08-09-2010, 15:29 | #1 (permalink) |
No Life Poster Join Date: May 2005 Location: GULMI Age: 49
Member: 143007 Status: Offline Thanks Meter: 141 | nokia 1616 ......... Device synchronized. CPU ID: A200341100 [X-GOLD 110] Sending Primary Boot Loader ...OK Sending Secondary Boot Loader ...OK Boot mode: CC EBL version: 10.19, Default_RAM_Bootloader Flash ID: 00EC 2254 [Samsung K8S6415ETC,64 Mbits] Version: V 03.61 29-01-10 RH-125 (c) Nokia Imei plain: 35197704913441-8 Product Code: 0590489 Cellular System: GSM ASIC ID: 0x2292, type: 11 Ppm Id: IC Language Pack: - not available. Imei net: 35197704913455 Version: Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000030002 nokia 1616 not flashing pls chk......... Last edited by gsm st; 08-09-2010 at 15:37. |
The Following User Says Thank You to gsm st For This Useful Post: |
08-10-2010, 07:50 | #2 (permalink) |
Freak Poster Join Date: Jan 2007 Location: karor lal-esan pakistan
Member: 427028 Status: Offline Sonork: 100.1639042 Thanks Meter: 63 | Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010) Do not disconnect or abort this operation otherwise phone will be damaged. Device synchronized. CPU ID: A200341100 [X-GOLD 110] Sending Primary Boot Loader ...OK Sending Secondary Boot Loader ...OK Boot mode: CC EBL version: 10.19, Default_RAM_Bootloader Flash ID: 0020 88C0 [ST M58MWR064FU,64 Mbits] Processing CODE:hw_f11_rh125_r03.610.fls from file rh125_003.610 Erasing area 0x00800000-0x00A0FFFE ...OK Programming ... Programming completed in 31.778 s Erasing area 0x00C60000-0x00EAFFFE ...OK Programming ... Programming completed in 30.463 s Erasing area 0x00FFC000-0x00FFFFFE ...OK Programming ... Programming completed in 0.022 s Checksum failed Processing CUST:hw_f11_rh125_003.61ej.fls from file rh125_003.61ej Erasing area 0x00210000-0x0045FFFE ...OK Programming ... Programming completed in 28.831 s Checksum failed Processing CUST:hw_f11_rh1250_nai03.61ej.fls from file rh1250_nai03.61ej Erasing area 0x00EB0000-0x00F7FFFE ...OK Programming ... Programming completed in 4.472 s Checksum failed Flashing completed in 3 min 29.753 s After Flash Processing ... Reseting Factory Values OK. Phone Type: RH-125 SW Version: V 03.61 29-01-10 RH-125 (c) Nokia Imei plain: 35197704741776-5 Product Code: 0588620 Cellular System: GSM ASIC ID: 0x2292, type: 11 Ppm Id: EJ Language Pack: - not available. Imei net: 35197704741776 Version: Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000030002 BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN Total time to process is 3 min 39.959 s but set is stelll is dad if aney one have this slation then plz help us |
