Member: 118601
Thanks Meter: 200 | Thanks your very much sir this one is ok now wait you to save me with the other one ( Asha 302).
here is log file after flashing Quote:
MXKEY [MxKey Team HTI PLUS Flasher Interface 4], SN: C085E944
Using device: USB Phonet and HTI, FW ver: 00.50, SN: 010030B4
Connection status: OHCI:HUB:USB 2.00 (Full-speed)
Driver: nmwcdc, ver: 7.1.32.84
Module ver: 1.0.0.21719(09-05-2013), Library ver: 1.0.0.14397(09-05-2013)
Battery voltage: 3994 mV
Waiting for USB device removal ...OK
Waiting for USB device arrival ...
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable, Battery back to device(make sure to have fully charged battery).
Insert Charger or Press phone's power button(if flashing doesnt start automatically)
Waiting for USB ROM device ...
Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 31006857
Device synchronized.
CPU: XGOLD 213
Using embedded SBL from MCU.
Sending EBL Loader...OK
Sending EBL ...OK
Getting EBL Version ...
Boot mode: 0xCC
EBL version major/minor: 10.46
EBL version: Quantum_Bootloader_10.46_M1S1
Protocol version suggested by phone: 3
Set baud rate to: 6.50 Mbit/s
Flash ID: 0089 8982 - 23280001 [Intel NU48F512,512 Mbits]
CFI information:
Flash settings: 0/1024, size: 0x04000000
1 Block regions:
512 x 0x00020000 = 0x04000000
EBL ready !
Original IMEI: 35518605149971
IMEI_DATA saved OK
CCC_DATA saved OK
HWC_DATA saved OK
LOCK120_DATA saved OK
RPL saved to "C:\mobileEx\3.5\data\backup\XGOLD_35518605149971_ back.RPL"
Processing file: D25AD0F8_rm799__11.81.ppm_ma1
Downloading item CUSTackage_ma1.ppm_ebl_psi.fls, num block: 1, size: 5.15 MB
Erasing area 0x41A40000-0x41F66ABA ...OK
Programming completed in 8.047 s
Checksum verified (0x4052)
Processing file: CAA5123F_rm799__11.81.image_ma1_059K5T0
Downloading item CUSTackage_ma1_059K5T0.image.fls, num block: 1, size: 15.25 MB
Erasing area 0x42180000-0x43E1FFFE ...OK
Programming completed in 22.172 s
Checksum verified (0x6345)
Total time for flashing process(boot+erase+write) was 5 min 46.578 s
Waiting for device boot up ...
Device connected: nmwcdc\Nokia Asha 201 USB Phonet, PORT_ID: 355186051499711
Verifying communication to device OK.
Phone type: RM-799 (Nokia 201)
SW version: V 11.81 20-08-12 RM-799 (c) Nokia
Imei plain: 35518605149971-1
Product code: 059P2T5
Battery voltage: 3989 mV, current: 21 mA
Cellular system: GSM
ASIC ID: 0x0000, type: 11
Ppm Id: MA1
Language Pack:
- not available.
Master code: 1333503467
Camera config: 115B6002004020, ver:
Imei net: 35518605149971
Version: SIMLOCK SERVER
Provider: GSM Test Operator
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 800000000003000B
BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
