>>> Nokia 2320c-2b (RM-515) Unlocked Successfully <<< 1 Attachment(s) Nokia 2320c-2b (RM-515) unlocked successfully after lot of tries and R&D.. Model is presently not supported for unlocking with MX Key.. Even if u flash to RM-514 firmware, unlock is not supported.. Here is the original simlock info >>> Phone Type: RM-515 (Nokia 2320c-2b) SW Version: V 06.88 06-07-09 RM-515 (c) Nokia Imei plain: 011975003xxxxx Imei OTP: 011975003xxxxx Product Code: 0579480 Cellular System: GSM ASIC ID: 0x3168, type: 11 Ppm Id: NCR Language Pack: - not available. "C:\Program Files\Nokia\Phoenix\Products\RM-515" folder created. Imei net: 011975003xxxxx Version: SIMLOCK SERVER Provider: CINGULAR - Pacific Bell Wireless, Country: U.S.A. Counter: 0/3, 0/10 CONFIG_DATA: 3101700000000000 PROFILE_BITS: 800000000003000B BLOCK 1: 1.LOCKED (MCC+MNC): 310150 BLOCK 2: 1.LOCKED (MCC+MNC): 310170 BLOCK 3: 1.LOCKED (MCC+MNC): 311180 BLOCK 4: 1.LOCKED (MCC+MNC): 310410 BLOCK 5: 1.LOCKED (MCC+MNC): 310980 Here is the trick, how I managed to unlock it >>>> Flashed it with Nokia 2330c (RM-512) firmware sw ver 6.75 .. Then proceeded for unlock operation and got the handset unlocked smoothly.. After that just wrote the pm attached for network and then harware conversion.. Handset unlocked and now showing both 900/1800 MHz networks.. Here is the log >>> Imei net: 011975003xxxxx Version: SIMLOCK SERVER Provider: CINGULAR - Pacific Bell Wireless, Country: U.S.A. Counter: 0/3, 0/10 CONFIG_DATA: 3101700000000000 PROFILE_BITS: 800000000003000B BLOCK 1: 1.LOCKED (MCC+MNC): 310150 BLOCK 2: 1.LOCKED (MCC+MNC): 310170 BLOCK 3: 1.LOCKED (MCC+MNC): 311180 BLOCK 4: 1.LOCKED (MCC+MNC): 310410 BLOCK 5: 1.LOCKED (MCC+MNC): 310980 PhoneType:RM-512 SwVersion: V 06.75 29-04-09 RM-512 (c) Nokia MCU file: rm512__06.75.mcusw Trying to find patch position ...OK ASIC ID: 0x3168 [UPP_8M ver: 6.4] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0089 8981 [Intel NU48F256,256 Mbits] page size: 128 K type: NOR area: 01000000-02FFFFFF - COMBO FLASH ExtBUSC: AD7E B61B 2310 0340 C605 E401 20A2 0000 Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x56A0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0049B319:3B8ADA60 Area [01000000-0101FFFF] erased in 0.890 s Area [01220000-0123FFFF] erased in 0.844 s Area [01440000-0145FFFF] erased in 0.922 s Area [014C0000-014DFFFF] erased in 0.781 s Area [01CE0000-01CFFFFF] erased in 0.031 s Programming ... Programming completed. Updating SIMLOCK ...OK Completed in 1 min 16.828 s Reading Simlock info ... Imei net: 011975003xxxxx Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000003000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN |
didnt work for me Invalid File Header Flashing terminated with error(s) in 21.282 s RX Buffer: |
Nokia 2320c-2b Unlocked 10000% tested here is my log :):):) Version: SIMLOCK SERVER Provider: CINGULAR - Pacific Bell Wireless, Country: U.S.A. Counter: 0/3, 0/10 CONFIG_DATA: 3101700000000000 PROFILE_BITS: 800000000003000B BLOCK 1: 1.LOCKED (MCC+MNC): 310150 BLOCK 2: 1.LOCKED (MCC+MNC): 310170 BLOCK 3: 1.LOCKED (MCC+MNC): 311180 BLOCK 4: 1.LOCKED (MCC+MNC): 310410 BLOCK 5: 1.LOCKED (MCC+MNC): 310980 PhoneType:RM-512 SwVersion: V 06.75 29-04-09 RM-512 (c) Nokia MCU file: rm512__06.75.mcusw Trying to find patch position ...OK ASIC ID: 0x3168 [UPP_8M ver: 6.4] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0089 8981 [Intel NU48F256,256 Mbits] page size: 128 K type: NOR area: 01000000-02FFFFFF - COMBO FLASH ExtBUSC: AD7E B61B 2310 0340 C605 E401 20A2 0000 Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x56A0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00DF399C:3B8ADA60 Area [01000000-0101FFFF] erased in 0.982 s Area [01220000-0123FFFF] erased in 0.811 s Area [01440000-0145FFFF] erased in 0.921 s Area [014C0000-014DFFFF] erased in 0.851 s Area [01CE0000-01CFFFFF] erased in 0.130 s Programming ... Programming completed. Updating SIMLOCK ...OK Completed in 1 min 41.416 s Reading Simlock info ... Imei net: 0119750041****** Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000003000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN |
GOOD WORK MAN,THNKS ALOT I DO AS U SAID AND IT UNLOCK FINE.BUT MY PROBLEM IS DAT DE NOKIA 2320C-2b IS O1 FROM US,SO IS NOT SEEING SERVICE IN MY COUNTRY.NIGERIA |
HOW TO UNLOCK 2320C-2b successfully 100% unlock ANYBODY DAT SAID IS NOT WORKING.OK FLASH WITH JAF USE rm-512 V08.20 TO FLASH IT.AFTER FLASHING IT NOW USE MXKEY TO UNLOCK IT AND PICK DE 08.20 MCU FILE.PHONE WORK FINE 100% GUARANTEE. |
how about the camera its not working .. camera on stand by???? |
Flashing terminated with error wts this pinout or flash file ????? |
wawwww 100% work flash it w rm-512 unlock w mx good PM file and try this http://www.imageurlhost.com/images/k...r8uef5gyhe.jpg |
good post and idea you made sir....i'll try it 100% tested |
the picture is not the phone but the principle is the same have a nice day riad |
thanks brother for ur nice update information |
hmmmmmmm goood................... |
