Old 08-01-2011, 07:39   #1 (permalink)
Member: 1323194
Thanks Meter: 61
Nokia 2700 C Contact service
Nokia 2700 Contact service and switched off
Log report
Using device: HTI BOX, FW ver: 00.17
Driver: usbuhci:usbhub:usbccgp:WinUSB, ver: 3.5.0.0
Module ver: 1.0.0.17841(12-07-2011), Library ver: 1.0.0.11875(12-07-2011)
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 097002070EC98B56B58ABCEA621F6A0EF11A972C
ASIC MODE ID: 00
ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
ROM ID: 273F6D55DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00
Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
Storage0: 0089 8982 - 0000 8A31 [Intel NU48F512,512 Mbits] type: FLASH,NOR, asic:CMT
Storage content: 0000 0000 0000 0000 0000 0000 0000 0000
Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT
TransmissionMode: 16Bit
Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.50.0 revision: 0.0 size: 0x23010
Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
CMT PAPUBKEYS HASH: 3EA22A1DDA660002E56108DB5072A10F8709443F
TransmissionMode: DDR&TX2
Original Imei: 35694603657825
Original Product code: 0579811
Bluetooth ID: 9C18746C56E5
Phone Type: RM-561 (Nokia 2700 classic)
SW Version: V 09.80 02-12-09 RM-561 (c) Nokia
Imei plain: 35694603*******
Product Code: 0579811
Battery voltage: 4695 mV, current: 80 mA
Language Pack:
- not available.
Detected as PA_SL3 phone.
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
TimeStamp: 2010-09-16T12:08:54Z
SW Version: 09.98
Variant Version: 032
ProductProfile: RM561_0579811_09.98_032.spr
Simlock: 0579811_simlock.bin
Imei net: 35694603*******
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
Old 08-01-2011, 07:43   #2 (permalink)
reset12345's Avatar
Member: 694652
Sonork: 100.1669706
Thanks Meter: 193
this is 100%herdwher proublum
Old 08-01-2011, 07:50   #3 (permalink)
mohammed imran's Avatar
Member: 533912
Thanks Meter: 109
first reheat not success then change........................
The Following User Says Thank You to mohammed imran For This Useful Post:
Old 08-01-2011, 07:53   #4 (permalink)
Member: 1323194
Thanks Meter: 61
How to solve
In hardware which section bro
Old 08-01-2011, 07:55   #5 (permalink)
Member: 1323194
Thanks Meter: 61
Ok bro, i will try and reply
Old 08-01-2011, 08:18   #6 (permalink)
Member: 1323194
Thanks Meter: 61
Now i just flashed, everything ok
But mobile is dead
Old 08-01-2011, 10:37   #7 (permalink)
Member: 533912
Thanks Meter: 109
why u flash ur flash log ok before check ur firmware version before ur version 09.80 flash with higher ver not success then change avilma......
Old 11-27-2011, 07:19   #8 (permalink)
NAAZTELECOM's Avatar
Member: 1274132
Thanks Meter: 20
rehot avilma ur problem will solved......
Old 11-27-2011, 07:28   #9 (permalink)
mobilehelper's Avatar
Member: 1696653
Sonork: 100.1638410
Thanks Meter: 782
Originally Posted by vijay dts View Post
nokia 2700 contact service and switched off
log report
using device: Hti box, fw ver: 00.17
driver: Usbuhci:usbhub:usbccgp:winusb, ver: 3.5.0.0
module ver: 1.0.0.17841(12-07-2011), library ver: 1.0.0.11875(12-07-2011)
cmt data :
System asic id: 000000010000022600010006030c192101033000 [rap3g ver: Pa 3.x]
em0 id: 00000296
em1 id: 00000b22
public id: 097002070ec98b56b58abcea621f6a0ef11a972c
asic mode id: 00
root key hash: 9ddbfcfe6e73ced7d8c6268c8eb85723
rom id: 273f6d55dfaaf68f
secondaryboot: Rap3gv3_2nd.fg [bb5] version: 9.11.1 revision: 0.0 size: 0x3c00
supported ids: 0103192101003000, 010c192101003000, 0103192101013000, 010c192101013000, 0103192101003100, 010c192101003100, 0303192101023000, 030c192101023000, 0303192101033000, 030c192101033000, 0103192101001101, 010c192101001101, 0003192101001002, 000c192101001002, 0013192101001002, 001c192101001002
storage0: 0089 8982 - 0000 8a31 [intel nu48f512,512 mbits] type: Flash,nor, asic:cmt
storage content: 0000 0000 0000 0000 0000 0000 0000 0000
storage1: Ffff 0000 - 0000 0000 type: Mmc, asic:cmt
transmissionmode: 16bit
algorithm: Rap3gv3_algo.fg [bb5 algorithm] version: 9.50.0 revision: 0.0 size: 0x23010
supported ids: 0103192101003000, 010c192101003000, 0103192101013000, 010c192101013000, 0103192101003100, 010c192101003100, 0303192101023000, 030c192101023000, 0303192101033000, 030c192101033000, 0003192101002000, 000c192101002000, 0003192101002100, 000c192101002100, 0003192101002200, 000c192101002200, 0003192101012200, 000c192101012200, 0103192101001101, 010c192101001101, 0003192101001002, 000c192101001002, 0013192101001002, 001c192101001002
cmt papubkeys hash: 3ea22a1dda660002e56108db5072a10f8709443f
transmissionmode: Ddr&tx2
original imei: 35694603657825
original product code: 0579811
bluetooth id: 9c18746c56e5
phone type: Rm-561 (nokia 2700 classic)
sw version: V 09.80 02-12-09 rm-561 (c) nokia
imei plain: 35694603*******
battery voltage: 4695 mv, current: 80 ma
language pack:
- not available.
Detected as pa_sl3 phone.
- avoid sw downgrade & manual erase to this phone !
Simlock seems to be valid
superdongle_key seems to be valid
cmla_key seems to be valid
wmdrm_pd seems to be valid
simlock_test passed
security_test passed
timestamp: 2010-09-16t12:08:54z
sw version: 09.98
variant version: 032
productprofile: Rm561_0579811_09.98_032.spr
simlock: 0579811_simlock.bin
imei net: 35694603*******
version: Simlock server
counter: 0/3, 0/10
config_data: 2440700000000000
profile_bits: 0000000000000000
block1: 1=open, 2=open, 3=open, 4=open, 5=open
block2: 1=open, 2=open, 3=open, 4=open, 5=open
block3: 1=open, 2=open, 3=open, 4=open, 5=open
block4: 1=open, 2=open, 3=open, 4=open, 5=open
block5: 1=open, 2=open, 3=open, 4=open, 5=open
block6: 1=open, 2=open, 3=open, 4=open, 5=open
block7: 1=open, 2=open, 3=open, 4=open, 5=open
this is hardware problem pro.u just normaly hit in power ic.ur problem is solve 10000000%
New Nokia Software!!!!!!! Jefferson Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 52 12-30-2016 07:17
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 30 02-24-2016 09:21
Page generated in 0.31781 seconds with 9 queries
