Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > MXKEY (by Alim Hape) > MXKEY Nokia Flasher and Unlocker (by Alim Hape)
Old 04-29-2012, 09:06   #1 (permalink)
Member: 1597393
Sonork: 6692766
Nokia 5130 rf data is empty what to do (ANSWERED)
NOKIA 5130 RF DATA IS EMPTY WHAT TO DO. WHITE AFTER NOKIA LOGO
Version from phone: 07.97
Version from file: 07.97
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 4],
Using device: HTI, FW ver: 00.50, SN: 0000DB7B
Connection status: UHCI:HUB:USB 2.00 (Full-speed)
Driver: WinUSB, ver: 3.5.1.0
Module ver: 1.0.0.19798(05-01-2012), Library ver: 1.0.0.13703(05-01-2012)
Reading RPL backup ...
Reading Phone IDs ...
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006
030C192101033000 [RAP3G ver: PA 3.x]
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 0470011242300356CDF58601C5355DC258ECE1BE
ASIC MODE ID: 00
ROOT KEY HASH:
9DDBFCFE6E73CED7D8C6268C8EB85723
ROM ID: 273F6D55DFAAF68F
SecondaryBoot: RAP3Gv30_2nd.fg [BB5] version: 11.34.0 revision: 3.0 size: 0x3B80
Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
eBB5ProtocolType: NEW
TransmissionMode: DDR&TX2
Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT
Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT
Storage2: 0089 8982 - 0000 8A31 [Intel NU48F512,512 Mbits] type: FLASH,NOR, asic:CMT
Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Algorithm: RAP3Gv30_XSR14_alg.fg [BB5 ALGORITHM] version: 11.34.0 revision: 3.0 size: 0x81324
FUR: Adding Asic CMT as client OK
CMT PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0
PRIVATE ID: 77E4D9A22FC53C2F62FF2DC4B9E3BF971390C3D6
E-FUSE: C5D5525E
SEC ROM CRC: DFAAF68F
productData saved.
Restarting phone ...
Reading Secure Storage ...
Reading Important data ...
Reading SIMLOCK data ...
Reading CERT data ...
CMT Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
ROOT KEY HASH:
SecondaryBoot: RAP3Gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00
Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
eBB5ProtocolType: OLD
Storage0: 0089 8982 - 0000 8A31 [Intel NU48F512,512 Mbits] type: FLASH,NOR, asic:CMT
Storage content: 0000 0000 0000 0000 0000 0000 0000 0000
TransmissionMode: 16Bit
Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.50.0 revision: 0.0 size: 0x23010
Reading CMT NPC (0x168 bytes).
Reading CMT VARIANT (0x0 bytes).
Reading CMT CCC (0x160 bytes).
Reading CMT HWC (0xD4 bytes).
Reading CMT R&D (0x0 bytes).
Reading CMT PARTNERC (0x0 bytes).
Flash Imei: 35537204130286
NPC_DATA saved OK
CCC_DATA saved OK
HWC_DATA saved OK
SIMLOCK_DATA saved OK
SIMLOCK_KEY_DATA saved OK
SUPERDONGLE_KEY_DATA saved OK
CMLA_KEY_DATA saved OK
WMDRM_PD_DATA saved OK
RF_DATA is empty.
PROD_DATA saved OK
BT_DATA saved OK
LOCK_DATA saved OK
LOCK120_DATA saved OK
BB_DATA saved OK
RPL saved to "C:\mobileEx\3.5\data\backup\BB5_35537204130286_BA CK.rpl"
Processing MCU file: rm495__07.97.mcusw
[BB5,BB5 ALGORITHM] size: 18.20 MB
Supported Ids: 010C192101013000, 0103192101003000, 0303192101033000, 030C192101033000
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
ROOT KEY HASH:
Storing certificate [NPC, VARIANT, R&D, CCC, HWC] ...OK
Erase size: 21 MB
CMT FLASH,NOR area [00000000-000006BF]
CMT FLASH,NOR area [000006C0-0001FFFF]
CMT FLASH,NOR area [00040000-000BFFFF]
CMT FLASH,NOR area [000C0000-0013FFFF]
CMT FLASH,NOR area [00140000-0137FFFF]
CMT FLASH,NOR area [01380000-0151FFFF]
erased in 1 min 44.097 s
Prog.status for Asic CMT ...
