Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > MXKEY (by Alim Hape) > MXKEY Nokia Flasher and Unlocker (by Alim Hape)
Old 10-08-2010, 09:26   #1 (permalink)
Rin2's Avatar
Member: 982335
Sonork: 100.1603225
nokia 2700c-2 white display after nokia logo.. (answered)
but handset is working ok without sim card.
flashing log....
Library version: 1.0.0.8955(29-09-2010), 1.0.0.14639(29-09-2010)
Processing file: FAF34F49_rm561__09.97.mcusw as MCU
[BB5,BB5 ALGORITHM] size: 19.41 MB
Supported RAP Ids: 010C192101013000, 0103192101003000, 030C192101033000
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable,Battery back to device.
Insert Charger or Press phone's power button
Waiting for USB device ...
[ADL] Pooling for ADL device
[ADL] Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 31EC223F
RAP SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
RAP EM0 ID: 00000296
RAP EM1 ID: 00000B22
RAP PUBLIC ID: 2710020DA2FB89569548B0537E172BDE7D0DBFE1
RAP ASIC MODE ID: 00
RAP ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
RAP ROM ID: 273F6D55DFAAF68F
[ADL] Flashing CMT Update Server Data, ULO: 0x3900 bytes
[ADL] Update Server code succesfully sent to phone.
[ADL] Flashing CMT Update Server Data, UPDAPP: 0x4B340 bytes
[ADL] Flashing CMT Update Server Data, PASUBTOC: 0x59980 bytes
[ADL] Device found: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, ID: 31BF6E02
[ADL] Verifying communication to device OK.
Erase size: 21.00 MB
CMT NOR area [00000000-000006BF] erased in 0.594 s
CMT NOR area [000006C0-0001FFFF] erased in 0.625 s
CMT NOR area [00040000-000BFFFF] erased in 2.578 s
CMT NOR area [000C0000-0013FFFF] erased in 2.204 s
CMT NOR area [00140000-0137FFFF] erased in 1 min 32.843 s
CMT NOR area [01380000-0151FFFF] erased in 8.485 s
Flash programming ...
CMT PAPUBKEYS: 3EA22A1DDA660054937DB77F2B8852B100000000 (RAP Certificate 202 v.1) written.
Programming completed in 1 min 7.765 s
Processing file: 07072A64_rm561__09.97.ppm_mena_b as PPM
[BB5,BB5 ALGORITHM] size: 5.52 MB
Erase size: 8.62 MB
CMT NOR area [01520000-01DBFFFF] erased in 42.203 s
Programming completed in 18.547 s
Processing file: B3AA323B_rm561__09.97.image_mena_b_blac as CNT
[BB5,BB5 ALGORITHM] page size: 128 K size: 8.26 MB
Erase size: 34.00 MB
CMT NOR area [01DC0000-0215FFFF] erased in 21.985 s
CMT NOR area [02160000-03FBFFFF] erased in 2 min 59.562 s
Converting UCP blocks to 128 K.
Programming completed in 27.500 s
[ADL] Restarting phone ...
[ADL] Timeout, no usb device found.
[ADL] Phone flashing completed, but failed to verify communication to product!
[ADL] Retrying in finalize phase...
[ADL] Device found: nmwcdc\Nokia 2700 classic USB Generic, ID: 18EAD8E9
Flashing completed in 9 min 3.391 s
Phone Type: RM-561 (Nokia 2700 classic)
SW Version: V 09.97 18-06-10 RM-561 (c) Nokia
Imei plain: 354192**********
Product Code: 0587979
Language Pack:
- not available.
This is SL3 phone(Simlock2 format).
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 35419**********
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
Total time to process is 9 min 5.531 s
Nokia USB ROM detached.
The Following 4 Users Say Thank You to Rin2 For This Useful Post:
Old 10-08-2010, 11:01   #2 (permalink)
.:SARCAR:.'s Avatar
Member: 322206
Sonork: 100.1594813/.:SARCAR:.
mate I think it's a hardware problem but before that make full flashing with fbus.
means backup all certificates (imei,simlock rpl) if possiable full pm then full erase the set & flash the phone with latest version.after that restore certificates make pmm auth & write pm 1,309 . then check with sim card.
post result
The Following 3 Users Say Thank You to .:SARCAR:. For This Useful Post:
Old 10-08-2010, 12:02   #3 (permalink)
Rin2's Avatar
Member: 982335
Sonork: 100.1603225
post result
i have already flashed the set with f bus interface.
but problem remain same.
The Following 2 Users Say Thank You to Rin2 For This Useful Post:
Old 10-08-2010, 12:12   #4 (permalink)
Ali Ahammad's Avatar
Member: 1350057
Sonork: Muntaha
Re hot the power ic.
problem solved 100%
The Following User Says Thank You to Ali Ahammad For This Useful Post:
Old 10-08-2010, 12:25   #5 (permalink)
gbluez's Avatar
Member: 73565
most case is nor flash that upper on rap chip (package on package) has got bad contact.
reheat, reball.
The Following User Says Thank You to gbluez For This Useful Post:
Old 11-08-2010, 15:27   #6 (permalink)
Member: 1210538
Sonork: ssibawi
[QUOTE=Ali Ahammad;6423302]Re hot the power ic.
problem solved 100%[/QUOTE
I have same problem display white screnn after nokia logo caeuse water damage, any solution with picture?
The Following User Says Thank You to ssibawi For This Useful Post:
Old 03-02-2011, 07:20   #7 (permalink)
master mobiles's Avatar
Member: 352880
Sonork: 100.1609545
[QUOTE=ssibawi;6544187]
reboll dabble chip ( cpu ) ic that is final solution
The Following 3 Users Say Thank You to master mobiles For This Useful Post:
Old 03-02-2011, 07:35   #8 (permalink)
Member: 887785
bro just flash last ver 9.98 prob solved
Old 03-02-2011, 07:40   #9 (permalink)
Member: 887785
Old 03-02-2011, 07:41   #10 (permalink)
mobylsolute's Avatar
Member: 587695
Sonork: 33121240
Arrow nokia 2700c
nokia 2700c make usb flashing set maybe ready
i have same problem i can solve with usb flashing with latest version
Old 03-02-2011, 07:50   #11 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
You r What expert ? MX KEY / NOKIA ?
What Flash Log post by original thread starter ?
The Following User Says Thank You to srinibas For This Useful Post:
Old 03-02-2011, 08:07   #12 (permalink)
sajidshah50's Avatar
Member: 1016490
Sonork: MY PHONE
Bro change the power ic.......it's in hardware....100% tested by uem
The Following 2 Users Say Thank You to sajidshah50 For This Useful Post:
Old 05-04-2011, 15:41   #13 (permalink)
sskanwal's Avatar
Member: 1380808
Sonork: askanwal
i flashed with latest version 9.98 and rehot power ic but same prob
The Following User Says Thank You to sskanwal For This Useful Post:
Old 05-04-2011, 16:26   #14 (permalink)
arvinddald's Avatar
Member: 582669
Sonork: 100.1592908
jus remove cam n flash ur phone
The Following User Says Thank You to arvinddald For This Useful Post:
Old 05-04-2011, 17:05   #15 (permalink)
Crazy Poster
Member: 554727
Are you have change LCD?
The Following User Says Thank You to dvd3t For This Useful Post:
New Nokia Software!!!!!!! Jefferson Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 73 05-15-2013 13:07
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 26 09-25-2012 02:41
Page generated in 0.34089 seconds with 11 queries
