Old 03-10-2010, 11:35   #1 (permalink)
MGT SOFTWARE's Avatar
Member: 53263
Sonork: gsm master
Thanks Meter: 280
nokia 5130 contact service repair successfully
For the first time i repaired 5130 which was very taff to me now is working ok
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.7687(12-02-2010), 1.0.0.12095(13-02-2010)
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 1CF0000A71D27D563A0A2AF739540E672F90FF1A
ASIC MODE ID: 00
ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
ROM ID: 273F6D55DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
ExtDEVC: FFFF 0000 - 0000 0000
Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0
Original Imei: 35524603053621
Original Product code: 0572175
Bluetooth ID: 0025D034E0DD
Phone Type: RM-495 (Nokia 5130c-2)
SW Version: V 06.65 01-04-09 RM-495 (c) Nokia
Imei plain: 35524603053621-3
Product Code: 0571584
Language Pack:
- not available.
This phone have PM308 protected, SD security in not restorable.
This is SL3 phone(Simlock2 format).
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 355246030536213
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
The Following 5 Users Say Thank You to MGT SOFTWARE For This Useful Post:
Old 03-10-2010, 11:40   #2 (permalink)
Master Software's Avatar
Member: 1149013
Thanks Meter: 244
gooood work bro thanks for reporting...................
br
The Following User Says Thank You to Master Software For This Useful Post:
Old 03-10-2010, 11:54   #3 (permalink)
ahsan bhi's Avatar
Member: 605545
Thanks Meter: 77
how can u solv this ???post log plzzzzz
Old 03-10-2010, 11:59   #4 (permalink)
Member: 53263
Sonork: gsm master
Thanks Meter: 280
first step make full back up, and save,
secondly repair SD, sometime you may get error, do not worry,
go to the PMSolution for: "SECURITY_TEST failed!" and "warning: SD authorized but verify failed!"
If after repair SD and/or Simlock (Super Dongle RPL and Simlock RPL upload) you get "SECURITY_TEST failed!" and/or "warning: SD authorized but verify failed!".
This is comming usually because some PM fields and/or RPL sections are missing from your phone (e.g. DRM keys, CCC, ...).
Solution 1 (easy way, maybe not work all time, depends how phone was damaged):
- write full PM from SAME phone model C:\mobileEx\3.3\data\NOKIA BB5 PM Tested by Chevka
- unplug/replug phone from JAF/UFS box
- make Simlock RPL repair
- make SD RPL repair
- make SUPER SX4 Auth then write PM1 and PM309
if still have problems, use Solution 2:
- backup RPL (NPC, CCC, HWC, ...), will call this ORIGINAL RPL
- backup RPL from another working phone (same model) with SAME product code
- edit this good RPL from another phone and remove NPC section (all lines who start with NPC_DATA_1 ... NPC_DATA_xx), will call this edited file CLONE RPL
- backup full PM from another working phone (same model) with SAME product code, will call this file CLONE PM
- full erase flash chip (use erase file regarding flash chip size)
- flash phone (CMT, APE, ...)
- upload CLONE RPL
- upload ORIGINAL RPL
- write full CLONE PM without fields 1,120,308,309
The Following 13 Users Say Thank You to MGT SOFTWARE For This Useful Post:
Old 03-10-2010, 12:14   #5 (permalink)
Member: 1234179
Thanks Meter: 3
br
The Following User Says Thank You to nokiacareasr For This Useful Post:
Old 03-10-2010, 12:18   #6 (permalink)
Misbahullah's Avatar
Member: 938983
Sonork: 100.1585802
Thanks Meter: 99
nice solution but this can be a repaired phone log where are the first logs and procedure
Old 03-10-2010, 12:28   #7 (permalink)
Member: 53263
Sonork: gsm master
Thanks Meter: 280
Originally Posted by falcon1975 View Post
hi
but how work it
can u repaly full post & how solution
thanks
next time i will arrange the video how to deal with good pm NOKIA BB5 PM Tested by Chevka is very useful pm , C:\mobileEx\3.3\data\NOKIA BB5 PM Tested by Chevka, if pm show fail warning, try to repair SD then again check factory reset , see if still security fail, if still security fail activate super dong, pm auth then write pm, check again , i think thats all, but remember do note erase the phone or press NPC button this is sl3 phone which till now no solution to repair simlock
The Following User Says Thank You to MGT SOFTWARE For This Useful Post:
Old 03-10-2010, 12:31   #8 (permalink)
Member: 53263
Sonork: gsm master
Thanks Meter: 280
i was not aware with this solution i was trying to follow some instruction from the previous repaired BB5 sl2, but this work only for security fail not for simlock data corrupted
Old 03-10-2010, 12:32   #9 (permalink)
alialjorany's Avatar
Member: 469192
Thanks Meter: 46
- upload CLONE RPL
is that possible ???????????
The Following User Says Thank You to alialjorany For This Useful Post:
Old 03-10-2010, 12:34   #10 (permalink)
Member: 299100
Sonork: 1603395
Thanks Meter: 3
can u help me 5130 c/s my id [email protected]
Old 03-10-2010, 12:36   #11 (permalink)
Member: 1149013
Thanks Meter: 244
Arrow
i think mayb possible but simoock data crupted not possible
Old 03-10-2010, 13:13   #12 (permalink)
Member: 554531
Thanks Meter: 85
yes u r right bro.....................
Old 07-18-2010, 13:28   #13 (permalink)
Crazy Poster
Member: 735745
Thanks Meter: 2
Cool Thank u i repaired 5130 security failed...
Thank u i repaired 5130 security failed with the 1st method
- upload CLONE RPL
is there any possibility that we make backup first aND THEN TRY TO UNLOCK...........
The Following User Says Thank You to vmf1990 For This Useful Post:
Old 07-31-2010, 07:00   #14 (permalink)
Member: 1352071
Sonork: none
Thanks Meter: 2
You can get the unlock code here ************.com : Unlock your mobile phone for free at free of cost....And also get the unlock instruction in then same site.....
Old 07-31-2010, 11:54   #15 (permalink)
Member: 1349974
Thanks Meter: 5
k510i
mic and speaker not working pls solution
5220 contact service repaired successfully (ANSWERED) abhi01 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 4 12-15-2010 17:53
Repair nokia 5130 contact service... [ANSWERED & CLOSED] WeBoXGT Genie Universal 5 09-17-2010 12:52
5130 contact service repaird successfully king.of.gsm Nokia Base Band 5 ( BB-5 ) 20 02-01-2010 11:05
7210c contact service repaired...Successfully.:) harim_1981 Genie Universal 46 12-19-2009 08:27
5130 contact service Repair sl gsm_yousuf MXKEY Nokia Flasher and Unlocker (by Alim Hape) 16 11-09-2009 16:49
Page generated in 0.51102 seconds with 8 queries
