Old 10-13-2012, 13:14   #1 (permalink)
Member: 154346
Thanks Meter: 32
nokia 303 flashing problem
hi i tried to flash with usb nokia 303 but phone now is dead .i tied
with dead usb but program show only error loader.problem isi not have
fbus cable ,is possible to repair with usb this problem.thanks
Old 10-13-2012, 14:14   #2 (permalink)
.::MASTER ALONE::.'s Avatar
Member: 1587480
Sonork: 100.1618317
Thanks Meter: 2,137
Recovered Fbus and log post here.
BR.
Arsalan gsm2000.
Old 10-13-2012, 14:14   #3 (permalink)
.::ZUBER::.'s Avatar
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,263
Yes,
It's possible,
Use Nokia USB Rom as Interface,
Flash as usual,
If Problem post Buscheck Logs for assistance.
BR,
ZUBER
Old 10-13-2012, 18:43   #4 (permalink)
Member: 154346
Thanks Meter: 32
MXKEY [MxKey Team HTI PLUS Flasher Interface 4], SN:
Using device: USB ROM and HTI, FW ver: 00.50, SN:
Connection status: EHCI:HUB::USB 2.00 (High-speed)
Driver: nmwcdnsuc, ver: 7.1.32.75
Module ver: 1.0.0.21200(18-07-2012), Library ver: 1.0.0.14205(18-07-2012)
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable, Battery back to device(make sure to have fully charged battery).
Insert Charger or Press phone's power button(if flashing doesnt start automatically)
Waiting for USB ROM device ...
Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 2BBF7AF8
CMT SYSTEM ASIC ID: 000000030000022600010007400C192103032108 [RAPUYAMA ver: 3.x]
CMT EM0 ID: 00001051
CMT EM1 ID: 00001060
CMT PUBLIC ID: 36690000FFFB3C40C4C0775F6FEFADB8EDF9463F
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: 3AB5DB70B45D23F1ADEEBB5734160706
CMT ROM ID: 2CAC45E23BC33C8B
Loading CMT secondary boot code
SecondaryBoot: RAPUv21_2nd.fg [BB5] version: 11.14.0 revision: 3.0 size: 0x3B40
Supported Ids: 0003192103002107, 000C192103002107, 0003192103012107, 000C192103012107, 000C192103022107, 0003192103022107, 400C192103022107, 4003192103022107, 000C192103032108, 0003192103032108, 400C192103032108, 4003192103032108, 0003192103042108, 000C192103042108
eBB5ProtocolType: NEW
Secondary boot loaded.
Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT
Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT
Storage2: 0020 0040 - 0000 0131 [ST NAND KAT00F00RA] type: FLASH,NOR, asic:CMT
Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 0020 0040 - 0000 0131 [ST NAND KAT00F00RA] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.6
Loading CMT update server data
Algorithm: RAPUv21_XSR17_alg.fg [XSR 1.6] version: 11.14.0 revision: 3.0 size: 0xC66F5
Update server code loaded.
ERROR: Loader not responding !
this is log from mxkey
Old 10-13-2012, 19:13   #5 (permalink)
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,263
Put Fully Charged Battery,
Try Changing different Flash Loader from Config.
BR,
ZUBER
Old 10-13-2012, 20:05   #6 (permalink)
Member: 154346
Thanks Meter: 32
i used diferent loader but same problem
Old 10-13-2012, 20:09   #7 (permalink)
market feedback's Avatar
Member: 1745022
Sonork: Save The Market
Thanks Meter: 40
what was the phone condition before?
maybe a hardware problem?
Old 10-13-2012, 20:15   #8 (permalink)
Member: 154346
Thanks Meter: 32
phone is new and i flashed for changing language.
now i flashed with cyclone box and phone show contact service
i have backup with mxkey but when try to flash with mxkey program show only
Old 10-13-2012, 20:23   #9 (permalink)
Member: 1745022
Thanks Meter: 40
well u can try to syncorise important files then try....
if not done, means maybe bug in mx side.
if problem not solved,u can copy the rpl file of this phone & copy into cyclone directory then repair it easily with cyclone;
Good luck
Old 10-21-2013, 04:06   #10 (permalink)
Member: 1444022
try to uninstall mxkey then install again,after installation syncronized files then try to flash
Page generated in 0.25892 seconds with 7 queries
