Old 02-13-2010, 08:05   #1 (permalink)
MR.MAMUN's Avatar
Member: 548479
Thanks Meter: 138
nokia 3110c sd repair ok but no netwark
sd repair pm autho oll wark but no netwark
how to problem solved
Old 02-13-2010, 08:08   #2 (permalink)
Member: 713374
Sonork: 100.1597179
Thanks Meter: 223
have u written PM file on it
Old 02-13-2010, 08:28   #3 (permalink)
Member: 316481
Sonork: 1621596
Thanks Meter: 8
i have like your problem it n70 no signal after repaire sdk ,why
Old 02-13-2010, 09:18   #4 (permalink)
kirta's Avatar
Member: 898963
Thanks Meter: 69
erase flash,flash phone with new version write full pm without 308 onather phone,REPAIR SD AGAIN and post result
Old 02-13-2010, 09:34   #5 (permalink)
gyuszko's Avatar
Member: 8086
Thanks Meter: 180
check hardware, possibly not SW problem!
Old 02-13-2010, 09:51   #6 (permalink)
..::Rizwan::..'s Avatar
Member: 777415
Sonork: 1589702
Thanks Meter: 1,420
I have same problem with 5220 xm but after full flash with latest version and recover cert all ok
Old 02-13-2010, 10:37   #7 (permalink)
MR.MAMUN's Avatar
Member: 548479
Thanks Meter: 138
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.12027, Date: 06-02-2010
Product: V 07.21 05-11-08 RM-237 (c) Nokia.
SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1]
ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
ROM ID: 191EC665DFAAF68F
Sending SecondaryBoot ...OK
Sending PreLoader ...OK
Sending CustomLoader ...OK
Restarting phone ...
Connecting to server[main.mxkey.biz] ...OK, secure login ...
Authenticating to SUPERDONGLE using security server ...
SUPERDONGLE authorized !
Phone authenticated to SUPERDONGLE already.
Writing PM from Node ...
Section: 1
- Key: 0, size 114 bytes written.
- Key: 2, size 98 bytes written.
- Key: 4, size 110 bytes written.
- Key: 6, size 98 bytes written.
- Key: 8, size 110 bytes written.
- Key: 13, size 98 bytes written.
- Key: 16, size 86 bytes written.
- Key: 18, size 86 bytes written.
- Key: 20, size 86 bytes written.
- Key: 25, size 4 bytes written.
- Key: 29, size 6 bytes written.
- Key: 34, size 80 bytes written.
Section: 309
- Key: 0, size 4 bytes written.
- Key: 1, size 2 bytes written.
- Key: 2, size 12 bytes written.
- Key: 4, size 12 bytes written.
- Key: 5, size 12 bytes written.
- Key: 7, size 12 bytes written.
- Key: 8, size 12 bytes written.
- Key: 17, size 12 bytes written.
- Key: 22, size 12 bytes written.
Completed in 1.906 s
Phone Type: RM-237 (Nokia 3110c)
SW Version: V 07.21 05-11-08 RM-237 (c) Nokia.
Imei plain: 35934302760914-9
Product Code: 0514950
Language Pack:
- not available.
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
TimeStamp: 2008-11-12T09:10:26Z
SW Version: 07.21
Variant Version: 013
ProductProfile: RM237_0514950_07.21_013.spr
Simlock: 0514950_simlock.bin
Imei net: 359343027609149
Version: SIMLOCK SERVER VERSION 63
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
please help.................................
Old 02-13-2010, 10:47   #8 (permalink)
NIMESHFONOTLY's Avatar
Member: 760274
Thanks Meter: 146
Read full pm another working mobile
write that read pm to your mobile.
Do simlock repair
do sd repair and uper sd auth then write 1,309pm
factory settings...
Old 02-13-2010, 16:37   #9 (permalink)
R@ZIB-BD's Avatar
Member: 718425
Thanks Meter: 5,873
Section: 1
Section: 309
Language Pack:
- not available.
SIMLOCK_TEST passed
SW Version: 07.21
Counter: 0/3, 0/10
Contact : STBSL
Old 02-13-2010, 16:45   #10 (permalink)
Member: 898927
Thanks Meter: 11
write 1,309pm your phone working fine
Old 02-13-2010, 18:07   #11 (permalink)
Member: 1153888
Thanks Meter: 4
problem solved
Bro, write this RPL to phone and your network will become normal!!!
BR,
NeOnyx
Old 02-14-2010, 06:53   #12 (permalink)
MR.MAMUN's Avatar
Member: 548479
Thanks Meter: 138
write band ching rpl but same problem please any other solution .
Old 02-14-2010, 10:49   #13 (permalink)
MR.MAMUN's Avatar
Member: 548479
Thanks Meter: 138
Do simlock repair
factory settings...
please send 100% pm file
3110c SD Repair l For MX-Key 100% working mdmosheur MXKEY Nokia Flasher and Unlocker (by Alim Hape) 0 02-06-2010 12:46
3110c sd repair prbolm infinitymobiles MXKEY Nokia Flasher and Unlocker (by Alim Hape) 0 02-06-2010 09:38
3110c sd repair prbolm infinitymobiles MXKEY Nokia Flasher and Unlocker (by Alim Hape) 2 02-06-2010 09:31
T serice unlock but no netwark MR.MAMUN UST Pro II 1 12-07-2009 08:46
NOKIA 33XX-3410 Charging OK but No Power ON! <<SOLUTION>> CyberoptiK Nokia Hardware & Hardware Repair 2 11-24-2004 08:20
Page generated in 0.20502 seconds with 9 queries
