04-16-2012, 09:23 | #1 (permalink) |
No Life Poster Join Date: Feb 2012 Location: india (rajasthan) Age: 32
Member: 1719279 Status: Offline Thanks Meter: 140 | nokia 3110c gallery problam CMT ALG Boot OK IMAGE : rm237__07.30.mcusw CMT NOR Erase Area: 0x00000000-000006BF CMT NOR Erase Area: 0x000006C0-0001FFFF CMT NOR Erase Area: 0x00020000-0007FFFF CMT NOR Erase Area: 0x00080000-000DFFFF CMT NOR Erase Area: 0x00100000-001FFFFF CMT NOR Erase Area: 0x00200000-0031FFFF CMT NOR Erase Area: 0x00320000-0105FFFF CMT NOR Erase Area: 0x01060000-01067FFF CMT NOR Erase Area: 0x01068000-0107FFFF CMT FLASH ERASE OK, Time: 01:33 CERT_BLK_ERROR at: 0xFFFFFFFF, 00 ERR: CMT FLASH WRITE C_BLK 000000000000000910000000B172, LN: 0x000600, Time: 00:05 Process Failed, Repowering Mobile AND WHEN I FLASH WITH MX BOX THEN FLASH COMPLEATE NUT GALLERY NOT COMPLEATE I USE VERSION 7.30 PLEASE TELL ME HOW TO SOLVE PROBLAM MX BOX SUCESSFUL FLASH LOGS HERE Phone type: RM-237 (Nokia 3110c) SW version: V 07.30 07-05-09 RM-237 (c) Nokia. Imei plain: 35322503141754-2 Product code: 0581437 Battery voltage: 4777 mV, current: 90 mA Language Pack: - not available. SLPA ver[1]: PA_SL (15 digit NCK) SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 353225031417542 Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN HOW TO SOLVE IT PROBLAM?? HOW TO COMPLETE GALLERY ??? |
04-16-2012, 10:39 | #3 (permalink) |
Member: 1719279 Status: Offline Thanks Meter: 140 | self test logs here Phone Type: RM-237 SW version: V 07.30 07-05-09 RM-237 (c) Nokia. ID Test name Startup Result 3 EAR_DATA_LOOP Y passed 12 SIM_CLK_LOOP Y passed 13 SIM_IO_CTRL_LOOP Y passed 15 SLEEP_X_LOOP Y passed 46 UEM_CBUS_IF Y passed 7 KEYBOARD_STUCK N passed 22 CAMERA_IF N passed 20 BACKUP_BATT N passed 21 LPRF_IF N !NOT EXECUTED(03) 44 LPRF_AUDIO_LINES N !NOT EXECUTED(03) 2 CURRENT_CONS N !NOT EXECUTED(03) 42 RADIO Y PASSED(00) 69 BACKLIGHT Y PASSED(00) 33 SIM_LOCK N PASSED(00) 93 SECURITY N PASSED(00) 71 BT_WAKEUP N !NOT EXECUTED(03) 99 IRDA_LED_STRESS N !NOT EXECUTED(03) 96 HOOKINT N !NOT EXECUTED(03) 88 TAHVOINT Y PASSED(00) 56 SLEEPCLK_FREQ N !NOT EXECUTED(03) 101 BTEMP N !NOT EXECUTED(03) 107 BT_SLEEP_CLK N !NOT EXECUTED(03) 108 EXT_DEVICE N !NOT EXECUTED(03) 86 CDSP_RF_BB_IF N !NOT EXECUTED(03) 83 CDSP_RF_SUPPLY N !NOT EXECUTED(03) 85 CDSP_TX_IQ N !NOT EXECUTED(03) 74 CDSP_TXC_DATA N !NOT EXECUTED(03) 79 CDSP_RX_PLL_PHASE_LOCK N !NOT EXECUTED(03) 80 CDSP_TX_PLL_PHASE_LOCK N !NOT EXECUTED(03) 81 CDSP_RX_IQ_LOOP_BACK N !NOT EXECUTED(03) 77 CDSP_GSM_TX_POWER N !NOT EXECUTED(03) |
04-16-2012, 10:44 | #5 (permalink) |
Member: 1719279 Status: Offline Thanks Meter: 140 | brother i select run all after here attach self test logs Phone Type: RM-237 SW version: V 07.30 07-05-09 RM-237 (c) Nokia. ID Test name Startup Result 3 EAR_DATA_LOOP Y passed 12 SIM_CLK_LOOP Y passed 13 SIM_IO_CTRL_LOOP Y passed 15 SLEEP_X_LOOP Y passed 46 UEM_CBUS_IF Y passed 7 KEYBOARD_STUCK N passed 22 CAMERA_IF N passed 20 BACKUP_BATT N passed 21 LPRF_IF N !NOT EXECUTED(03) 44 LPRF_AUDIO_LINES N !NOT EXECUTED(03) 2 CURRENT_CONS N !NOT EXECUTED(03) 42 RADIO Y PASSED(00) 69 BACKLIGHT Y PASSED(00) 33 SIM_LOCK N PASSED(00) 93 SECURITY N PASSED(00) 71 BT_WAKEUP N !NOT EXECUTED(03) 99 IRDA_LED_STRESS N !NOT EXECUTED(03) 96 HOOKINT N !NOT EXECUTED(03) 88 TAHVOINT Y PASSED(00) 56 SLEEPCLK_FREQ N !NOT EXECUTED(03) 101 BTEMP N !NOT EXECUTED(03) 107 BT_SLEEP_CLK N !NOT EXECUTED(03) 108 EXT_DEVICE N !NOT EXECUTED(03) 86 CDSP_RF_BB_IF N !NOT EXECUTED(03) 83 CDSP_RF_SUPPLY N !NOT EXECUTED(03) 85 CDSP_TX_IQ N !NOT EXECUTED(03) 74 CDSP_TXC_DATA N !NOT EXECUTED(03) 79 CDSP_RX_PLL_PHASE_LOCK N !NOT EXECUTED(03) 80 CDSP_TX_PLL_PHASE_LOCK N !NOT EXECUTED(03) 81 CDSP_RX_IQ_LOOP_BACK N !NOT EXECUTED(03) 77 CDSP_GSM_TX_POWER N !NOT EXECUTED(03) |
