Old 10-06-2012, 05:59   #1 (permalink)
6622622's Avatar
Member: 1562066
Sonork: 100.1622824
Thanks Meter: 555
Arrow Nokia 2700c flash problem
SCAN INFO
Phone type: RM-561 (Nokia 2700 classic)
SW version: V 09.95 02-04-10 RM-561 (c) Nokia
Imei plain: 35341704301865-3
Product code: 0579321
Battery voltage: 4534 mV, current: 31 mA
Language Pack:
- not available.
SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK)
warning: avoid SW Downgrade & manual erase to this phone !
Camera config: NIMMIIIIRRFF0A021001, ver: 002.007
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 353417043018653
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
WRITE FLASH
Version from phone: 09.95
Version from file: 09.97
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 4], SN: C085461E
Using device: HTI, FW ver: 00.50, SN: 0000021B
Connection status: UHCI:HUB:USB 2.00 (Full-speed)
Driver: WinUSB, ver: 3.5.1.0
Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14195(13-07-2012)
Rpl backup already exist (C:\mobileEx\3.5\data\backup\RPL\BB5_3534170430186 5_BACK.rpl).
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.0]
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 18D00108560E0156946ACC6B04B78F49EA8B4C4E
ASIC MODE ID: 00
ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
ROM ID: 273F6D55DFAAF68F
SecondaryBoot: RAP3Gv30_2nd.fg [BB5] version: 10.48.1 revision: 3.0 size: 0x3B80
Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
eBB5ProtocolType: NEW
TransmissionMode: DDR&TX2
Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT
Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT
Storage2: 00EC 2400 - 0000 8A31 [Samsung K5N2833ATB,512 Mbits] type: FLASH,NOR, asic:CMT
Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Not supported flash chip, please disable "Use New Protocol for RAP3GV3" in config
Task failed at (08000008)!!!
Last RX buffer: 00 00 01 00 00 00 01 00 00 00 00 BB 00
Nokia 2700 alive only on application error ahen open application handset Restart
Old 10-06-2012, 10:21   #2 (permalink)
.::ZUBER::.'s Avatar
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
Bro.
You have Ticked Use New Protocol for RAP3GV3 in Nokia Tool Cofig. Setting.
So Untick last option as in Image below.
BR,
ZUBER
Old 10-06-2012, 17:17   #3 (permalink)
rahulgsm7's Avatar
Member: 1810350
Sonork: 8888888
Thanks Meter: 9
BR,
ZUBER your helpes are vary usefull from the many pepple
thanks BR, 10000000000000 times
Old 10-07-2012, 06:50   #4 (permalink)
6622622's Avatar
Member: 1562066
Sonork: 100.1622824
Thanks Meter: 555
always check all protocol before post but error same on 1 handset
Old 10-07-2012, 06:56   #5 (permalink)
6622622's Avatar
Member: 1562066
Sonork: 100.1622824
Thanks Meter: 555
use atf best bb5 inifinty ufs cyclone but no success i think chip is damage
Old 10-07-2012, 19:18   #6 (permalink)
sajohaker's Avatar
Member: 698071
Sonork: 100.1622915
Thanks Meter: 283
open phone and clean all ----camera and tray flash
Page generated in 0.18598 seconds with 8 queries
