Nokia 1616 Not enter Local Mode Phone was dead, flashing done complete with checksum mismatch error( with same product code )but phone not on. log is : MXKEY [FT SCR2000 0], SN: C08 Using device: HTI, FW ver: 00.50, SN: 00000 Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.21200(18-07-2012), Library ver: 1.0.0.14205(18-07-2012) Device synchronized. CPU: XGOLD 110 Using embedded SBL from MCU. Sending EBL Loader ...OK Sending EBL ...OK Getting EBL Version ... Boot mode: 0xCC EBL version major/minor: 10.19 EBL version: Default_RAM_Bootloader Set baud rate to: 921.60 Kbit/s Flash ID: 00EC 2254 - 23280002 [Samsung K8S6415ETC,64 Mbits] CFI information: Flash settings: 0/1, size: 0x00800000 2 Block regions: 127 x 0x00010000 = 0x007F0000 8 x 0x00002000 = 0x00010000 EBL ready ! Processing file: rh125_006.520 Downloading item CODE:hw_f11_rh125_r06.520.fls, num block: 3, size: 4.14 MB Erasing area 0x00800000-0x00A0FFFE ...OK Programming completed in 49.750 s Erasing area 0x00C60000-0x00E72D7E ...OK Programming completed in 48.922 s Erasing area 0x00FFC000-0x00FFC03E ...OK Programming completed in 0.188 s Checksum mismatch: Phone calculated 0x9BF3, software calculated 0x7819 Processing file: rh125_006.52mg Downloading item CUST:hw_f11_rh125_006.52mg.fls, num block: 1, size: 1.90 MB Erasing area 0x00210000-0x003F6C3E ...OK Programming completed in 45.750 s Checksum mismatch: Phone calculated 0x5803, software calculated 0x576B Processing file: rh1250_nai06.52mg_nlt Downloading item CUST:hw_f11_rh1250_nai06.52mg_nlt.fls , num block: 1, size: 790.52 KB Erasing area 0x00EB0000-0x00F74CFE ...OK Programming completed in 18.234 s Checksum mismatch: Phone calculated 0x75F4, software calculated 0x7E05 Total time for flashing process(boot+erase+write) was 3 min 35.3 28 s Me changed lcd, reflow cpu & flash ic Plz suggest any solution. |
you deed to change display or lcd line is damaged but before do self test is software |
chack info show lcd unkwon chack info show lcd unkwon |
BR. Arsalan gsm2000. |
Means Phone Dead & no way to repair with changing LCD when error is: Quote:
Select Latest Firmware of Phone Product with Drop Down Menu, Untick Safe Flash & Click Flash will update your Phone without error. BR, ZUBER |
Br Zuber, unticked safe flash but same problem. Logs is : Using device: HTI, FW ver: 00.50, SN: 00000D7B Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.21200(18-07-2012), Library ver: 1.0.0.14205(18-07-2012) Device synchronized. CPU: XGOLD 110 Using embedded SBL from MCU. Sending EBL Loader ...OK Sending EBL ...OK Getting EBL Version ... Boot mode: 0xCC EBL version major/minor: 10.19 EBL version: Default_RAM_Bootloader Set baud rate to: 921.60 Kbit/s Flash ID: 00EC 2254 - 23280002 [Samsung K8S6415ETC,64 Mbits] CFI information: Flash settings: 0/1, size: 0x00800000 2 Block regions: 127 x 0x00010000 = 0x007F0000 8 x 0x00002000 = 0x00010000 EBL ready ! Processing file: rh125_006.520 Downloading item CODE:hw_f11_rh125_r06.520.fls, num block: 3, size: 4.14 MB Erasing area 0x00800000-0x00A0FFFE ...OK Programming completed in 43.657 s Erasing area 0x00C60000-0x00E72D7E ...OK Programming completed in 47.469 s Erasing area 0x00FFC000-0x00FFC03E ...OK Programming completed in 0.188 s Checksum mismatch: Phone calculated 0xB844, software calculated 0x7819 Processing file: rh125_006.52mg Downloading item CUST:hw_f11_rh125_006.52mg.fls, num block: 1, size: 1.90 MB Erasing area 0x00210000-0x003F6C3E ...OK Programming completed in 44.781 s Checksum mismatch: Phone calculated 0xBC77, software calculated 0x576B Processing file: rh1250_nai06.52mg_nlt Downloading item CUST:hw_f11_rh1250_nai06.52mg_nlt.fls , num block: 1, size: 790.52 KB Erasing area 0x00EB0000-0x00F74CFE ...OK Programming completed in 19.219 s Checksum mismatch: Phone calculated 0x1075, software calculated 0x7E05 Total time for flashing process(boot+erase+write) was 3 min 27.735 s Now please suggest how to proceed further |
