Old 06-06-2009, 14:03   #1 (permalink)
sahil2000ind's Avatar
Member: 269044
Sonork: 100.1590584
Thanks Meter: 3,949
Nokia 2610 rh-86 v 03.77 27-07-06 t-mobile unlock done good with mx-key in no time:)-
HERE IS THE READ INFO LOG:-
Version Info:
MCU SW version: V 03.77 27-07-06 RH-86 (c) Nokia.
HW version: 0603
UEM version: 1328
UPP version: 12352
RFIC version: 0500
DSP version: P05w45.v26
LCD version: ELBE
PPM version: V 03.77 27-07-06 RH-86_87 (c) Nokia. AE
Content Pack version: Content: ae V 03.77 27-07-06 RH-86_87 (c) Nokia.
Serial Numbers:
IMEI plain: 352770012431153
IMEI spare to net: 3A 25 77 00 21 34 11 05
IMEI SV to net: 33 25 77 00 21 34 11 15 F3
Other Info:
Model : Nokia 2610 (Classic Phone)
CS type : GSM/DCS1800
Project Name: Panda (EU)
Imei net: 35277001243115
Provider: Virgin, Country: United Kingdom
Counter: 0/3, 0/10
CONFIG_DATA: 2343000000000000
PROFILE_BITS: 800000000001000B
BLOCK 1: 1.LOCKED (MCC+MNC): 23430F
BLOCK 2: 1.LOCKED (MCC+MNC): 23430F
HERE IS THE UNLOCKING LOGS:-
PhoneType:RH-86
SwVersion: V 03.77 27-07-06 RH-86 (c) Nokia.
MCU file: rh86_87__03.77.mcusw
Trying to find patch position ...OK, case id: 2
ASIC ID: 0x3040 [UPP2M_v2.0]
u3_2nd.fia: [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8
Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168
FlashID0: 00EC 22E8 [Samsung K4M64163PK] page size: 64 K type: NOR area: 01000000-01FFFFFF
FlashID1: 0000 0001 [unused/removed]
ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514
u3_amd.fia: [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x7528
Performing Flash Authentication ...OK
UEM ID: 00106CCF:874EDA60
Area [010A0000-010BFFFF] erased in 0.828 s
Programming ...
Programming completed.
Updating SIMLOCK ...OK
Programming ...
Completed in 39.328 s
Reading Simlock info ...
Provider: ALL Operator, Country: -
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
ALL THANKS GOES TO Mr.ALIM HAPE AND MX-KEY TEAM
WBR
sahil2000ind
The Following 3 Users Say Thank You to sahil2000ind For This Useful Post:
Nokia 6500c rm-265 v 04.80 31-10-07 rm-265 unlocked by mx-key in no time:)- sahil2000ind MXKEY Nokia Flasher and Unlocker (by Alim Hape) 4 06-10-2009 15:36
Nokia 2610 rh-86 Unlock code wawuce Phone Unlocking Codes & Maps 1 01-27-2009 14:32
nokia 2610 rh-86 convert into 2626 rm-291 rasgula Nokia Digital Core Technology 4 ( DCT-4 ) 4 01-14-2009 07:29
[REL] Nokia 2610 RH-86 4.90 - rapidshare link here. Justin Case Nokia Digital Core Technology 4 ( DCT-4 ) 1 03-25-2007 13:41
Page generated in 0.14321 seconds with 9 queries
