05-12-2010, 21:10 | #1 (permalink) |
Insane Poster Join Date: Dec 2009 Location: in my dreamhouse
Member: 1177366 Status: Offline Sonork: 9495 Thanks Meter: 14 | nokia-3110c flashing error by mx-key Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010) Processing file: rm237__07.30.mcusw as MCU [BB5,BB5 ALGORITHM] size: 14.49 MB Supported RAP Ids: 0103192101001101, 010C192101001101 RAP Data : SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] EM0 ID: 00000232 EM1 ID: 00000353 PUBLIC ID: 0FF0000C67937C56B68E871D6023698BE7EBAA80 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8981 - 0000 0000 [Intel NU48F256,256 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS is blank/erased. Storing certificate ...OK Erase size: 16.37 MB CMT NOR area [00000000-000006BF] erased in 0.796 s CMT NOR area [000006C0-0001FFFF] erased in 0.157 s CMT NOR area [00020000-0007FFFF] erased in 1.000 s CMT NOR area [00080000-000DFFFF] erased in 0.188 s CMT NOR area [00100000-001FFFFF] erased in 0.313 s CMT NOR area [00200000-0031FFFF] erased in 0.375 s CMT NOR area [00320000-0105FFFF] erased in 3.141 s CMT NOR area [01060000-01067FFF] erased in 0.187 s CMT NOR area [01068000-0107FFFF] erased in 0.188 s Flash programming ... Error while programming [00] at 0xFFFFFFFF, Result: 0000 Please try to use newer flashloader. Flashing terminated with error(s) in 43.235 s RX Buffer: F372 how can i solve this problem? any body solution this problem? |
The Following User Says Thank You to systel For This Useful Post: |
05-12-2010, 22:10 | #3 (permalink) | |
Freak Poster Join Date: Aug 2005 Location: india. Age: 52
Member: 173509 Status: Offline Sonork: 100.1584320 Thanks Meter: 96 | Quote:
simply it is hardware problem,post selftest result if u get.or first backup rpl and pm.after it erase whole flash and flash with higher version.post result. ::regards===shabbir husain:::::::::: | |
05-13-2010, 00:20 | #4 (permalink) |
Crazy Poster Join Date: Jul 2006 Location: rodeiguez rizal
Member: 318105 Status: Offline Thanks Meter: 7 | try to flash the phone with usb thats the biggest problem on f bus flashing on mxkey but anyway i usually flash it on usb and i get good results just try it |
05-14-2010, 08:23 | #9 (permalink) |
Member: 1177366 Status: Offline Sonork: 9495 Thanks Meter: 14 | 3110c Are donr by mx-key...... Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010) Processing file: rm237__07.30.mcusw as MCU [BB5,BB5 ALGORITHM] size: 14.49 MB Supported RAP Ids: 0103192101001101, 010C192101001101 RAP Data : SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] EM0 ID: 00000232 EM1 ID: 00000353 PUBLIC ID: 0FF0000C67937C56B68E871D6023698BE7EBAA80 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8981 - 0000 0000 [Intel NU48F256,256 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS is blank/erased. Storing certificate ...OK Erase size: 16.37 MB CMT NOR area [00000000-000006BF] erased in 0.796 s CMT NOR area [000006C0-0001FFFF] erased in 0.157 s CMT NOR area [00020000-0007FFFF] erased in 1.000 s CMT NOR area [00080000-000DFFFF] erased in 0.188 s CMT NOR area [00100000-001FFFFF] erased in 0.313 s CMT NOR area [00200000-0031FFFF] erased in 0.375 s CMT NOR area [00320000-0105FFFF] erased in 3.141 s CMT NOR area [01060000-01067FFF] erased in 0.187 s CMT NOR area [01068000-0107FFFF] erased in 0.188 s Flash programming ... Error while programming [00] at 0xFFFFFFFF, Result: 0000 Please try to use newer flashloader. Flashing terminated with error(s) in 43.235 s RX Buffer: F372 When i try to fast flash then set is compleetly ok..... thank's *** & thaanks for all mx-key user which suggest me when i confused.....thanks all.... |
10-05-2010, 13:51 | #11 (permalink) |
Junior Member Join Date: Sep 2010
