08-18-2013, 15:47 | #3 (permalink) |
Freak Poster Join Date: May 2009 Location: DHAKA GAZIPUR Age: 51
Member: 1033768 Status: Offline Sonork: sonork_id=100.1603335 Thanks Meter: 81 | MXKEY [FT SCR2000 0], SN: C08011F1 Using device: USB ROM Connection status: EHCI:HUB::USB 2.00 (High-speed) Driver: NMWCD, ver: 7.1.32.84 Module ver: 1.0.0.21719(09-05-2013), Library ver: 1.0.0.14397(09-05-2013) Processing MCU file: rm763__14.87.mcusw [BB5,XSR 1.6] size: 34.10 MB Supported Ids: 0003192103002107, 000C192103002107, 0003192103022107, 000C192103022107, 000C192103032108, 400C192103022107, 4003192103022107, 400C192103032108, 4003192103032108, 400C192103042108, 4003192103042108 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... CMT SYSTEM ASIC ID: 000000030000022600010007400C192103032108 [RAPUYAMA ver: 3.x] CMT EM0 ID: 00001051 CMT EM1 ID: 00001060 CMT PUBLIC ID: 32200004FFFB3C406C9DD2DEBA1D86269AFB488C CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 3AB5DB70B45D23F1ADEEBB5734160706 CMT ROM ID: 2CAC45E23BC33C8B Loading CMT secondary boot code SecondaryBoot: RAPUv21_2nd.fg [BB5] version: 11.14.0 revision: 3.0 size: 0x3B40 Supported Ids: 0003192103002107, 000C192103002107, 0003192103012107, 000C192103012107, 000C192103022107, 0003192103022107, 400C192103022107, 4003192103022107, 000C192103032108, 0003192103032108, 400C192103032108, 4003192103032108, 0003192103042108, 000C192103042108 eBB5ProtocolType: NEW Secondary boot loaded. Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0040 - 0000 0241 [Samsung 2Gb DDP OneNAND,2 Gbits] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Loading CMT update server data Algorithm: RAPUv21_XSR17_alg.fg [XSR 1.6] version: 11.14.0 revision: 3.0 size: 0xC66F5 Supported Ids: 0003192103002107, 000C192103002107, 0003192103012107, 000C192103012107, 000C192103022107, 0003192103022107, 400C192103022107, 4003192103022107, 000C192103032108, 0003192103032108, 400C192103032108, 4003192103032108, 0003192103042108, 000C192103042108 Update server code loaded. Waiting for USB device removal ...OK Waiting for USB device arrival ...OK Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 2439CE5C FUR: Adding Asic CMT as client OK. Reading CMT NPC (0x190 bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x160 bytes). Reading CMT HWC (0xD4 bytes). Reading CMT R&D (0x0 bytes). Reading CMT MDM_KEYS (0x0 bytes). Reading CMT PARTNERC (0x0 bytes). RPL(CERT) backup already exist (C:\mobileEx\3.5\data\backup\BB5_35827904362846_CE RT.rpl). CMT PAPUBKEYS HASH: ACE39760399CD7A3FE439DCC52111C24D435D533 Storing certificate [NPC, CCC, HWC, R&D] ...OK Partitioning.... Partitioning complete Erase size: 50.81 MB CMT FLASH,MuxOneNAND area [00040000-000403FF] CMT FLASH,MuxOneNAND area [000C0000-0013FFFF] CMT FLASH,MuxOneNAND area [00140000-004BFFFF] CMT FLASH,MuxOneNAND area [004C0000-0073FFFF] CMT FLASH,MuxOneNAND area [00740000-0147FFFF] CMT FLASH,MuxOneNAND area [00160000-0017FFFF] CMT FLASH,MuxOneNAND area [03300000-0397FFFF] CMT FLASH,MuxOneNAND area [0F080000-0F67FFFF] CMT FLASH,MuxOneNAND area [01480000-0253FFFF] CMT FLASH,MuxOneNAND area [02540000-026BFFFF] Formating partition ... Flash programming ... CMT KEYS block sent CMT PAPUBKEYS: ACE39760 [] sent CMT DSP0 block sent CMT MCUSW block sent CMT MCUSW1 block sent CMT GENIO_INIT block sent CMT ISA+DYNSW block sent CMT ADA block sent CMT PRIMAPP block sent CMT PASUBTOC block sent CMT RAP3NAND block sent CMT UPDAPP block sent CMT ISA+EXTDRV block sent Programming completed in 7.250 s Processing PPM file: rm763__14.87.ppm_mec [BB5,XSR 1.6] size: 8.04 MB Supported Ids: 0003192103002107, 000C192103002107, 0003192103022107, 000C192103022107, 000C192103032108, 400C192103022107, 4003192103022107, 400C192103032108, 4003192103032108, 400C192103042108, 4003192103042108 Erase size: 12.25 MB CMT FLASH,MuxOneNAND area [026C0000-032FFFFF] Flash programming ... Programming completed in 1.703 s Processing CNT file: rm763__14.87.image_mec_059J327 [BB5,XSR 1.6] size: 46.28 MB Supported Ids: 0003192103002107, 000C192103002107, 0003192103022107, 000C192103022107, 000C192103032108, 400C192103022107, 4003192103022107, 400C192103032108, 4003192103032108, 400C192103042108, 4003192103042108 Erase size: 183.06 MB CMT FLASH,MuxOneNAND area [03980000-0F07FFFF] Formating partition ... Flash programming ... Programming completed in 8.343 s Total time for flashing process(boot+erase+write) was 27.516 s Waiting for USB device removal ...OK Waiting for USB device arrival ...OK Waiting for device boot up ... Device connected: nmwcdc\Nokia Asha 303 USB Phonet, PORT_ID: 358279043628468 Verifying communication to device OK. Phone type: RM-763 (Nokia 303) SW version: V 14.87 17-10-12 RM-763 (c) Nokia Imei plain: 35827904362846-8 Product code: 059J1H7 Battery voltage: 3939 mV, current: 199 mA Language Pack: - not available. SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! Camera config: 0C219802004005, ver: SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 358279043628468 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN FULL FACTORY... OK USER DATA... OK LEAVE FACTORY... OK SERVICE CENTER... OK SOFTWARE UPGRADE... OK PRODUCTION TUNING... OK Reset User Code (to default:12345) ... OK Completed in 2.266 s |
08-18-2013, 15:49 | #4 (permalink) |
Member: 1033768 Status: Offline Sonork: sonork_id=100.1603335 Thanks Meter: 81 | MXKEY [FT SCR2000 0], SN: C08011F1 Using device: USB Phonet Connection status: EHCI:HUB:USB 2.00 (High-speed) Driver: nmwcdc, ver: 7.1.32.84 Module ver: 1.0.0.21719(09-05-2013), Library ver: 1.0.0.14397(09-05-2013) Battery voltage: 3945 mV Waiting for USB device removal ... CMT SYSTEM ASIC ID: 000000030000022600010007400C192103032108 [RAPUYAMA ver: 3.x] CMT EM0 ID: 00001051 CMT EM1 ID: 00001060 CMT PUBLIC ID: 32200004FFFB3C406C9DD2DEBA1D86269AFB488C CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 3AB5DB70B45D23F1ADEEBB5734160706 CMT ROM ID: 2CAC45E23BC33C8B Loading CMT secondary boot code SecondaryBoot: RAPUv21_2nd.fg [BB5] version: 11.14.0 revision: 3.0 size: 0x3B40 Supported Ids: 0003192103002107, 000C192103002107, 0003192103012107, 000C192103012107, 000C192103022107, 0003192103022107, 400C192103022107, 4003192103022107, 000C192103032108, 0003192103032108, 400C192103032108, 4003192103032108, 0003192103042108, 000C192103042108 eBB5ProtocolType: NEW Secondary boot loaded. Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0040 - 0000 0241 [Samsung 2Gb DDP OneNAND,2 Gbits] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Loading CMT update server data Algorithm: RAPUv21_XSR17_alg.fg [XSR 1.6] version: 11.14.0 revision: 3.0 size: 0xC66F5 Supported Ids: 0003192103002107, 000C192103002107, 0003192103012107, 000C192103012107, 000C192103022107, 0003192103022107, 400C192103022107, 4003192103022107, 000C192103032108, 0003192103032108, 400C192103032108, 4003192103032108, 0003192103042108, 000C192103042108 Update server code loaded. Waiting for USB device removal ...OK Waiting for USB device arrival ...OK Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 2439CE5C FUR: Adding Asic CMT as client OK. CMT PAPUBKEYS HASH: ACE39760399CD7A3FE439DCC52111C24D435D533 Selected firmware certificate matched. Original Imei: 35827904362846 Original Product code: 059J1H7 Bluetooth ID: 6CE9075D56D6 SIMLOCK PA identifier: [0] PA_SIMLOC30 Reading CMT NPC (0x190 bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x160 bytes). Reading CMT HWC (0xD4 bytes). Reading CMT R&D (0x0 bytes). Reading CMT MDM_KEYS (0x0 bytes). Reading CMT PARTNERC (0x0 bytes). Waiting for USB device removal ... Waiting for device boot up ... Device connected: nmwcdc\Nokia Asha 303 USB Phonet, PORT_ID: 358279043628468 Verifying communication to device OK. Phone type: RM-763 (Nokia 303) SW version: V 14.87 17-10-12 RM-763 (c) Nokia Imei plain: 35827904362846-8 Product code: 059J1H7 Battery voltage: 3934 mV, current: 200 mA Language Pack: - not available. SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! Camera config: 0C219802004005, ver: |
08-18-2013, 18:15 | #9 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Bro. It's Hardware & Software seems to be OK, So please check Phone for Waterlogg or check Sim Ways. BR, ZUBER |