04-16-2012, 10:49 | #6 (permalink) | |
Banned Join Date: Jul 2011 Age: 32
Member: 1609044 Status: Offline Thanks Meter: 892 | Quote:
04-16-2012, 10:52 | #7 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | bro. it's RAP ic problem, so clean PCB for water log or reflow RAP & again flash it with v7.30, post result if not solve. |
04-16-2012, 11:01 | #8 (permalink) | |
No Life Poster Join Date: Sep 2007 Location: I donot know what is the best Age: 51
Member: 581626 Status: Offline Thanks Meter: 184 | Quote:
all will be ok | |
04-16-2012, 11:30 | #10 (permalink) |
Member: 1719279 Status: Offline Thanks Meter: 140 | my probalm is ok when i fllash with usb with mt box then my set ok.....logs here CONNECT PHONE to USB and Power ON phone! Pooling for phone... \\?\nmwcd#vid_0421&pid_0106&if_oth#6&472eea3&0&00# {4f919102-4adf-11d5-882d-00b0d02fe381} FAILED TO BOOT PHONE!!! Make sure that phone is connected. Using Tx2 Data line. BB5 PM back Phone is in: Phone is not responding! Processing File: rm237__07.30.mcusw Boot... CONNECT PHONE to USB and Power ON phone! Pooling for phone... \\?\nmwcd#vid_0421&pid_0106&if_oth#6&472eea3&0&00# {4f919102-4adf-11d5-882d-00b0d02fe381} Sending ULO code Sending UPDAPP code Sending PASUBTOC code Pooling for device removal... Device removed Pooling for ADL device... \\?\nmwcd#vid_0421&pid_0105&if_oth#6&fedfd1d&0&00# {4f919102-4adf-11d5-882d-00b0d02fe381} CMT Certificates NOT SUPPORTED Erase[31.75 MB]... erasing RAP [00000000 to 000006BF] erasing RAP [000006C0 to 0001FFFF] erasing RAP [00020000 to 0007FFFF] erasing RAP [00080000 to 000DFFFF] erasing RAP [00100000 to 001FFFFF] erasing RAP [00200000 to 0031FFFF] erasing RAP [00320000 to 0105FFFF] erasing RAP [01060000 to 01067FFF] erasing RAP [01068000 to 0107FFFF] erasing RAP [01520000 to 01FDFFFF] erasing RAP [01080000 to 0151FFFF] in 229.88s Flash[14.49 MB]...in 45.56s * * Processed file in 292.98 seconds Processing File: rm237__07.30.image_c_tr Boot... Pooling for ADL device... \\?\nmwcd#vid_0421&pid_0105&if_oth#6&fedfd1d&0&00# {4f919102-4adf-11d5-882d-00b0d02fe381} Erase[0.00 MB]... in 0.06s Flash[3.69 MB]...Content page size is 128K in 11.80s * * Processed file in 11.95 seconds Processing File: rm237__07.30.ppm_c Boot... Pooling for ADL device... \\?\nmwcd#vid_0421&pid_0105&if_oth#6&fedfd1d&0&00# {4f919102-4adf-11d5-882d-00b0d02fe381} Erase[0.00 MB]... in 0.06s Flash[3.75 MB]...in 11.80s * * Processed file in 11.94 seconds Restarting device... Pooling for device removal... Device disconnected. * * * Phone flashing done in 5:23 minutes Post Flash serial tunning of phone.... Pooling mode for full factory set... V 07.30/07-05-09/RM-237 (c) Nokia. IMEI: 353225031417542 Factory Default Settings...OK Dynamic camera configuration... Pooling mode for profile update... RM-237\RM237_0544311_07.30_015.dcpf\0544311\ProductPr ofile_0544311.xml Sending Profile to Phone...OK my post is closed |