NOR: OK
Flash programming ...
CMT NOLO block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT PASUBTOC block sent
CMT PAPUBKEYS: 0C917F11 [RAP Certificate 164 v.1] sent
CMT UPDAPP block sent
CMT DSP0 block sent
CMT MCUSW block sent
NOR: OK
Programming completed in 1 min 19.050 s
Processing PPM file: rm495__07.97.ppm_mena_a1
[BB5,BB5 ALGORITHM] size: 6.07 MB
CMT Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
ROOT KEY HASH:
Erase size: 8.62 MB
CMT FLASH,NOR area [01520000-01DBFFFF]
erased in 34.845 s
NOR: OK
NOR: OK
Programming completed in 26.579 s
Processing CNT file: rm495__07.97.image_mena_a1_red
[BB5,BB5 ALGORITHM] page size: 128 K size: 10.26 MB
NOR page size in the phone is 128 K.
CMT Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
ROOT KEY HASH:
Erase size: 34 MB
CMT FLASH,NOR area [01DC0000-0215FFFF]
CMT FLASH,NOR area [02160000-03FBFFFF]
erased in 1 min 32.190 s
NOR: OK
Converting UCP blocks to 128 K.
NOR: OK
Programming completed in 44.923 s
Total time for flashing process(boot+erase+write) was 7 min 7.779 s
Phone type: RM-495 (Nokia 5130c-2)
SW version: V 07.97 13-09-10 RM-495 (c) Nokia
Imei plain: 35537204130286-4
Product code: 0580133
Battery voltage: 4802 mV, current: 80 mA
Language Pack:
- not available.
SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK)
warning: avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 355372041302864
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
FULL FACTORY...
Failed! (0102)
Completed in 2.016 s
FULL FACTORY...
Failed! (0103)
Please Set mode to "TEST MODE" and retry!
Completed in 0.860 s
FULL FACTORY...
Failed! (0102)
Completed in 13.938 s
FULL FACTORY...
Failed! (0102)
Completed in 1 min 7.924 s
Old 04-29-2012, 09:33   #2 (permalink)
.::ZUBER::.'s Avatar
Member: 262425
Sonork: 100.1617691
bro. write PM area1 from local RF/BB, will solve it.
br,
zuberchowdhry
Old 04-30-2012, 14:43   #3 (permalink)
gbluez's Avatar
Member: 73565
Press Repair SD, follow on screen messages.
Should solve your problem.
Old 04-30-2012, 14:50   #4 (permalink)
Member: 967368
Sonork: anil19
HI how to solve 5130 c imei corroupted??hv any solutions?? plz suggest me..
Old 04-30-2012, 14:51   #5 (permalink)
Member: 967368
Sonork: anil19
read info... - Ok
Reading Phone Info....
Connected phone - Nokia 5130c-2
Software ver : V 07.97 13-09-10 RM-495 (c) Nokia
IMEI : 12345610654321?
DSP Ver : ICPR72_10w01
PPM : V 07.97
13-09-10
RM-495
(c) Nokia
MH
CNT :
Product SN : HED356366
Product code :
Base Prd.code: 0567772
Module code : 0204024
Long Prod.SN : 0
Hardware info=======
HWID : 1000
Retu : 16
Tahvo : 22
Batery: 4824 mV
CMT BT: 2222-302
LCDVer: SEIKO
RF ic : 06540601
Lock info ===========
IMEI spNet :
IMEI svNet :
Unable to read Lock table...
User Code : 12345
MMC pwd : no any record found
UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery]
Done!
Old 04-30-2012, 15:14   #6 (permalink)
Member: 262425
Sonork: 100.1617691
bro. post only Mxkey HTI logs & no other box logs here, by the way needs previuos RPL backup of same phone, means when came from customer in this condition only then buy new RPL.
br,
New Nokia Software!!!!!!! Jefferson Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 73 05-15-2013 13:07
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 26 09-25-2012 02:41
Page generated in 0.51043 seconds with 11 queries
