02-11-2012, 15:58 | #1 (permalink) |
No Life Poster Join Date: Jan 2009 Location: Afghanistan 0093786144898 Age: 37
Member: 938983 Status: Offline Sonork: 100.1585802 Thanks Meter: 102 | Nokia 3110c Security Test Failed Phone type: RM-237 (Nokia 3110c) SW version: V 07.21 05-11-08 RM-237 (c) Nokia. Imei plain: 35320303811666-4 Product code: 0544325 Battery voltage: 5008 mV, current: 52 mA Language Pack: - not available. SLPA ver[1]: PA_SL (15 digit NCK) SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 353203038116664 Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN |
02-11-2012, 16:15 | #3 (permalink) | |
Product Supporter Join Date: Feb 2010 Location: .::INDIA::.
Member: 1236722 Status: Offline Sonork: 100.1601546 Thanks Meter: 4,180 | Quote:
02-11-2012, 16:41 | #4 (permalink) |
Member: 938983 Status: Offline Sonork: 100.1585802 Thanks Meter: 102 | The problem solved by this solution 1. first backup rpl ( go > imei and security tab > imei rebuild > backup rpl) 2. erase old pm ( go > pm tab > erase ) 3. Reset npc data ( go> imei and security tab> reset NPC data)( must backup rpl before do this) 4. Erase pm again (go > pm tab > erase ) 5.Write rpl from backup ( go > imei and security tab > imei rebuild > restore imei) 6. go pm tab > super sd auth or pmm auth > than write good or modified pm ( must need pm 1 & 309) |
03-31-2012, 15:51 | #5 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: Bareilly(U.P) Age: 50
Member: 405715 Status: Offline Thanks Meter: 271 | Quote:
and finally "repair simlock". | |
03-31-2012, 18:29 | #6 (permalink) |
No Life Poster Join Date: Jan 2008 Location: Pakistan
Member: 682736 Status: Offline Thanks Meter: 457 | No need for that all. Very simple solution I tell you... 1. Press Repair SD when software ask for writing rfbb press NO. 2. Now select Pm file manually and just Tick 1 and 309. And press write. Its tested solution............ |
The Following 2 Users Say Thank You to adnon For This Useful Post: |
