02-20-2010, 14:09 | #3 (permalink) |
Freak Poster Join Date: Nov 2007 Location: Jamalpur, Bangladesh
Member: 623873 Status: Offline Thanks Meter: 41 | log here ............. Content Pack extracted successfully in 0.031 s File Processed in 1 min 12.234 s Processing file: rh86_87__06.70.ppm_x as PPM [DCT4,DCT4 ALGORITHM] size: 2.50 MB Supported Ids: 3040 ASIC ID: 0x3040 [UPP_4M ver: 4.1] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0001 2C7E [AMD S29NS128N,128 Mbits] page size: 128 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00DE33B4:2984DA60 Area [018E0000-01B7FFFF] erased in 15.000 s Flash programming ... Programming completed in 36.593 s File Processed in 1 min 0.281 s Flashing completed in 6 min 22.062 s Phone Type: RH-86 (Nokia 2610) SW Version: V 06.70 16-11-07 RH-86 (c) Nokia. Imei plain: ??????????????-? Product Code: 0533407 Cellular System: GSM ASIC ID: 0x3040, type: 11 Ppm Id: X Language Pack: - not available. Imei plain is invalid !!! Imei net: FFFFFFFFFFFFFF Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: 3FD4046DF2078C04 PROFILE_BITS: AEE9BB4A5A015EFF SIMLOCK_DATA corrupted! Total time to process is 6 min 31.593 s |
02-20-2010, 14:11 | #4 (permalink) |
Member: 623873 Status: Offline Thanks Meter: 41 | Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.7705(18-02-2010), 1.0.0.12217(18-02-2010) ASIC ID: 0x3040 [UPP_4M ver: 4.1] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0001 2C7E [AMD S29NS128N,128 Mbits] page size: 128 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00DE33B4A3BDA66 ASIC type: 11 UEM Imei: Empty Flash Imei: 35977100049105 MasterCode: 3324057473 RPL saved to "C:\mobileEx\3.3\data\backup\_BACK.rpl" Phone Type: RH-86 (Nokia 2610) SW Version: V 06.70 16-11-07 RH-86 (c) Nokia. Imei plain: ??????????????-? Product Code: 0533407 Cellular System: GSM ASIC ID: 0x3040, type: 11 Ppm Id: X Language Pack: - not available. Imei plain is invalid !!! Imei net: FFFFFFFFFFFFFF Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: 3FD4046DF2078C04 PROFILE_BITS: AEE9BB4A5A015EFF SIMLOCK_DATA corrupted! Invalid UEM Data, No RPL backup will be made for this phone. |
6120c Original Imei: Empty MXKEY help | kabul | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 11 | 05-14-2010 11:42 |
nokia 2600 UEM Imei: Empty?????? | omkarvitekar | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 01-01-2010 18:15 |
Nokia 1200 UEM is empty | ZubairArain | Universalbox | 1 | 11-29-2009 11:46 |
UEM IMEI: f0000000f00000X | aikonmani | Universalbox | 1 | 01-13-2008 11:43 |
