03-27-2012, 15:13 | #1 (permalink) |
Freak Poster Join Date: Sep 2006 Location: OACHIRA KOLLAM
Member: 354427 Status: Offline Thanks Meter: 6 | nokia 5130 contact service (ANSWERED) MXKEY [FT SCR2000 0], SN: C0808FD7 Using device: HTI, FW ver: 00.50, SN: 00000E97 Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.20454(13-03-2012), Library ver: 1.0.0.13962(12-03-2012) CMT Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.0] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 0EA00219F5A17D560DFBB745E8EA6F10860D8A1B ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: RAP3Gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 eBB5ProtocolType: OLD Storage0: 0089 8982 - 0000 8A31 [Intel NU48F512,512 Mbits] type: FLASH,NOR, asic:CMT Storage content: 0000 0000 0000 0000 0000 0000 0000 0000 Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.50.0 revision: 0.0 size: 0x23010 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0 TransmissionMode: DDR&TX2 Original Imei: 35322303080009 Original Product code: 0577793 Bluetooth ID: 00247CF104C5 SIMLOCK PA identifier: [0] PA_SL3 Phone type: RM-495 (Nokia 5130c-2) SW version: V 07.97 13-09-10 RM-495 (c) Nokia Imei plain: 35322303080009-9 Battery voltage: 4801 mV, current: 93 mA Language Pack: - not available. SLPA ver[1]: PA_SL (15 digit NCK) Camera config: NIMMIIIIRRFF0A021001, ver: XXX.XXX warning: DCC corrupted ! SIMLOCK invalid! SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST failed! SECURITY_TEST passed SIMLOCK_DATA corrupted! SIMLOCK_DATA corrupted! |
The Following User Says Thank You to shamnad For This Useful Post: |
03-27-2012, 20:44 | #4 (permalink) | |
No Life Poster Join Date: May 2010 Location: <:D-R-E-A-M-S:>
Member: 1312746 Status: Offline Thanks Meter: 766 | Quote:
03-28-2012, 20:34 | #5 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | Damaged SL3 simlock, damaged any BB5 IMEI: BB5 > Service > Imei & Security presss Restore IMEI if you have any backup. and if no backup, corrupted backup, incomplete backup, etc: contact Fast Unlocking make deal and send to him your .ask file. ignore logs or version on picture, just an example |
03-29-2012, 08:00 | #7 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | bro. what will atf do in this case ? will it produce new RPL in this case ? your answer is wrong. noting will be happen with atf for simlock corrupted. |
03-29-2012, 08:53 | #8 (permalink) |
No Life Poster Join Date: Feb 2012 Location: lalamusa pakistan Age: 39
Member: 1724303 Status: Offline Sonork: 1611265 Thanks Meter: 70 | only by new rpl and problem sole but new rpl price 40$ and normal working 5130 phone price 30$ i think by new working phone |
03-29-2012, 10:08 | #12 (permalink) |
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | bro. in SL3 phones you cant repair simlock via unlock procedure with any box direct, needs to buy RPL, so you are wrong. |
04-21-2012, 09:28 | #13 (permalink) |
No Life Poster Join Date: Dec 2006
Member: 408058 Status: Offline Thanks Meter: 371 | MXKEY [MxKey Team HTI PLUS Flasher Interface 4], SN: C086D623 Using device: HTI, FW ver: 00.50, SN: 01001640 Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.20251(25-02-2012), Library ver: 1.0.0.13946(25-02-2012) CMT Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.0] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 1B40021906B77D56A24AC5EFA61E480D740340CC ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: RAP3Gv3_2nd.fg [BB5] version: 10.6.0 revision: 0.0 size: 0x3C40 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 eBB5ProtocolType: OLD Storage0: 0089 8982 - 0000 8A31 [Intel NU48F512,512 Mbits] type: FLASH,NOR, asic:CMT Storage content: 0000 0000 0000 0000 0000 0000 0000 0000 Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 10.28.0 revision: 0.0 size: 0x23220 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0 TransmissionMode: DDR&TX2 Original Imei: 35422303567700 Original Product code: 0576445 Bluetooth ID: 002548C7192E SIMLOCK PA identifier: [0] PA_SL3 Phone type: RM-495 (Nokia 5130c-2) SW version: V 07.97 13-09-10 RM-495 (c) Nokia Imei plain: 35422303567700-4 Product code: 0576445 Battery voltage: 4947 mV, current: 150 mA Language Pack: - not available. SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! Camera config: NIMMIIIIRRFF094B2F01, ver: 002.012 SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 354223035677004 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN |
04-21-2012, 09:35 | #14 (permalink) | |
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Quote:
