NOR area [01B20000-03FBFFFF] erased in 6 min 32.234 s
Programming completed in 1 min 7.531 s
Total time for flashing process(boot+erase+write) was 14 min 14.047 s
Waiting for USB device removal ...OK
Waiting for USB device arrival ...
Waiting for device boot up ...
Device connected: nmwcdc\Nokia 5310 XpressMusic USB Phonet, PORT_ID: 534623A
Phone type: RM-303 (Nokia 5310 XpressMusic)
SW version: V 10.10 23-03-09 RM-303 (c) Nokia
Imei plain: 35421803362979-1
Product code: 0564389
Battery voltage: 3737 mV, current: 246 mA
Language Pack:
- not available.
SLPA ver[2]: PA_SL2 (15 digit NCK)
Camera config: NIMMIIIIRRFF0A021001, ver: 002.006
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 354218033629791
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
Old 03-06-2012, 10:38   #8 (permalink)
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
bro. whats your problem, are you posting the result or having problem in phone. please give details.
Old 03-06-2012, 11:07   #9 (permalink)
specta's Avatar
Member: 1149800
Thanks Meter: 211
xgold110 can be downgraded with out any risk. done it couples times.
@tanveeranjum
what version r u using now? do u do crossed module? so far i know, mxkey not support hwk any longer for dct4 n bb5. better try to flash it using hwk itself than use hwk as interface of mxkey.
good luck bro
br
Old 03-06-2012, 11:28   #10 (permalink)
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
bro. i accept that it can be done but he didnt ask for downgrading & i also mention him to use HTI instead of hwk interface with mxkey dongle. by the way thanks....
Old 03-06-2012, 12:05   #11 (permalink)
Member: 386511
Thanks Meter: 305
i have mxkey not mxbox any body tell me profect v
Old 03-06-2012, 12:27   #12 (permalink)
specta's Avatar
Member: 1149800
Thanks Meter: 211
hwk can flash 1280 too. have u tried yet?
br
Old 03-06-2012, 12:31   #13 (permalink)
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
br
bro. may be he is using old usf or twister box not hwk as a interface.
Old 03-06-2012, 16:23   #14 (permalink)
Member: 386511
Thanks Meter: 305
i have hwk box i m trying but its not work now i rehot cpu and try
Old 01-04-2013, 12:11   #15 (permalink)
Member: 1493694
Sonork: 100.1623862
Thanks Meter: 11
nokia 1280 flashing
EBL version: Default_RAM_Bootloader
Set baud rate to: 921.60 Kbit/s
Flash ID: 00EC 2254 - 23280002 [Samsung K8S6415ETC,64 Mbits]
CFI information:
Flash settings: 0/1, size: 0x00800000
2 Block regions:
127 x 0x00010000 = 0x007F0000
8 x 0x00002000 = 0x00010000
EBL ready !
Processing file: rm647_005.800
Downloading item CODE:hw_b2_rm647_r05.800.fls, num block: 3, size: 3.99 MB
Erasing area 0x00800000-0x00A0FFFE ...flashing terminated !
Page generated in 0.28587 seconds with 10 queries
