11-17-2013, 11:07 | #1 (permalink) |
No Life Poster Join Date: Aug 2010 Location: SearchinG ... Age: 39
Member: 1369772 Status: Offline Thanks Meter: 297 | Nokia 2690 RM-635 dead after flash and flash with latest version now phone is dead. here is LOG. MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN: C0xxxxxx Using device: HTI, FW ver: 00.50, SN: 000xxxxx Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.21724(14-05-2013), Library ver: 1.0.0.14397(09-05-2013) CMT Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.0] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 1C500106CDED0256641CB17AF229DF1C9AE86286 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: RAP3Gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 eBB5ProtocolType: OLD Storage0: 0089 8982 - 0000 8A31 [Intel NU48F512,512 Mbits] type: FLASH,NOR, asic:CMT Storage content: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.50.0 revision: 0.0 size: 0x23010 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS is blank/erased. TransmissionMode: DDR&TX2 Processing MCU file: rm635__10.65.mcusw [BB5,BB5 ALGORITHM] size: 17.99 MB Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000 Storing certificate [NPC, VARIANT, R&D, CCC, HWC] ...OK Erase size: 21 MB CMT FLASH,NOR area [00000000-000006BF] CMT FLASH,NOR area [000006C0-0001FFFF] CMT FLASH,NOR area [00040000-000BFFFF] CMT FLASH,NOR area [000C0000-0013FFFF] CMT FLASH,NOR area [00140000-0137FFFF] CMT FLASH,NOR area [01380000-0151FFFF] erased in 0.203 s Prog.status for Asic CMT ... NOR: OK Flash programming ... Error chk C7012D0103CD RX2 not responding, please check BSI/cable/pinout ! Error while programming [00] at 0x00000400, Result: 0000 Task failed at (0800001C)!!! Last RX buffer: C7 01 2D 01 03 CD 00 |
11-17-2013, 15:27 | #2 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Bro. Clean FBus Cable or change it, Clean Flashing Terminals & Battery Connector of Phone & try again will solve it. You can also try USB Flashing. BR, ZUBER |
11-18-2013, 04:42 | #3 (permalink) | |
Member: 1369772 Status: Offline Thanks Meter: 297 | Quote:
I clean the Flashing terminal and B/C Here is USB flashing procedure log MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN: Cxxxxx Using device: USB ROM and HTI, FW ver: 00.50, SN: 00xxxxxxxx Connection status: UHCI:HUB::USB 2.00 (Full-speed) Driver: NMWCD, ver: 7.1.32.84 Module ver: 1.0.0.21724(14-05-2013), Library ver: 1.0.0.14397(09-05-2013) Processing MCU file: rm635__10.65.mcusw [BB5,BB5 ALGORITHM] size: 17.99 MB Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... CMT SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.0] CMT EM0 ID: 00000296 CMT EM1 ID: 00000B22 CMT PUBLIC ID: 1C500106CDED0256641CB17AF229DF1C9AE86286 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID: 273F6D55DFAAF68F Flashing CMT Update Server Data, ULO: 0x3900 bytes Update Server code succesfully sent to phone. Flashing CMT Update Server Data, UPDAPP: 0x49480 bytes Update Server code succesfully sent to phone. Flashing CMT Update Server Data, PASUBTOC: 0x57AC0 bytes Update Server code succesfully sent to phone. Waiting for USB device removal ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: F0F12C Verifying communication to device... ERROR: Could not verify communication ! Failed to set phone to flashmode, possible reason: Update Agent not running or PASUBTOC corrupted ! Please recover phone using FBUS. Maxpro. | |
11-18-2013, 04:58 | #4 (permalink) | |
No Life Poster Join Date: Oct 2007
Member: 608516 Status: Offline Sonork: 100.1607007 Thanks Meter: 123 | Quote:
11-19-2013, 15:53 | #5 (permalink) | |
No Life Poster Join Date: Feb 2011 Location: Android Modding
Member: 1507693 Status: Offline Thanks Meter: 131 | Quote:
bro you are 1000% WRONG, usb flashing for 2690 rm-635 is very well supported by MXBOX, MXKEY, but if flashing failed first time with usb or rj-45 cable, then you cannot continue flashing with usb, you recover using rj-45 cable.this is RAP3Gv3_algo!!! USB FLASHING SUPPORTED. but if flashing failed before finishing PROGRAMING CMT you have to use RJ-45 cable to recover it, check where his software stopped ( CMT PAPUBKEYS is blank/erased. TransmissionMode: DDR&TX2 Processing MCU file: rm635__10.65.mcusw [BB5,BB5 ALGORITHM] size: 17.99 MB Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000 Storing certificate [NPC, VARIANT, R&D, CCC, HWC] ...OK Erase size: 21 MB CMT FLASH,NOR area [00000000-000006BF] CMT FLASH,NOR area [000006C0-0001FFFF] CMT FLASH,NOR area [00040000-000BFFFF] CMT FLASH,NOR area [000C0000-0013FFFF] CMT FLASH,NOR area [00140000-0137FFFF] CMT FLASH,NOR area [01380000-0151FFFF] erased in 0.203 s Prog.status for Asic CMT ... NOR: OK Flash programming ... Error chk C7012D0103CD RX2 not responding, please check BSI/cable/pinout ! Error while programming [00] at 0x00000400, Result: 0000 Task failed at (0800001C)!!! Last RX buffer: C7 01 2D 01 03 CD 00 AND THAT ERROR IN RED SHOWS RJ-45 CABLE IS NOT WELL CONNECTED TO PHONE, OR CABLE NOT GOOD | |
The Following User Says Thank You to Fragga For This Useful Post: |
11-20-2013, 10:36 | #6 (permalink) | |
