08-02-2011, 22:18 | #1 (permalink) |
Freak Poster Join Date: Jan 2008 Location: Bangladesh
Member: 671937 Status: Offline Sonork: 100.1613181 Thanks Meter: 94 | Nokia 2700c SECURITY_TEST failed! (ANSWERED) SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 35********** can anyone plz give me solution.........?????????? |
08-03-2011, 01:56 | #3 (permalink) |
Freak Poster Join Date: Jul 2009 Location: Inside Softwa®e™
Member: 1084363 Status: Offline Thanks Meter: 109 | @ contract.., go to service PM tab.. tick load rfbb from server... tick PMM Auth....if phone sucessfully authorized.. then click write.. @ksvimal.., definitely you gave wrong solution... |
08-03-2011, 01:57 | #4 (permalink) |
Freak Poster Join Date: Dec 2006 Location: gsmworld of moderetso .
Member: 410890 Status: Offline Thanks Meter: 88 | just go to PM tab then click pmm auth or click sd auth then check load rf/bb from server to make it automatic upload the pm1 and pm309 or simply write new modified pm..your problem will be solved |
08-03-2011, 04:45 | #5 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | - SUPERDONGLE_KEY[MX] seems to be valid - is good. all you need is RFBB things. if you use 3.5rev1.2 with synced, you'll be done just 1 click after press 'repair SD' BR |
08-03-2011, 18:30 | #7 (permalink) |
No Life Poster Join Date: May 2010 Location: Incredible-India
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,297 | i have try all tricks but not solved in 2690 plz help me ppm not autho i am tried many time i do this here log- Phone Type: RM-635 (Nokia 2690) SW Version: V 10.10 22-04-10 RM-635 (c) Nokia Imei plain: 355*********** Product Code: 059C947 Battery voltage: 4752 mV, current: 57 mA Language Pack: - not available. Detected as PA_SL3 phone. - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 35*********** Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN Product: V 10.10 22-04-10 RM-635 (c) Nokia Using cached productData. PUBLIC ID: 17E0010E8E9303564578874BEFF2856FA748BD93 PRIVATE ID: BC6AC252BB6F487F9079CF9C7D5B72EA9ADC0F03 E-FUSE: 025B2301 SEC ROM CRC: 40830040 Calculating SUPERDONGLE using security server ... SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.7 Completed in 7.891 s RPL saved to "C:\mobileEx\3.5\data\backup\BB5_RM-635_35*********_SD.RPL" Updating SUPERDONGLE_KEY ...OK Scanning local SX4 Card ... No SX4 Card found. SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.7 Authenticating using [MX] security server ... Connecting to server[main.mxkey.biz] ...MXKEY SX4CARD - ID, hello 117.200.38.9 Bad phones ack, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request Retrying ... SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.7 Authenticating using [MX] security server ... Connecting to server[main.mxkey.biz] ...MXKEY SX4CARD - ID, hello 117.200.38.9 Bad phones ack, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request Retrying ... SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.7 Authenticating using [MX] security server ... Connecting to server[main.mxkey.biz] ...MXKEY SX4CARD - ID, hello 117.200.38.9 Bad phones ack, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request |
08-04-2011, 02:50 | #10 (permalink) |
Major Poster Join Date: Mar 2010 Location: Ukraine 06
Member: 1262043 Status: Offline Thanks Meter: 6 | don't work Scanning local SX4 Card ... No SX4 Card found. SERVER->Served by MXKEY - BLADE X at host3, agent version 1.1 revision 0.7 Authenticating using security server ... Connecting to server[main2.mxkey.biz] ...Bad phones ack, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request Retrying ... SERVER->Served by MXKEY - BLADE X at host3, agent version 1.1 revision 0.7 Authenticating using security server ... Connecting to server[main2.mxkey.biz] ...Bad phones ack, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request Retrying ... SERVER->Served by MXKEY - BLADE X at host3, agent version 1.1 revision 0.7 Authenticating using [MX] security server ... Connecting to server[main2.mxkey.biz] ...Bad phones ack, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request |
