Old 08-22-2010, 16:09   #1 (permalink)
drjaved_akhter's Avatar
Member: 585807
Thanks Meter: 781
6303 aafter flash dead help
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010)
Processing file: rm443__10.10.mcusw as MCU
[BB5,BB5 ALGORITHM] size: 24.67 MB
Supported RAP Ids: 010C192101013000, 0103192101003000, 030C192101033000
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
EM0 ID: 00000295
EM1 ID: 00000B22
PUBLIC ID: 18800115237C7D562DCF6A7A5F518C5C78FBA0EA
ASIC MODE ID: 00
ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
ROM ID: 273F6D55DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP
ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
TransmissionMode: 16Bit
Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS is blank/erased.
TransmissionMode: DDR&TX2
Storing certificate [NPC, R&D, CCC, HWC] ...OK
Erase size: 28.25 MB
CMT NOR area [00000000-0001FFFF] erased in 0.250 s
CMT NOR area [00040000-0005FFFF] erased in 0.172 s
CMT NOR area [00060000-0007FFFF] erased in 0.172 s
CMT NOR area [00080000-0015FFFF] erased in 0.297 s
CMT NOR area [00160000-0023FFFF] erased in 0.313 s
CMT NOR area [01740000-0191FFFF] erased in 0.578 s
CMT NOR area [00240000-0173FFFF] erased in 4.969 s
CMT NOR area [022E0000-0261FFFF] erased in 0.890 s
Flash programming ...
Error chk C7012D0103CD000010000000F1
RX2 not responding, please check BSI/cable/pinout !
Error while programming [00] at 0x00080000, Result: 0010
Flashing terminated with error(s) in 38.094 s
RX Buffer: C7012D0103CD000010000000F172
please help me set goes to local mode and test mode but now dead
Old 08-22-2010, 16:19   #2 (permalink)
Member: 1070908
Sonork: bogha
Thanks Meter: 29
just clean it good then try to reflash it using mx key using jaf box
Old 08-22-2010, 16:20   #3 (permalink)
Member: 998867
Sonork: chuchu
Thanks Meter: 24
try use usb to flash the phone................
Old 08-22-2010, 16:43   #4 (permalink)
Member: 585807
Thanks Meter: 781
sir i try to usb but hand set not connect .not response usb
Old 08-22-2010, 16:48   #5 (permalink)
Member: 585807
Thanks Meter: 781
Using device: POTATO BOX, FW ver: 01.B4
Unknown ID !
Error getting boot info !
Bootstrap failed!
Flashing terminated with error(s) in 52.000 s
RX Buffer:
Interface: POTATO BOX
» BOX FW Version: 01.B4
» BOX Authentication ...OK.
POTATO FLASHER INTERFACE ready.
RAP Data :
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
erased in 6.609 s
Error while programming [00] at 0x00000400, Result: 0000
Please try to use newer flashloader.
Flashing terminated with error(s) in 45.672 s
with jaf logs
Old 08-22-2010, 16:55   #6 (permalink)
Member: 1299960
Thanks Meter: 36
try ticking the FAST Flash options and post result
Old 08-22-2010, 16:59   #7 (permalink)
Member: 998867
Sonork: chuchu
Thanks Meter: 24
you install all ready usb driver???
Old 08-22-2010, 17:02   #8 (permalink)
Member: 1028136
Thanks Meter: 18
instal driver mx-key bro,,---C:\mobileEx\3.4\data\drivers\nokia
This may be your problem
br.
Old 08-22-2010, 17:06   #9 (permalink)
Member: 585807
Thanks Meter: 781
br.
sir,
handset not response usb.
when i connect usb cable with pc must found new hardware but not found
so handset usb not connect
Old 08-22-2010, 17:08   #10 (permalink)
Member: 585807
Thanks Meter: 781
Using device: POTATO BOX, FW ver: 01.B2
Unknown ID !
Bootstrap failed!
Flashing terminated with error(s) in 52.047 s
RX Buffer:
Old 08-22-2010, 17:08   #11 (permalink)
Member: 32168
Thanks Meter: 183
use Phoenix to flash the phone like dead usb...after u click refurbish put cable Without Battery and after that insert battery and pres shortly power....
regards
Old 08-22-2010, 17:14   #12 (permalink)
Member: 385828
Sonork: 100.1612815
Thanks Meter: 73
Flash with mt box with Tx2 line enabled (use ufc combo or mt box 10 pin cable)
Old 08-22-2010, 17:16   #13 (permalink)
Member: 1028136
Thanks Meter: 18
try reading this brother http://forum.gsmhosting.com/vbb/f550...58/index2.html
The Following User Says Thank You to e r i k For This Useful Post:
Old 08-22-2010, 17:29   #14 (permalink)
Member: 1374054
Thanks Meter: 14
RAP Data :
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
dear bro i can give u only idea
your rx2 conection is missing or broken thats why cant program..
so you colect user manual and try to reconect rx2 pin...
good luck bro...
The Following User Says Thank You to bigboyb For This Useful Post:
Old 08-22-2010, 18:14   #15 (permalink)
Member: 392149
Thanks Meter: 199
Bro ur jaf box is dead now use another interface or dont use jaf again on MX key bro try to another Fc on usb cable i hope it ll be ok
The Following User Says Thank You to shh_903 For This Useful Post:
Eeprom dump lost, help needed. CAMILO Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 11-29-2010 19:04
Page generated in 0.26707 seconds with 9 queries
