Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Jul 2007 Location: FENI,BANGLADESH Age: 27
Member: 537829 Status: Offline Thanks: 155
| nokia 1800 flash ok but not on. here is flashing log:- Backup saved to "C:\mobileEx\3.5\data\backup\XGOLD_RM-653_84CD07361CEE974D_IMEI.back" MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN: C085F7C0 Using device: HTI, FW ver: 00.50, SN: 0000C540 Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.20769(01-04-2012), Library ver: 1.0.0.14022(01-04-2012) Device synchronized. CPU: XGOLD 110 Using embedded SBL from MCU. Sending EBL Loader ...OK Sending EBL ...OK Getting EBL Version ... Boot mode: 0xCC EBL version major/minor: 10.19 EBL version: Default_RAM_Bootloader Set baud rate to: 921.60 Kbit/s Flash ID: 0020 88C0 - 23280003 [ST M58MWR064FU,64 Mbits] CFI information: Flash settings: 0/1, size: 0x00800000 2 Block regions: 127 x 0x00010000 = 0x007F0000 8 x 0x00002000 = 0x00010000 EBL ready ! Processing file: rm653_005.800 Downloading item CODE:hw_b2_rm653_r05.800.fls, num block: 3, size: 4.10 MB Erasing area 0x00800000-0x00A0FFFE ...OK Programming completed in 43.687 s Erasing area 0x00C60000-0x00E68CBE ...OK Programming completed in 43.640 s Erasing area 0x00FFC000-0x00FFC03E ...OK Programming completed in 0.156 s Error reading checksum! Processing file: rm653_005.80ed Downloading item CUST:hw_b2_rm653_005.80ed.fls, num block: 1, size: 2.18 MB Erasing area 0x00210000-0x0043E23E ...OK Programming completed in 39.110 s Checksum mismatch: Phone calculated 0x0044, software calculated 0x66F3 Processing file: rm6530_nai05.80ed Downloading item CUST:hw_b2_rm6530_nai05.80ed.fls, num block: 1, size: 330.77 KB Erasing area 0x00EB0000-0x00F01DFE ...OK Programming completed in 6.438 s Checksum mismatch: Phone calculated 0x00F1, software calculated 0x5348 Total time for flashing process(boot+erase+write) was 3 min 50.500 s Phone type: RM-653 SW version: V 05.80 06-08-10 RM-653 (c) Nokia Imei plain: 35626504221174-7 Product code: 0594931 Cellular system: GSM ASIC ID: 0x2292, type: 11 Ppm Id: ED Language Pack: English,Croatian,German,Slovenian,Albanian,Macedon ian Imei net: 35626504221174 Provider: GSM Test Operator Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000030002 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN FULL FACTORY... OK USER DATA... OK LEAVE FACTORY... OK SERVICE CENTER... OK SOFTWARE UPGRADE... OK PRODUCTION TUNING... OK Reset User Code (to default:12345) ... OK Completed in 2.203 s |
| | #2 (permalink) |
| Product Supporter ![]() ![]() ![]() Join Date: Apr 2006 Location: MXBox (Orange-Green) Helpdesk Age: 39
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks: 516
| Brother, run self test to resolve issue if appears Local or Test Mode. BR, |
| | #3 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Jun 2009 Location: mx-key is the best nokia tool.
Member: 1051835 Status: Offline Sonork: 100.1594332 Thanks: 193
| 100000000000% LCD problem. |
| The Following User Says Thank You to ~The JoKeR~ For This Useful Post: |
| | #10 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Apr 2012 Location: forum.gsmhosting.com
Member: 1745022 Status: Offline Sonork: Save The Market Thanks: 32
| better u check for selftest. if lcd test passes then rehot Xgold IC if lcd test fail, means u need to change lcd. Good luck |
| | #15 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2009 Location: philippines now here in U.A.E Age: 27
Member: 1070665 Status: Offline Sonork: 100.1636802 Thanks: 1,059
| brother befor you recieve what will happened,is okay or dead ifis nokia only before you recieve that is 50% hardware or software try flash with latest version if same that is hardware problem...................lcd or lcd resestor good luck..... lilong lee |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| New Nokia Software!!!!!!! | Jefferson | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 73 | 05-15-2013 13:07 |
| Need software upgrade for Nokia 5110 | ptkrf | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 26 | 09-25-2012 02:41 |
