Old 02-19-2011, 16:39   #1 (permalink)
nura1335's Avatar
Member: 481744
Thanks Meter: 30
Nokia 3110c flashing problem MX key 3.4 v1.7 (ANSWERED)
What is My Problem?
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.9100(23-12-2010), 1.0.0.15151(24-12-2010)
Processing MCU file: rm237__06.02.mcusw
[BB5,BB5 ALGORITHM] size: 14.46 MB
Supported Ids: 0103192101001101, 010C192101001101
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1]
EM0 ID: 00000232
EM1 ID: 00000353
PUBLIC ID: 07000205E77D7E5658C690DA0BE41AD262727166
ASIC MODE ID: 00
ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
ROM ID: 191EC665DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 10.6.0 revision: 0.0 size: 0x3C40
Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0089 8981 - 0000 6A21 [Intel NU48F256,256 Mbits] type: NOR,CMT
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
TransmissionMode: 16Bit
Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 10.28.0 revision: 0.0 size: 0x23220
Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
CMT PAPUBKEYS HASH: C0E691EA16A7593A9BB28832D7312A39F7ED668D
TransmissionMode: DDR&TX2
Storing certificate [NPC, VARIANT, R&D] ...OK
Erase size: 16.37 MB
CMT NOR area [00000000-000006BF] erased in 0.797 s
CMT NOR area [000006C0-0001FFFF] erased in 0.218 s
CMT NOR area [00020000-0007FFFF] erased in 2.469 s
CMT NOR area [00080000-000DFFFF] erased in 0.140 s
CMT NOR area [00100000-001FFFFF] erased in 0.203 s
CMT NOR area [00200000-0031FFFF] erased in 6.765 s
CMT NOR area [00320000-0105FFFF] erased in 1 min 16.188 s
CMT NOR area [01060000-01067FFF] erased in 0.828 s
CMT NOR area [01068000-0107FFFF] erased in 0.172 s
Flash programming ...
Error while programming [00] at 0x00020000, Result: 0000
Please try to use newer flashloader.
Flashing terminated with error(s) in 2 min 1.313 s
RX Buffer: B372
Old 02-19-2011, 16:46   #2 (permalink)
ABDUL RAJA's Avatar
Member: 665989
Sonork: 100.1597348
Thanks Meter: 552
Skip erase and then try.
Old 02-19-2011, 19:25   #3 (permalink)
Moderator
.:SARCAR:.'s Avatar
Member: 322206
Sonork: 100.1594813/.:SARCAR:.
Thanks Meter: 1,350
first of all use latest version of flash file . change with a good working cable then check.
post result
Old 02-19-2011, 22:11   #4 (permalink)
rahul_rocks3's Avatar
Member: 1312746
Thanks Meter: 766
brother first downloda 7.30 version then flash your handset via USB then reflash it normally like you are doing now....your problem will be 100% resolved....this is tested by me
Old 02-19-2011, 22:12   #5 (permalink)
Member: 1312746
Thanks Meter: 766
Originally Posted by nura1335 View Post
What is My Problem?
CMT Data :
EM0 ID: 00000232
EM1 ID: 00000353
ASIC MODE ID: 00
RX Buffer: B372
Old 02-20-2011, 01:50   #6 (permalink)
sunny box's Avatar
Member: 1456392
Sonork: 100.1606104
Thanks Meter: 115
use another version bro like 7.30...
Old 02-20-2011, 23:31   #7 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
use another flash loader, the older one. set it from config menu.
Old 06-16-2011, 11:07   #8 (permalink)
Member: 1280620
Sonork: Mobile
Thanks Meter: 6
Is there any other newer version Flash Loader mobileEx\3.4\modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\11.10.000.2\
DES key Driver black Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 02-08-2014 04:50
Page generated in 0.22666 seconds with 9 queries
