03-05-2013, 12:51 | #1 (permalink) |
No Life Poster Join Date: Jun 2009
Member: 1051835 Status: Offline Sonork: 100.1594332 Thanks Meter: 514 | Nokia 3110c Show Contact Service Simlock OK Here is log flashing log, MXKEY [MxKey Team HTI PLUS Flasher Interface 1], SN: Using device: USB ROM and HTI, FW ver: 00.50, SN: Connection status: EHCI:HUB:HUB::USB 2.00 (Full-speed) Driver: NMWCD, ver: 7.1.32.75 Module ver: 1.0.0.21313(12-12-2012), Library ver: 1.0.0.14337(12-12-2012) Processing MCU file: rm237__07.30.mcusw [BB5,BB5 ALGORITHM] size: 14.49 MB Supported Ids: 0103192101001101, 010C192101001101 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... CMT SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAP3G ver: PA 1.x] CMT EM0 ID: 00000232 CMT EM1 ID: 00000353 CMT PUBLIC ID: 0CE00019921C8C56491665B03EBC3E4086859BE5 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID: 191EC665DFAAF68F Flashing CMT Update Server Data, ULO: 0x38C0 bytes Update Server code succesfully sent to phone. Flashing CMT Update Server Data, UPDAPP: 0x3DFC0 bytes Update Server code succesfully sent to phone. Flashing CMT Update Server Data, PASUBTOC: 0x4BF80 bytes Update Server code succesfully sent to phone. Waiting for USB device removal ... Device connected: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, PORT_ID: 3B1C80F2 Verifying communication to device OK. Erase size: 16.37 MB CMT FLASH,NOR area [00000000-000006BF] erased in 0.708 s CMT FLASH,NOR area [000006C0-0001FFFF] erased in 0.751 s CMT FLASH,NOR area [00020000-0007FFFF] erased in 2.301 s CMT FLASH,NOR area [00080000-000DFFFF] erased in 2.330 s CMT FLASH,NOR area [00100000-001FFFFF] erased in 5.878 s CMT FLASH,NOR area [00200000-0031FFFF] erased in 7.132 s CMT FLASH,NOR area [00320000-0105FFFF] erased in 1 min 22.776 s CMT FLASH,NOR area [01060000-01067FFF] erased in 0.752 s CMT FLASH,NOR area [01068000-0107FFFF] erased in 0.753 s Flash programming ... CMT NOLO block sent CMT KEYS block sent CMT PRIMAPP block sent CMT PASUBTOC block sent Selecting first CMT PAPUB block with matching RootKey. CMT PAPUBKEYS: C0E691EA [RAP Certificate 66 v2] sent CMT UPDAPP block sent CMT DSP0 block sent CMT MCUSW block sent CMT PMM_CONF block sent CMT SBIF_CONF block sent Programming completed in 55.447 s Processing PPM file: rm237__07.30.ppm_b [BB5,BB5 ALGORITHM] size: 3.20 MB Supported Ids: 0103192101001101, 010C192101001101 Erase size: 4.62 MB CMT FLASH,NOR area [01080000-0151FFFF] erased in 28.692 s Flash programming ... Programming completed in 12.257 s Processing CNT file: rm237__07.30.image_b_era_pl2 [BB5,BB5 ALGORITHM] page size: 64 K size: 4.76 MB Supported Ids: 0103192101001101, 010C192101001101 Erase size: 10.75 MB CMT FLASH,NOR area [01520000-01FDFFFF] erased in 1 min 26.990 s Converting UCP blocks to 128 K. Flash programming ... Programming completed in 18.616 s Total time for flashing process(boot+erase+write) was 5 min 36.603 s Waiting for USB device removal ... Waiting for device boot up ... Device connected: nmwcdc\Nokia 3110 classic USB Phonet, PORT_ID: C701390 Verifying communication to device OK. Phone type: RM-237 (Nokia 3110c) SW version: V 07.30 07-05-09 RM-237 (c) Nokia. Imei plain: 35606103821186-0 Product code: 0544307 Battery voltage: 3935 mV, current: 116 mA Language Pack: - not available. SLPA ver[1]: PA_SL (15 digit NCK) SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 356061038211860 Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN FULL FACTORY... OK USER DATA... OK LEAVE FACTORY... OK SERVICE CENTER... OK SOFTWARE UPGRADE... OK PRODUCTION TUNING... OK Reset User Code (to default:12345) ... OK Any solution. |
03-06-2013, 06:52 | #4 (permalink) |
Member: 1051835 Status: Offline Sonork: 100.1594332 Thanks Meter: 514 | Here is sefl tests Phone Type: RM-237 SW version: V 07.30 07-05-09 RM-237 (c) Nokia. ID Test name Startup Result 3 EAR_DATA_LOOP Y passed 12 SIM_CLK_LOOP Y passed 13 SIM_IO_CTRL_LOOP Y passed 15 SLEEP_X_LOOP Y !failed ! 46 UEM_CBUS_IF Y passed 7 KEYBOARD_STUCK N passed 22 CAMERA_IF N passed 20 BACKUP_BATT N passed 21 LPRF_IF N passed 44 LPRF_AUDIO_LINES N passed 2 CURRENT_CONS N passed 42 RADIO Y passed 69 BACKLIGHT Y passed 33 SIM_LOCK N passed 93 SECURITY N passed 71 BT_WAKEUP N passed 99 IRDA_LED_STRESS N passed 96 HOOKINT N passed 88 TAHVOINT Y passed 56 SLEEPCLK_FREQ N passed 101 BTEMP N passed 107 BT_SLEEP_CLK N passed 108 EXT_DEVICE N passed 86 CDSP_RF_BB_IF N !no signal 83 CDSP_RF_SUPPLY N !no signal 85 CDSP_TX_IQ N !no signal 74 CDSP_TXC_DATA N !no signal 79 CDSP_RX_PLL_PHASE_LOCK N !no signal 80 CDSP_TX_PLL_PHASE_LOCK N !no signal 81 CDSP_RX_IQ_LOOP_BACK N !no signal 77 CDSP_GSM_TX_POWER N !no signal |
03-06-2013, 07:02 | #5 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Quote:
It's Hardware, Reflow CPU & Retu IC, Change Retu IC will solve it. BR, ZUBER | |
03-06-2013, 12:02 | #8 (permalink) |
No Life Poster Join Date: May 2010 Location: Samsung Mobile Philippines
Member: 1300241 Status: Offline Sonork: 100.1626973 Thanks Meter: 356 | this is not an hardware problem, TS you can try to relock to network! i have this phone problem before, and solved with this solution! |
