Old 10-06-2010, 08:55   #1 (permalink)
saker2050's Avatar
Member: 1296389
Sonork: 100.1618052
Thanks Meter: 265
Nokia 1616 falsh ok but no power (Answered)
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.8955(29-09-2010), 1.0.0.14639(29-09-2010)
Do not disconnect or abort this operation otherwise phone will be damaged.
Device synchronized.
CPU ID: A200341100 [X-GOLD 110]
Sending Primary Boot Loader ...OK
Changing baudrate to: 921600
Sending Secondary Boot Loader ...OK
Boot mode: CC
EBL version: 10.19, Default_RAM_Bootloader
Flash ID: 00EC 2254 [Samsung K8S6415ETC,64 Mbits]
Processing CODE:hw_f11_rh125_r03.610.fls from file rh125_003.610
Erasing area 0x00800000-0x00A0FFFE ...OK
Programming ...
Programming completed in 39.500 s
Erasing area 0x00C60000-0x00EAFFFE ...OK
Programming ...
Programming completed in 31.125 s
Erasing area 0x00FFC000-0x00FFFFFE ...OK
Programming ...
Programming completed in 0.031 s
Checksum OK (0xE49B)
Processing CUST:hw_f11_rh125_003.61ej.fls from file rh125_003.61ej
Erasing area 0x00210000-0x0045FFFE ...OK
Programming ...
Programming completed in 31.391 s
Checksum OK (0xCF63)
Processing CUST:hw_f11_rh1250_nai03.61ej.fls from file rh1250_nai03.61ej
Erasing area 0x00EB0000-0x00F7FFFE ...OK
Programming ...
Programming completed in 4.906 s
Checksum OK (0xE74B)
Flashing completed in 2 min 43.750 s
After Flash Processing ...
Reseting Factory Values OK.
Phone Type: RH-125
SW Version: V 03.61 29-01-10 RH-125 (c) Nokia
Imei plain: 35823403451034-0
Product Code: 0587509
Cellular System: GSM
ASIC ID: 0x2292, type: 11
Ppm Id: EJ
Language Pack:
- not available.
"C:\Program Files\Nokia\Phoenix\Products\RH-125" folder created.
Imei net: 35823403451034
Version:
Provider: ALL Operator, Country: -
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 0000000000030002
BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
Total time to process is 2 min 52.625 s
The Following User Says Thank You to saker2050 For This Useful Post:
Old 10-06-2010, 08:58   #2 (permalink)
GSMJordan's Avatar
Member: 92813
Sonork: 100.1619156
Thanks Meter: 129
its lcd problem 100% tested
Old 10-06-2010, 09:02   #3 (permalink)
THE GREAT ONE's Avatar
Member: 751235
Sonork: 100.1662008
Thanks Meter: 521
change the sreen problem will be sloved
Old 10-11-2010, 09:40   #4 (permalink)
Registered User
Member: 600337
Sonork: 100.1593943
Thanks Meter: 31
i change lcd but same problem any idea
Old 10-11-2010, 19:10   #5 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,059
can you power up on normal mode with box? if you could, please check pwr on/off switch line.
The Following User Says Thank You to gbluez For This Useful Post:
Old 10-12-2010, 04:21   #6 (permalink)
..::One-Man::..'s Avatar
Member: 1174508
Sonork: 100.1593820
Thanks Meter: 11,565
brother check charging post result .
Old 10-12-2010, 04:39   #7 (permalink)
Temporary banned !!
Member: 839503
Sonork: 100.1578866
Thanks Meter: 108
With box normal mode done only first time, power sw ok it's working.
Old 10-12-2010, 09:45   #8 (permalink)
Member: 334225
Thanks Meter: 65
this is big matter coming from x gold mobiles i have flashed many mobiles after flash done lcd goes faild i have checked many x gold mobiles but same problem lcd failed after flash why?????????
Old 10-17-2010, 13:42   #9 (permalink)
Member: 772386
Thanks Meter: 147
bro check the light track, i tested many sets 5030,1661 etc i flash the phone but no power on, then i check light track and repair light track then set ok tested many sets,
try and post result
Old 10-17-2010, 13:53   #10 (permalink)
WAJID PNR's Avatar
Member: 625961
Sonork: 100.1590447
Thanks Meter: 1,259
try and post result
if light track is nt ok ,then how that fone done in normal mode?///?/wen normal mode comes that time lcd & lights are ok
many xgold infineon processor phone's had this problem,
i ddnt solved yet,
kindly share if anyone solved,
Old 10-17-2010, 14:31   #11 (permalink)
Member: 773516
Sonork: 100.1583311
Thanks Meter: 61
i ddnt solved yet,
the phone is so simple to do i think out of 10 i will reture one to costomer back dat he cannot be repair.sometime u can not flash d phone it will not connect most of d problem is screen or d line of d screen is cut.like d one u flash and is ok when u flash then cheek d line of d screen and sometime they select screen dat will work d them.
Old 10-17-2010, 17:21   #12 (permalink)
Baba Khanikar's Avatar
Member: 1126485
Sonork: 100.1605067
Thanks Meter: 32
Yes Same 2 me.....flashed many phone 1616,1800...but not suceed..
Flashing ok but no power on why...
Old 01-02-2011, 04:53   #13 (permalink)
Registered User
Member: 473907
Thanks Meter: 63
i hv aslo problem i flashed set ok but not power on with batter i jumpered r2205,removed lcd etc......same problem is coming
Old 01-02-2011, 04:56   #14 (permalink)
Member: 1016351
Thanks Meter: 51
bro chang the LCD 100% ok
Old 01-02-2011, 05:16   #15 (permalink)
alpona_su's Avatar
Member: 1217358
Sonork: 100.1605541
Thanks Meter: 145
bro not best MXKEY flash XGOLD.1616,1800,
try ATF box
ENJOY.................
New Nokia Software!!!!!!! Jefferson Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 52 12-30-2016 07:17
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 30 02-24-2016 09:21
Page generated in 0.40601 seconds with 8 queries
