Old 10-10-2010, 12:55   #1 (permalink)
Temporary banned !!
Member: 935605
Sonork: 100.1601177
Thanks Meter: 78
Exclamation Nokia 2323c flashing taking about 30 minutes
Sukses flashing Nokia 2323c with mxkey, interface ufs.
But it takes time about 30 minutes
Why so long ???
Here the log
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.8955(29-09-2010), 1.0.0.14639(29-09-2010)
Rpl backup already exist (D:\Program Files\mobileEx\3.4\data\backup\35195203XXXXX_BACK. rpl).
Processing file: rm543__06.75.mcusw as MCU
[DCT4,DCT4 ALGORITHM] size: 11.53 MB
Supported Ids: 3160, 3161, 3162, 3164, 3166, 3168
ASIC ID: 0x3168 [UPP_8M ver: 6.4]
SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8
Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168
FlashID0: 0089 8981 [Intel NU48F256,256 Mbits] page size: 128 K type: NOR area: 01000000-02FFFFFF - COMBO FLASH
ExtBUSC: AD7E B61B 2310 0340 C605 E401 20A2 0000
Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x56A0
Performing Flash Authentication ...OK
UEM ID: 009D1B3B:3B8ADA60
Area [01000000-0101FFFF] erased in 0.907 s
Area [01020000-01CFFFFF] erased in 1 min 19.828 s
Flash programming ...
Programming completed in 13 min 38.781 s
File Processed in 15 min 10.922 s
Processing file: rm543__06.75.image_x_bla as CNT
[DCT4,DCT4 ALGORITHM] page size: 128 K size: 5.88 MB
UEM ID: 009D1B3B:C5A4DA78
Area [02180000-02E7FFFF] erased in 1 min 57.813 s
Area [02E80000-02FBFFFF] erased in 10.906 s
Converting UCP blocks to 128 K.
Programming completed in 7 min 12.297 s
Extracting Content Pack, (c) Nokia File Server
Content Pack extracted successfully in 0.172 s
File Processed in 9 min 42.375 s
Processing file: rm543__06.75.ppm_x as PPM
[DCT4,DCT4 ALGORITHM] size: 2.75 MB
UEM ID: 009D1B3B:2984DA60
Area [01D00000-0217FFFF] erased in 20.828 s
Programming completed in 3 min 5.406 s
File Processed in 3 min 37.187 s
Flashing completed in 28 min 36.890 s
Phone Type: RM-543 (Nokia 2323c-2)
SW Version: V 06.75 29-04-09 RM-543 (c) Nokia
Imei plain: 351952032XXXXX
Imei OTP: 351952032XXXXX
Product Code: 0576670
Cellular System: GSM
ASIC ID: 0x3168, type: 11
Ppm Id: X
Language Pack:
- not available.
Imei net: 351952032XXXXX
Version: SIMLOCK SERVER
Provider: ALL Operator, Country: -
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 800000000003000B
BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
Total time to process is 28 min 51.562 s
The Following User Says Thank You to bujokhp For This Useful Post:
Old 10-10-2010, 12:58   #2 (permalink)
Member: 681854
Thanks Meter: 12
Brother use ATF Flashing within 3min
Old 10-10-2010, 14:46   #3 (permalink)
Master Software's Avatar
Member: 1149013
Thanks Meter: 247
ATF Flasher is very fasht flashing tool
Old 10-11-2010, 04:44   #4 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
as told by other member, mxkey will flash much faster on that phone by using ATF as interface.
Old 10-13-2010, 07:11   #5 (permalink)
Temporary banned !!
Member: 935605
Sonork: 100.1601177
Thanks Meter: 78
thanks for reply. I will try another interface when i get another phone to test
Page generated in 0.20119 seconds with 9 queries
