07-14-2011, 07:52 | #1 (permalink) |
No Life Poster Join Date: Apr 2007 Location: India
Member: 481609 Status: Offline Sonork: 100.1659889 Thanks Meter: 367 | nokia 3110c SECURITY_TEST failed! SECURITY_TEST failed! Phone Type: RM-237 (Nokia 3110c) SW Version: V 07.30 07-05-09 RM-237 (c) Nokia. Imei plain: 35681502157961-1 Product Code: 0544306 Battery voltage: 4773 mV, current: 54 mA Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 356815021579611 Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN i will do allafter pm write same SECURITY_TEST failed! plz help |
07-14-2011, 07:58 | #4 (permalink) |
Junior Member Join Date: Feb 2010
Member: 1229689 Status: Offline Sonork: [email protected] Thanks Meter: 2 | connet with me i will solve............by atf |
07-14-2011, 08:07 | #9 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Bosnia
Member: 698071 Status: Offline Sonork: 100.1622915 Thanks Meter: 283 | solution 1. super sd auth or pmm auth than write good or modified pm ( must need pm 1 & 309) or, 2. sd repair super sd auth or pmm auth than write good or modified pm ( must need pm 1 & 309) yes! we have this solution 1. first backup rpl ( go > imei and security tab > imei rebuild > backup rpl) 2. erase old pm ( go > pm tab > erase ) 3. Reset npc data ( go> imei and security tab> reset NPC data)( must backup rpl before do this) 4. Erase pm again (go > pm tab > erase ) 5.Write rpl from backup ( go > imei and security tab > imei rebuild > restore imei) 6. go pm tab > super sd auth or pmm auth > than write good or modified pm ( must need pm 1 & 309) 7. erase pm again 8. Recover CERT ( go>imei and security tab> imei rebuild > recover cert) 9. give full factory reset ---------------------------------------------------------------------------------- 2nd or 3rd option of security test fail solution IF ALL SOLUTION NOT WORK THEN 1. Firest Backup Just Npc Rpl In Sl2 And Full Rpl Backup In Sl3 Most Importanat Simlock Data (save simlock rpl extra for sl3) 2. Second Erase set with erase file then flash with any version after flash write npc data rpl with clone rpl ccc and hwc data (by model) After write repair superdongle key and simlock data in sl 2 write full pm with SX4 server. and Sl3 also erase and write flash after flash write npc data rpl with ccc and hwc not full then simlock data rpl after write rpl repair SD then write full pm with SX4 Server. and 3rd solution for 3110c all thing try but security test fail not ok then just do that backup npc data rpl then write another set rpl dont worry about anything when writing ok then check ur imei crrupt SD crrupt and simlock data crrupt but security test pass.after this condtion just write npc data rpl then repair sd then simlock then write full pm with sx4 server ur set ok. (some time 3110c writing wrong rpl show error but ur work is done or some time after write wrong rpl ur imei is not currpt but ur sd and simlock data crrupt and security test pass) br. sajohaker |
07-14-2011, 08:11 | #10 (permalink) |
Member: 698071 Status: Offline Sonork: 100.1622915 Thanks Meter: 283 | 3110c very hard security test failed to repair. Here what to do. -Backup full pm and rpl. -erased full pm area -repair sd and write moded pm 1, 309. -restore simlock data by choosing your full pm backup. -Unlock your phone -Now info phone. -Done br. sajohaker |
05-10-2012, 06:12 | #11 (permalink) |
Junior Member Join Date: Jun 2009
Member: 1047794 Status: Offline Thanks Meter: 4 | right and real soluation go to service imei and security tick write rpl (select ncp data) ncp data download mx server then ncp data write go pm tab(load from file only rpl pm1and 309) then reapair sd.super sd.pm au.and write last full factory set 100%ok lalji mobile care |
