10-14-2013, 08:09 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: I.N.D.I.A
Member: 385162 Status: Offline Thanks Meter: 598 | Nokia 501 flash ok Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... CMT SYSTEM ASIC ID: 00000C201610004049B22809A2D0893C5229B500 [XGOLD 223] CMT PUBLIC ID: 31DFA0D4B44AD1FF49B22809A2D0893C5229B500 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 125FC72605B5C4E48A9E0225084D2579 CMT ROM ID: 535882252F54C676 Loading CMT secondary boot code SecondaryBoot: XG223_v11_usb2nd.fg [XG223] version: 12.30.1 revision: 4.0 size: 0x59C0 Supported Ids: 00000C2016000040, 00000C2016100040 Secondary boot loaded. Loading CMT update server data Algorithm: XG223_v11_usbalg.fg [XG223_V0 ALG] version: 12.30.1 revision: 4.0 size: 0x32338 Supported Ids: 00000C2016000040, 00000C2016100040 Update server code loaded. Initializing Update Server ... Configuring Algorithm clients... FUR: Adding Asic CMT as client OK. Reading CMT NPC (0x1B8 bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x1E8 bytes). Reading CMT HWC (0xD4 bytes). Reading CMT R&D (0x0 bytes). Reading CMT MDM_KEYS (0x0 bytes). Reading CMT PARTNERC (0x0 bytes). RPL(CERT) backup already exist (C:\mobileEx\3.5\data\backup\BB5_35552105487610_CE RT.rpl). CMT PAPUBKEYS is blank/erased. Storing certificate [NPC, CCC, HWC, R&D] ...OK Erase size: 57 MB CMT FLASH,NOR area [40000000-4003FFFF] CMT FLASH,NOR area [47E00000-47E3FFFF] CMT FLASH,NOR area [40060000-426FFFFF] CMT FLASH,NOR area [42700000-437FFFFF] CMT FLASH,NOR area [47E40000-47F1FFFF] Flash programming ... CMT ISSW block sent CMT MEMSET block sent CMT PRIMAPP block sent CMT LOADER block sent CMT PASUBTOC block sent Selecting first CMT PAPUB block with matching RootKey. CMT PAPUBKEYS: 7E4AA995 [] sent CMT UPDAPP block sent CMT MCUSW block sent Programming completed in 7.172 s Processing PPM file: rm902_10.0.2_059R3B3_i1_239_02_236669.rofs.fpsx [XG223,XG223_V0 ALG] size: 5.54 MB Supported Ids: 00000C2016100040 Erase size: 17 MB CMT FLASH,NOR area [42700000-437FFFFF] erased in 0.031 s Flash programming ... CMT PPM block sent Programming completed in 1.907 s Processing CNT file: rm902_10.0.2_059R3B3_i1_239_02_236669.image.fpsx [XG223,XG223_V0 ALG] size: 10.05 MB Supported Ids: 00000C2016100040 Erase size: 70 MB CMT FLASH,NOR area [43800000-47DFFFFF] erased in 0.000 s Flash programming ... Programming completed in 8.406 s Total time for flashing process(boot+erase+write) was 27.390 s Waiting for device boot up ... Device connected: nmwcdc\Nokia USB Phonet, PORT_ID: 355521054876103 Verifying communication to device OK. Phone type: RM-902 (501) SW version: V 10.0.14 04-07-13 RM-902 (c) Nokia Imei plain: XXXXXXXXXX Product code: 059T1N3 Battery voltage: 3652 mV, current: 121 mA Language Pack: - not available. SLPA ver[5]: PA_SIMLOC30 (20 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! Camera config: 01035602005001, ver: RPL saved to "C:\mobileEx\3.5\data\backup\BB5_RM-902_355521054876103_14_10_13_123800_SIM.RPL" SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: XXXXXXXXXXXX Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN |
The Following 2 Users Say Thank You to dharmeshslnk For This Useful Post: |
