04-16-2011, 08:45 | #1 (permalink) |
Junior Member Join Date: May 2007
Member: 517527 Status: Offline Thanks Meter: 7 | nokia 5130 flashing problem (ANSWERED) CMT Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 2780010BA64F7F56C376A666ABCCC7ADA2C8456E ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,CMT ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0 TransmissionMode: DDR&TX2 Processing MCU file: rm495__07.95.mcusw [BB5,BB5 ALGORITHM] size: 18.20 MB Supported Ids: 010C192101013000, 0103192101003000, 0303192101033000, 030C192101033000 Storing certificate [NPC, VARIANT, R&D, CCC, HWC] ...OK Erase size: 21.00 MB CMT NOR area [00000000-000006BF] CMT NOR area [000006C0-0001FFFF] CMT NOR area [00040000-000BFFFF] CMT NOR area [000C0000-0013FFFF] CMT NOR area [00140000-0137FFFF] CMT NOR area [01380000-0151FFFF] erased in 1 min 30.282 s Flash programming ... CMT PAPUBKEYS: 0C917F11196FDB7378C18EF7260698CA4489DCA0 (RAP Certificate 164 v.1) written. Programming completed in 2 min 0.391 s Processing PPM file: rm495__07.95.ppm_el [BB5,BB5 ALGORITHM] size: 5.91 MB Supported Ids: 010C192101013000, 0103192101003000, 0303192101033000, 030C192101033000 Erase size: 8.62 MB CMT NOR area [01520000-01DBFFFF] erased in 22.500 s Flash programming ... Error chk C7012D0103CD000010000000F1 RX2 not responding, please check BSI/cable/pinout ! Error while programming [00] at 0x01660000, Result: 0010 RX Buffer: C7012D0103CD000010000000F17 |
04-16-2011, 09:15 | #5 (permalink) |
Member: 517527 Status: Offline Thanks Meter: 7 | i also trying with hwk showing this Cannot Detect Mobile Brand 1ST BOOT : C0,07 [Rm-495] [2.1.0.0] RAPx ID : 000000010000022600010006030C192101033000 EM 1 ID : 00000296 EM 2 ID : 00000B22 RAPx PBID : 2780010BA64F7F56C376A666ABCCC7ADA2C8456E RAPx MODE : 00 RAPx HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 RAPx ROID : 273F6D55DFAAF68F CMT 1ST Boot OK CMT 2ND Bt: RAP3Gv3_2nd.fg, Ver: 9.11.1 CMT FLID0 : 00898982-00008A31, Int NU48F512 CMT FLCNT : 000000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF CMT MCID0 : FFFF0000-00000000 CMT 2ND Boot OK CMT ALGO : RAP3Gv3_algo_v1331.fg, Ver: 1.33.1 CMT VPP : Internal DUAL LINE : True CMT ALG Boot OK IMAGE : 08CDBE83_rm495__07.91.mcusw CMT NOR Erase Area: 0x00000000-000006BF CMT NOR Erase Area: 0x000006C0-0001FFFF CMT NOR Erase Area: 0x00040000-000BFFFF CMT NOR Erase Area: 0x000C0000-0013FFFF CMT NOR Erase Area: 0x00140000-0137FFFF CMT NOR Erase Area: 0x01380000-0151FFFF CMT FLASH ERASE OK, Time: 01:12 DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_BLK_ERROR at: 0x00618400, 03 ERR: CMT FLASH WRITE D_BLK C7012D0103CD000010000000F172, LN: 0x004000, Time: 01:45 Process Failed, Repowering Mobile |