Member: 1405722 Status: Offline Thanks Meter: 1 | Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8955(29-09-2010), 1.0.0.14639(29-09-2010) RAP Data : SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] EM0 ID: 00000232 EM1 ID: 00000353 PUBLIC ID: 03400104F4ED7E56AF0D3AD4FC299D7E048F026D ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8981 - 0000 0000 [Intel NU48F256,256 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS is blank/erased. TransmissionMode: DDR&TX2 Processing file: rm237__07.21.mcusw as MCU [BB5,BB5 ALGORITHM] size: 14.48 MB Supported RAP Ids: 0103192101001101, 010C192101001101 Storing certificate [NPC, VARIANT, R&D] ...OK Erase size: 16.37 MB CMT NOR area [00000000-000006BF] CMT NOR area [000006C0-0001FFFF] CMT NOR area [00020000-0007FFFF] CMT NOR area [00080000-000DFFFF] CMT NOR area [00100000-001FFFFF] CMT NOR area [00200000-0031FFFF] CMT NOR area [00320000-0105FFFF] CMT NOR area [01060000-01067FFF] CMT NOR area [01068000-0107FFFF] erased in 5.516 s Flash programming ... Error while programming [00] at 0xFFFFFFFF, Result: 0000 Please try to use newer flashloader. Flashing terminated with error(s) in 18.453 s RX Buffer: B372 I will try all above solution but problem is still the same.. Once i can backup rpl and full erase it with mxkey and tick the fast flash option, flashing is complete and IMEI is 123... when i try to restore imei from backup then again phone did not do any response. I remove it from F-Bus cable and switch on the phone Nokia coming and began to blink phone... i just tired soo plzzzzzzzzz help me... and give me right solution... plzzzzzzzz |
12-26-2010, 05:59 | #12 (permalink) | |
Freak Poster Join Date: Aug 2005 Age: 39
Member: 170684 Status: Offline Thanks Meter: 19 | 3110c flashing error tested 100% Quote:
Using device: POTATO BOX, FW ver: 01.B4 Library version: 1.0.0.9100(23-12-2010), 1.0.0.15151(24-12-2010) Processing MCU file: rm237__07.21.mcusw [BB5,BB5 ALGORITHM] size: 14.48 MB Supported Ids: 0103192101001101, 010C192101001101 CMT Data : SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] EM0 ID: 00000232 EM1 ID: 00000353 PUBLIC ID: 11900203DBAD7C56CA0626C611CA7D17A19DD8B9 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8981 - 0000 0000 [Intel NU48F256,256 Mbits] type: NOR,CMT ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS is blank/erased. TransmissionMode: DDR&TX2 Storing certificate [NPC, VARIANT, R&D] ...OK Erase size: 16.37 MB CMT NOR area [00000000-000006BF] CMT NOR area [000006C0-0001FFFF] CMT NOR area [00020000-0007FFFF] CMT NOR area [00080000-000DFFFF] CMT NOR area [00100000-001FFFFF] CMT NOR area [00200000-0031FFFF] CMT NOR area [00320000-0105FFFF] CMT NOR area [01060000-01067FFF] CMT NOR area [01068000-0107FFFF] erased in 5.640 s Flash programming ... CMT PAPUBKEYS: C0E691EA16A7593A9BB28832D7312A39F7ED668D (RAP Certificate 66 v2) written. Programming completed in 2 min 24.875 s Processing PPM file: rm237__07.21.ppm_mr [BB5,BB5 ALGORITHM] size: 3.55 MB Supported Ids: 0103192101001101, 010C192101001101 CMT Data : SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] EM0 ID: 00000232 EM1 ID: 00000353 PUBLIC ID: 11900203DBAD7C56CA0626C611CA7D17A19DD8B9 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8981 - 0000 0000 [Intel NU48F256,256 Mbits] type: NOR,CMT ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: C0E691EA16A7593A9BB28832D7312A39F7ED668D TransmissionMode: DDR&TX2 Erase size: 4.62 MB CMT NOR area [01080000-0151FFFF] erased in 21.625 s Flash programming ... Programming completed in 34.219 s Processing CNT file: rm237__07.21.image_ctv_india_mr [BB5,BB5 ALGORITHM] page size: 64 K size: 4.00 MB Supported Ids: 0103192101001101, 010C192101001101 NOR page size in the phone is 128 K. CMT Data : SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] EM0 ID: 00000232 EM1 ID: 00000353 PUBLIC ID: 11900203DBAD7C56CA0626C611CA7D17A19DD8B9 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8981 - 0000 0000 [Intel NU48F256,256 Mbits] type: NOR,CMT ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: C0E691EA16A7593A9BB28832D7312A39F7ED668D TransmissionMode: DDR&TX2 Erase size: 10.75 MB CMT NOR area [01520000-01FDFFFF] erased in 51.172 s Converting UCP blocks to 128 K. Flash programming ... Programming completed in 39.078 s Total time for flashing process(boot+erase+write) was 5 min 36.312 s Flashing completed in 5 min 36.343 s Phone Type: RM-237 (Nokia 3110c) SW Version: V 07.21 05-11-08 RM-237 (c) Nokia. Imei plain: 356833XXXXXXX Product Code: 0550573 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 356833XXXXXXX Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF | |
DES key Driver | black | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 02-08-2014 04:50 |
