Old 03-26-2011, 09:26   #1 (permalink)
Member: 71502
Sonork: 100.1650667
Thanks Meter: 587
6610 phone restricted???? (ANSWERED)
nokia 6610 phone restricted
see log
Old 03-26-2011, 09:27   #2 (permalink)
Member: 743419
Sonork: ranz_28
Thanks Meter: 42
unlock it................................................ ......
Old 03-26-2011, 09:36   #3 (permalink)
Emmanuel Ankah's Avatar
Member: 167261
Thanks Meter: 19
Post
see log
free unlock ufs sarasoft and check serial lmei whether ??????????4
Old 03-26-2011, 09:38   #4 (permalink)
Member: 71502
Sonork: 100.1650667
Thanks Meter: 587
I DONE IT
Version Info:
MCU SW version: V 5.52 19-09-03 NHL-4 (c) Nokia.
HW version: 0660
PCI version: 0
UEM version: 8
UPP version: 4384
RFIC version: 0203
DSP version: V4.61
LCD version: SED15G10
PPM version: V 5.52 19-09-03 NHL-4 (c) Nokia. C
Bluetooth ID: 00 A5 A5 00 5B 02
DVB-H receiver Bootloader version: [
Product Info:
Production serial number: CMC090246
Product code: 0509510
Module code: 0
Basic production code: 0507780
Flash code: 0
Order number: 0
Long production SN: 0
ATO: 0
Serial Numbers:
IMEI warranty: 351****************
IMEI plain: 351***************
IMEI spare to net: 3A 15 53 40 10 06 17
IMEI SV to net: 33 15 53 40 10 06 17 50 F3
PDC: 4E 54 54 4A 50 12 34 56
Other Info:
Model: Nokia 7210 (Fashion Phone)
CS type: GSM900/GSM1800/GSM1900
Project Name: Vanessa
BSI: 0.0 KOhm
Imei net: 351***************
Version: SIMLOCKLIB VERSION 2.26
Provider: GSM Test Operator, Country: -
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 0000000000000002
BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
Old 03-26-2011, 09:42   #5 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
to all, with the same case, how to repair all dct4 corrupted imei:
Rebuild Imei:
DCT4 > Service > Imei & Security > Online Logger.
- press login, DCT4 IMEI
proceed with simlock
- untick direct unlock > init simlock
The Following User Says Thank You to gbluez For This Useful Post:
Old 03-27-2011, 09:13   #6 (permalink)
Registered User
Member: 759011
Sonork: 164643 (server.sonork.com
Thanks Meter: 152
Arrow nokia 6610 phone restricted
not unlock posible hwk,mexkey
unlock jaf 100% unlock this modal not unlock mexkey
Old 03-27-2011, 09:21   #7 (permalink)
Member: 1025395
Sonork: 100.1606191
Thanks Meter: 20
phone is aleady repaired by t.s.
Old 03-27-2011, 13:30   #8 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
my personal advice just for you:
don't use mxkey. it's only for smart people. too hard for you, isn't it?
Old 03-27-2011, 13:43   #9 (permalink)
Member: 71502
Sonork: 100.1650667
Thanks Meter: 587
Rebuild Imei:
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.9100(23-12-2010), 1.0.0.15124(23-12-2010)
ASIC ID: 0x1120 [UPP_8M ver: 2.0 or 2.1 or 2.2]
SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0
Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164
FlashID0: 00EC 22F2 [Samsung K8S64158TM,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF
FlashID1: 0000 0001 [unused/removed]
ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514
Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8
Performing Flash Authentication ...OK
UEM ID: 00CBE439:2984DA60
ASIC type: 2
UEM Imei: 35135040160710
Flash Imei: 35135040160710
MasterCode: 7233765446
RPL saved to "C:\mobileEx\3.4\data\backup\35135040160710_BACK.r pl"
Phone Type: NHL-4 (Nokia 7210)
SW Version: V 5.65 19-Nov-04 NHL-4 (c) Nokia.
Imei plain: 35135040160710-0
Imei OTP: 35135040160710
Product Code: 0509510
Cellular System: GSM
ASIC ID: 0x1120, type: 2
Ppm Id: Q
Language Pack:
English,Chinese S,Chinese T (Hong Kong)
Imei net: 35135040160710
Version: SIMLOCKLIB VERSION 2.26 - fixed version for more TDS-6 boxes
Counter: 0/3, 0/10
mobile is on but after 10 sec. off
when i write imei by mistake 351350401607100
i press *#92702689# imei is 351350401697101
original print imei 351350401697101
how to change original imei
Old 03-27-2011, 13:52   #10 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
damaged data2 inside uem otp.
you will need to change uem. repeat with imei rebuild
Old 03-27-2011, 14:08   #11 (permalink)
Member: 71502
Sonork: 100.1650667
Thanks Meter: 587
DSP version: V4.61
PPM version: V 5.65 19-Nov-04 NHL-4 (c) Nokia. D
Product Info:
Module code: 0
Flash code: 0
Order number: 0
ATO: 0
Serial Numbers:
IMEI warranty: 351350/40/169710/1
IMEI plain: 351350401607100
IMEI SV to net: 33 15 53 40 10 06 17 50 F5
Other Info:
BSI: 0.0 KOhm
Counter: 0/3, 0/10
Old 03-27-2011, 14:17   #12 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
start watchdog timer test inside various test.
is it passed or not?
Old 03-27-2011, 14:31   #13 (permalink)
Member: 71502
Sonork: 100.1650667
Thanks Meter: 587
Phone Type:
SW version:
ID Test name Startup Result
46 UEM_CBUS_IF Y PASSED(00)
15 SLEEP_X_LOOP Y PASSED(00)
1 AUX_DA_LOOP Y PASSED(00)
3 EAR_DATA_LOOP Y PASSED(00)
17 TX_IDP_LOOP Y PASSED(00)
18 TX_IQ_DP_LOOP Y PASSED(00)
12 SIM_CLK_LOOP Y PASSED(00)
13 SIM_IO_CTRL_LOOP Y PASSED(00)
6 IR_LOOP Y !NO SIGNAL(06)
8 MBUS_RX_TX_LOOP Y PASSED(00)
20 BACKUP_BATT Y !FAILED(01)
42 RADIO N !NOT EXECUTED(03)
39 WARRANTY N !NOT EXECUTED(03)
51 PA_TEMP Y PASSED(00)
33 SIM_LOCK Y PASSED(00)
10 PPM_VALIDITY N PASSED(00)
7 KEYBOARD_STUCK N !NOT EXECUTED(03)
41 FLASH_CHECKSUM N PASSED(00)
54 EXT_RAM_DATA_BUS N !NOT EXECUTED(03)
55 EXT_RAM_ADDR_BUS N !NOT EXECUTED(03)
30 RF_CHIP_ID N !NOT EXECUTED(03)
45 IR_IF N !NOT EXECUTED(03)
Old 03-27-2011, 14:38   #14 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
not this test, WD Timer, on various tab.
forget it..
reset data1, full erase, untick safe erase. reflash.
rebuild imei, how is the way, described above.
write pm, init simlock, all described above.
if phone still turned off after seconds: uem damaged, also described above.
Old 03-27-2011, 14:53   #15 (permalink)
Member: 71502
Sonork: 100.1650667
Thanks Meter: 587
not this test, wd timer, on various tab.
Forget it..
Reset data1, full erase, untick safe erase. Reflash.
Rebuild imei, how is the way, described above.
Write pm, init simlock, all described above.
If phone still turned off after seconds: Uem damaged, also described above.
this is the wd test log 00:31
Phone Stuff for FREE & KEy-GEn For Logo Editor ! BoNtEk - ThA WtC MeMbA Nokia Multimedia 8 10-31-2012 20:17
SIM restriction pending -- what does it mean? Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 7 07-17-2011 10:05
Page generated in 0.30621 seconds with 11 queries
