12-16-2012, 09:32 | #1 (permalink) |
No Life Poster Join Date: Jul 2007 Location: india Age: 48
Member: 549926 Status: Offline Thanks Meter: 118 | Nokia 3110c Contact service ..SECURITY_TEST failed! SW version: V 07.30 07-05-09 RM-237 (c) Nokia. Imei plain: 35685202------- Product code: 0514950 Battery voltage: 4933 mV, current: 61 mA Language Pack: - not available. SLPA ver[1]: PA_SL (15 digit NCK) SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 3568520-------- Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN |
12-16-2012, 09:57 | #4 (permalink) |
No Life Poster Join Date: Nov 2008 Location: GSM WORLD
Member: 898387 Status: Offline Sonork: 1000.2 Thanks Meter: 103 | Backup Just NPC Data rpl (only npc data) Or recover cert with HWK. 2.Full erase With erase file (BB5Erase_8MBrap)with hwk after erase full flash and ui setting then 3.write backup Just Npc Data Rpl Not hwc ccc data just NPC data. 4.Then repair sd and simlock 5.Then write full pm with pmauth ur problem solve i teset this many time with security test fail problem when its not done with any thing or 1. first backup rpl ( go > imei and security tab > imei rebuild > backup rpl) 2. erase old pm ( go > pm tab > erase ) 3. Reset npc data ( go> imei and security tab> reset NPC data)( must backup rpl before do this) 4. Erase pm again (go > pm tab > erase ) 5.Write rpl from backup ( go > imei and security tab > imei rebuild > restore imei) 6. go pm tab > super sd auth or pmm auth > than write good or modified pm ( must need pm 1 & 309) 7. erase pm again 8. Recover CERT ( go>imei and security tab> imei rebuild > recover cert) |
12-16-2012, 11:23 | #5 (permalink) | ||
Product Supporter Join Date: Feb 2010 Location: .::INDIA::.
Member: 1236722 Status: Offline Sonork: 100.1601546 Thanks Meter: 4,180 | Quote:
Follow this method otherwise Contact me On Yh or Sonork Quote:
