03-11-2010, 18:43 | #1 (permalink) |
No Life Poster Join Date: Jan 2005 Age: 54
Member: 105625 Status: Offline Thanks Meter: 44 | Nokia 3110C flashing problem Cable is 100% working - tested with both normal FBUS and Universal FBUS cable. Code: Using device: J.A.F, FW ver: 01.B0 Library version: 1.0.0.7687(12-02-2010), 1.0.0.12095(13-02-2010) Processing file: rm237__07.21.mcusw as MCU [BB5,BB5 ALGORITHM] size: 14.48 MB Supported RAP Ids: 0103192101001101, 010C192101001101 RAP Data : SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] EM0 ID: 00000232 EM1 ID: 00000353 PUBLIC ID: 23C0000DFC016D564E11F4CC68D31C02A9B19EF9 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0020 881C - 0000 6A21 [ST M58LR256JU,256 Mbits] type: NOR,RAP ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS is blank/erased. Storing certificate ...OK Total erase size: 16.37 MB CMT NOR area [00000000-000006BF] CMT NOR area [000006C0-0001FFFF] CMT NOR area [00020000-0007FFFF] CMT NOR area [00080000-000DFFFF] CMT NOR area [00100000-001FFFFF] CMT NOR area [00200000-0031FFFF] CMT NOR area [00320000-0105FFFF] CMT NOR area [01060000-01067FFF] CMT NOR area [01068000-0107FFFF] erased in 3.875 s Flash programming ... Error chk C7012D0103CD RX2 not responding, please check BSI/cable/pinout ! Error while programming [00] at 0x00020000, Result: 0000 Please try to use newer flashloader. Flashing terminated with error(s) in 9.875 s RX Buffer: C7012D0103CD00 |
03-11-2010, 19:21 | #5 (permalink) |
Member: 105625 Status: Offline Thanks Meter: 44 | Dead USB: Not working... Nothing happens when i connect turned off phone to USB. JAF: Flashing completes without error (until after flash procedures/factory reset), but phone still dead. MT-Box: Flashing works, but content extract fails. Phone still dead. But i tried downgrading to initial firmware (4.90) and even though content extract failed, i could turn the phone on and LCD lights up with Nokia logo, but then turns off. I assume that's because it was downgraded. Of course, i can't enable downgrade, because local mode is not working... And upgrading to 7.20 doesn't work either, so i'm kinda stuck.... :-/ Yes, also tried to enable RX, but same/similar error. |
03-11-2010, 19:28 | #6 (permalink) | |
No Life Poster Join Date: Feb 2006 Location: syria Age: 46
Member: 231153 Status: Offline Thanks Meter: 313 | Quote:
Nokia 3110c Flashing Problem...... | Saleemsmj | Nokia Hardware & Hardware Repair | 4 | 12-21-2009 15:06 |
Nokia 3110C Flashing Problem...Pls. Pls. Help.. | amit123 | Nokia Hardware & Hardware Repair | 10 | 05-07-2009 16:13 |
Nokia 3110c flash problem | wase | Universalbox | 10 | 04-14-2009 20:56 |
nokia 3110c unlock problem!!!!! | gsmcity66 | BB5 Box by D.K. | 22 | 02-20-2008 22:37 |
