Old 09-14-2011, 12:07   #1 (permalink)
Member: 334225
Thanks Meter: 66
Nokia 1280 ok but nothing show on display
NOKIA 1280 OK BUT NOTHING SHOW ON DISPLAY
FACTORY DEFAULT OK SELF TEST GIVING OK PLZ CHECK ND TELL ME
MXKEY Serial: [FT SCR2000 0] - C0817873
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Connection status: UHCI:HUB:HUB:USB 1.10 (Full-speed)
Driver: UFS2XX, ver: 1.5.4.0 , NTMP ver: 1.5.4.1
Module ver: 1.0.0.18624(06-08-2011), Library ver: 1.0.0.12274(06-08-2011)
Device synchronized.
CPU: XGOLD 110
Sending EBL Loader ...OK
Sending EBL ...OK
Getting EBL Version ...
Boot mode: 0xCC
EBL version major/minor: 10.19
EBL version : Default_RAM_Bootloader
Set baud rate to: 921.60 Kbps
Flash ID: 0020 88C0 [ST M58MWR064FU,64 Mbits]
Phone type: RM-647
SW version: V 05.80 06-08-10 RM-647 (c) Nokia
Imei plain: 35592604294459-2
Product code: 0592303
Cellular system: GSM
ASIC ID: 0x2292, type: 11
Ppm Id: IA
Language Pack:
English,Arabic,Farsi,French,Urdu
Imei net: 35592604294459
Provider: GSM Test Operator
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 0000000000030002
BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
Old 09-15-2011, 04:06   #2 (permalink)
Member: 272979
Sonork: 100.1607215
Thanks Meter: 135
try to change display it may be display problem
Old 09-16-2011, 18:27   #3 (permalink)
Member: 334225
Thanks Meter: 66
what is display lcd or ic x gold mobiles has alot matter must like this
Old 09-16-2011, 18:47   #4 (permalink)
atif ikram's Avatar
Member: 1644460
Thanks Meter: 44
CPU: XGOLD 110
Sending EBL ...OK
Boot mode: 0xCC
Phone type: RM-647
Ppm Id: IA
Language Pack:
Counter: 0/3, 0/10
brother take self test of your phone if lcd fail then 100% problem is LCD change it or resold it
The Following 2 Users Say Thank You to atif ikram For This Useful Post:
Old 09-17-2011, 05:29   #5 (permalink)
amn32's Avatar
Member: 569925
Sonork: 100.1624057
Thanks Meter: 6,313
Check lcd or lcd connecting points.
The Following User Says Thank You to amn32 For This Useful Post:
Page generated in 0.17803 seconds with 9 queries
