nokia 5130 contact service repair successfully For the first time i repaired 5130 which was very taff to me now is working ok Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.7687(12-02-2010), 1.0.0.12095(13-02-2010) RAP Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 1CF0000A71D27D563A0A2AF739540E672F90FF1A ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0 Original Imei: 35524603053621 Original Product code: 0572175 Bluetooth ID: 0025D034E0DD Phone Type: RM-495 (Nokia 5130c-2) SW Version: V 06.65 01-04-09 RM-495 (c) Nokia Imei plain: 35524603053621-3 Product Code: 0571584 Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 355246030536213 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
gooood work bro thanks for reporting................... br |
how can u solv this ???post log plzzzzz |
first step make full back up, and save, secondly repair SD, sometime you may get error, do not worry, go to the PMSolution for: "SECURITY_TEST failed!" and "warning: SD authorized but verify failed!" If after repair SD and/or Simlock (Super Dongle RPL and Simlock RPL upload) you get "SECURITY_TEST failed!" and/or "warning: SD authorized but verify failed!". This is comming usually because some PM fields and/or RPL sections are missing from your phone (e.g. DRM keys, CCC, ...). Solution 1 (easy way, maybe not work all time, depends how phone was damaged): - write full PM from SAME phone model C:\mobileEx\3.3\data\NOKIA BB5 PM Tested by Chevka - unplug/replug phone from JAF/UFS box - make Simlock RPL repair - make SD RPL repair - unplug/replug phone from JAF/UFS box - make SUPER SX4 Auth then write PM1 and PM309 if still have problems, use Solution 2: - backup RPL (NPC, CCC, HWC, ...), will call this ORIGINAL RPL - backup RPL from another working phone (same model) with SAME product code - edit this good RPL from another phone and remove NPC section (all lines who start with NPC_DATA_1 ... NPC_DATA_xx), will call this edited file CLONE RPL - backup full PM from another working phone (same model) with SAME product code, will call this file CLONE PM - full erase flash chip (use erase file regarding flash chip size) - flash phone (CMT, APE, ...) - upload CLONE RPL - upload ORIGINAL RPL - write full CLONE PM without fields 1,120,308,309 - unplug/replug phone from JAF/UFS box - make Simlock RPL repair - make SD RPL repair - unplug/replug phone from JAF/UFS box - make SUPER SX4 Auth then write PM1 and PM309 |
nice solution but this can be a repaired phone log where are the first logs and procedure |
can u help me 5130 c/s my id [email protected] |
Thank u i repaired 5130 security failed... Thank u i repaired 5130 security failed with the 1st method Quote:
is there any possibility that we make backup first aND THEN TRY TO UNLOCK........... |
You can get the unlock code here ************.com : Unlock your mobile phone for free at free of cost....And also get the unlock instruction in then same site..... |
k510i mic and speaker not working pls solution |
