Old 11-05-2010, 08:42   #1 (permalink)
shabir97's Avatar
Member: 1277468
Sonork: 100.1603661
Thanks Meter: 701
Nokia 1616 imei ?????????????1...plz help me mxkey team................
i have nokia 1616 imei is ?????????????1
i try to mxkey but no RPL replay ..
I need any sulation this problum...
Here is bus check logo:.
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: ?????0(18-10-2010),???????(18-10-2010)
Device synchronized.
CPU ID: A200341100 [X-GOLD 110]
Sending Primary Boot Loader ...OK
Changing baudrate to: 921600
Sending Secondary Boot Loader ...OK
BootloaderString: SE0_091125 F11
Boot mode: CC
EBL version: 10.13, Default_RAM_Bootloader
Flash ID: 00EC 2254 [Samsung K8S6415ETC,64 Mbits]
Phone Type: RH-125
SW Version: V 04.65 24-04-10 RH-125 (c) Nokia
Imei plain: ????????000000-0
Product Code: 0588617
Cellular System: GSM
ASIC ID: 0x2292, type: 11
Ppm Id: IA
Language Pack:
- not available.
Imei plain is invalid !!!
Imei net: 00000000000000
Version:
Counter: 0/3, 0/10
CONFIG_DATA: 0000000000000000
PROFILE_BITS: 0000000000030000
SIMLOCK_DATA corrupted!
Old 11-05-2010, 08:44   #2 (permalink)
Member: 1434798
Thanks Meter: 3
some times it is hardware problem try to check if the set is water damage
Old 11-05-2010, 08:48   #3 (permalink)
shabir97's Avatar
Member: 1277468
Sonork: 100.1603661
Thanks Meter: 701
yes this is water dameg set is ok for same days working is ok but after same days ago face this problum
any idia for this sulation
Old 11-05-2010, 08:52   #4 (permalink)
sahilfency's Avatar
Member: 1212231
Sonork: 100.1611130
Thanks Meter: 164
if u can change uem
so solve it
Old 11-05-2010, 09:29   #5 (permalink)
Member: 1434798
Thanks Meter: 3
yes it will be better to change uem
DES key Driver black Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 02-08-2014 04:50
8810 mbus-cable zfrank Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 05-19-1999 13:12
Page generated in 0.16468 seconds with 9 queries
