10-10-2010, 19:09 | #1 (permalink) |
No Life Poster Join Date: Dec 2007 Location: kashmir Age: 41
Member: 642074 Status: Offline Thanks Meter: 1,955 | N73 security test failed help urgent manole ## -DONE (ANSWERED) Security test failed And 3110 PHONE RESTRICTED I do all repair SD upadte simlock pm auth all ok still same And another 3110 security test failed i pm auth many times but still again security test failed HELP |
10-10-2010, 19:52 | #4 (permalink) | |
Freak Poster Join Date: Nov 2008 Location: indonesia Age: 38
Member: 895552 Status: Offline Thanks Meter: 33 | Quote:
step 1.pm auth and write pm 1.and 309 3110 phone restrice you cant repair simlock or init simlock ok.please post you log in here may be im cant help you ok | |
10-10-2010, 20:33 | #5 (permalink) |
Product Manager Join Date: Jan 2002 Location: NCK Team Projects
Member: 94675 Status: Offline Sonork: 100.8888 QQ3161545070 Thanks Meter: 97,265 | http://forum.gsmhosting.com/vbb/f550...ection-984366/ 5. If you need help, post your problem with most accurate description, post logs and screen shots, phone model and phone status before you used mxkey, also remember to post what version of mxkey software you used and what interface. Last edited by Fast Unlocking; 10-11-2010 at 16:45. |
10-11-2010, 00:07 | #6 (permalink) | |
No Life Poster Join Date: Apr 2009 Location: Mizoram>>Aizawl
Member: 1014781 Status: Offline Thanks Meter: 177 | Quote:
BR, curvenger. | |
10-13-2010, 15:23 | #7 (permalink) |
Member: 642074 Status: Offline Thanks Meter: 1,955 | ASIC MODE ID: 00 PUBLIC ID: 3938985752DF4104611134AE18BF41BB31EBE8A1 ROOT KEY HASH: 49A97E826B93BA20B7ED0B082475C00500000000 ROM ID: 1DFD66132C872FD4 RAP Data : SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 14600213CBF50154F206C43D8D065F751F9A3C7E ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 00EC 22E8 - 0000 6921 [Samsung K8S2815ETB,128 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.33.1 revision: 0.0 size: 0x29878 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: 5E8D0D504A0902E261268C14FCD8A2C9093523BC TransmissionMode: DDR&TX2 SecondaryBoot: helen3_2nd.fg [BB5] version: 1.35.0 revision: 0.0 size: 0x3500 Supported APE Ids: 17100700, 17100701, 17100702, 17100703, 17100704, 17100708 FlashID0: 00EC 00A1 - 0080 0015 [Samsung KAL00T00EM-DGYY/66,1 Gbits] type: NAND,APE ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF Algorithm: h3_sam_nand_xsr.fg [OMAP1710 UNISTORE-II-1.2.1 ALG] version: 1.47.0 revision: 0.0 size: 0x13598 Supported APE Ids: 17100700, 17100701, 17100702, 17100703, 17100704, 17100708 APE PAPUBKEYS HASH: 5E8D0D504A0902E261268C14FCD8A2C9093523BC Original Imei: 35897301328158 Original Product code: 0543843 Bluetooth ID: 001DFD051C26 Phone Type: RM-133 (Nokia N73) SW Version: V 05wk47v51.5 29-08-07 RM-133 (c) Nokia. Imei plain: 35897301328158-5 Product Code: 0529607 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 358973013281585 Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
10-13-2010, 15:26 | #8 (permalink) | |
Member: 642074 Status: Offline Thanks Meter: 1,955 | N73 log............................................... ............................... Quote:
10-13-2010, 16:36 | #10 (permalink) | |
Member: 642074 Status: Offline Thanks Meter: 1,955 | Quote:
Writing PM from Node ... Section: 1 - Key: 0, size 114 bytes written. - Key: 2, size 98 bytes written. - Key: 4, size 110 bytes written. - Key: 6, size 98 bytes written. - Key: 8, size 110 bytes written. - Key: 13, size 98 bytes written. - Key: 16, size 98 bytes written. - Key: 18, size 98 bytes written. - Key: 20, size 98 bytes written. - Key: 22, size 16 bytes written. - Key: 23, size 4 bytes written. - Key: 24, size 84 bytes written. - Key: 25, size 4 bytes written. - Key: 26, size 110 bytes written. - Key: 28, size 98 bytes written. - Key: 29, size 6 bytes written. - Key: 31, size 98 bytes written. - Key: 33, size 36 bytes written. - Key: 34, size 80 bytes written. - Key: 44, size 182 bytes written. - 2 skipped - 4 skipped - 8 skipped - 11 skipped - 17 skipped - 44 skipped - 50 skipped - 54 skipped - 88 skipped - 92 skipped - 96 skipped - 107 skipped - 193 skipped - 239 skipped - 308 skipped Section: 309 - Key: 0, size 4 bytes written. - Key: 1, size 2 bytes written. - Key: 2, size 12 bytes written. - Key: 4, size 12 bytes written. - Key: 5, size 12 bytes written. - Key: 7, size 12 bytes written. - Key: 8, size 12 bytes written. - Key: 17, size 12 bytes written. - Key: 22, size 12 bytes written. - 322 skipped - 334 skipped Completed in 3.531 s | |
10-14-2010, 03:32 | #11 (permalink) |
Freak Poster Join Date: Jul 2004 Location: Khakassia,MobileService Age: 48
Member: 72306 Status: Offline Thanks Meter: 193 | write this PM with SX4 write simlock rpl........ Last edited by Igorbublik; 10-14-2010 at 03:39. |
The Following User Says Thank You to Igorbublik For This Useful Post: |
10-22-2010, 15:56 | #14 (permalink) |
No Life Poster Join Date: Aug 2006 Location: in earth
Member: 333037 Status: Offline Sonork: 100.1611244 Thanks Meter: 77 | brother i will tell u how to solve this problem 1 use hwk try make option sx4b then save it 2 full erase the phone then flash it 3 write cert in hwk 4 open mxkey use option buscheck it show phone data 5 make repair sd then write pm 6 last option use write recover cert 100% fix your problem |
Winlock 1.10 - Help | rdmfs | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 06-25-1999 08:21 |
