Old 12-09-2011, 14:58   #1 (permalink)
Member: 1323194
Thanks Meter: 61
Nokia 1661-2b Rh 121 unlock problem
Nokia 1661-2b Rh 121, T mobile USA need to unlock
I unlocked with HTI, but tower not coming. I think need to change imei,
Here is the log
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 4], SN: C-----
Using device: HTI, FW ver: 00.24, SN: 00000947
Connection status: EHCI:HUB:HUB:USB 2.00 (Full-speed)
Driver: WinUSB, ver: 3.5.0.0
Module ver: 1.0.0.19228(10-11-2011), Library ver: 1.0.0.13150(10-11-2011)
ASIC ID: 0x2293 [UPPCosto ver: 2.0]
SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8
Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168
FlashID0: 0020 88C0 [ST M58MWR064FU,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF
FlashID1: 0000 0001 [unused/removed]
ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514
Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30
Performing Flash Authentication ...OK
UEM ID: 00714202A3BDA66
ASIC type: 11
UEM Imei: 01188500033458
Flash Imei: 01188500033458
MasterCode: 6503301750
RPL saved to "C:\mobileEx\3.5\data\backup\01188500033458_BACK.r pl"
Phone type: RH-121
SW version: V 03.00 02-09-09 RH-121 (c) Nokia
Imei plain: 01188500033458-2
Product code: 0576976
Cellular system: GSM
ASIC ID: 0x2293, type: 11
Ppm Id: UB
Language Pack:
- not available.
Master code: 4006663447
Imei net: 01188500033458
Version: SIMLOCK SERVER
Provider: GSM Test Operator
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 000000000003000B
BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
Old 12-09-2011, 15:16   #2 (permalink)
Member: 1071783
Thanks Meter: 11
nice post brotherrrrrr
Old 12-09-2011, 15:23   #3 (permalink)
Member: 1323194
Thanks Meter: 61
Nice post ah, sir i need to clear the problem
Old 12-09-2011, 15:44   #4 (permalink)
Sucre79's Avatar
Member: 1413902
Sonork: 100.1611698
Thanks Meter: 143
try this
http://forum.gsmhosting.com/vbb/f550...121-a-1264992/
Old 12-09-2011, 16:07   #5 (permalink)
Registered User
Member: 457521
Thanks Meter: 28
It's already unlock
no need to change imei
just write good pm
Old 12-09-2011, 16:11   #6 (permalink)
Member: 1323194
Thanks Meter: 61
Originally Posted by skytronic View Post
It's already unlock
just write good pm
Dont want to change filters ah ?
Old 12-09-2011, 16:33   #7 (permalink)
Registered User
Member: 457521
Thanks Meter: 28
Sorry i forgot change filter also like THIS
Old 12-09-2011, 16:38   #8 (permalink)
Member: 1323194
Thanks Meter: 61
Changed PM,
I want to change filter or can do jumber ?
Page generated in 0.22925 seconds with 9 queries
