Old 12-21-2010, 12:44   #1 (permalink)
Member: 700741
Sonork: 100.1617188
Thanks Meter: 343
nokia 5130 SECURITY_TEST failed (ANSWERED)
Phone Type: RM-495 (Nokia 5130c-2)
SW Version: V 07.95 03-02-10 RM-495 (c) Nokia
Imei plain: 355232033*******
Product Code: 0576616
Language Pack:
- not available.
This is SL3 phone(Simlock2 format).
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
SUPERDONGLE_KEY[MX] seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST failed!
Imei net: 355232033879222
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFF
after write pm but same
Old 12-21-2010, 12:46   #2 (permalink)
alamgarh's Avatar
Member: 358694
Sonork: 100.1597323
Thanks Meter: 827
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
first make rpl backup. then DO PM AUTH.
THEN WRITE 1 AND 309 .
I THINK SO.,
The Following User Says Thank You to alamgarh For This Useful Post:
Old 12-21-2010, 12:48   #3 (permalink)
Member: 700741
Sonork: 100.1617188
Thanks Meter: 343
i m also try but same
Old 12-21-2010, 12:50   #4 (permalink)
alamgarh's Avatar
Member: 358694
Sonork: 100.1597323
Thanks Meter: 827
acctualy bro this time SL3 unlocking and simlock repair is not possible in MX-KEY so u have to wait.........
Old 12-21-2010, 12:51   #5 (permalink)
awadvictory's Avatar
Member: 286073
Sonork: 100.1594901
Thanks Meter: 35
Download pm -1/309 and pm auth
Old 12-21-2010, 12:53   #6 (permalink)
Member: 286073
Sonork: 100.1594901
Thanks Meter: 35
Use the full pm without 120-308
Old 12-21-2010, 13:01   #7 (permalink)
PedaLBoard's Avatar
Member: 1317565
Thanks Meter: 61
have read the logs? "SECURITY_TEST failed!" no simlock problem..
@MALIKTARIQ
on pm tab
tick load RFBB from server
click pmm auth.
wait until superdongle authorized
the click write
if doesn't exist
click bb5 certificate validation and paste here logs
Old 12-21-2010, 14:25   #8 (permalink)
ashraf_bcs's Avatar
Member: 303373
Sonork: 100.1584377
Thanks Meter: 1,212
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
before doing any operation first take full pm and rpl back up.now use nx key and press recover certificate.
The Following User Says Thank You to ashraf_bcs For This Useful Post:
Old 12-21-2010, 14:30   #9 (permalink)
d.jain's Avatar
Member: 670629
Sonork: 100.1590208
Thanks Meter: 431
yes yes yes............................................... .......................10000% ok
Old 12-21-2010, 14:43   #10 (permalink)
ABDUL RAJA's Avatar
Member: 665989
Sonork: 100.1597348
Thanks Meter: 550
5130 security test failed!!!
5130_Contact Service_Removed.rar
The Following User Says Thank You to ABDUL RAJA For This Useful Post:
Old 12-21-2010, 17:14   #11 (permalink)
ABDUL RAJA's Avatar
Member: 665989
Sonork: 100.1597348
Thanks Meter: 550
all security test failed 100% solution!
Many people posted in this forum about security test failed !
we know that
when come security test failed
solution
1. super sd auth or pmm auth than write good or modified pm ( must need pm 1 & 309)
or, 2. sd repair super sd auth or pmm auth than write good or modified pm ( must need pm 1 & 309)
yes! we have this solution
1. first backup rpl ( go > imei and security tab > imei rebuild > backup rpl)
2. erase old pm ( go > pm tab > erase )
3. Reset npc data ( go> imei and security tab> reset NPC data)( must backup rpl before do this)
4. Erase pm again (go > pm tab > erase )
5.Write rpl from backup ( go > imei and security tab > imei rebuild > restore imei)
6. go pm tab > super sd auth or pmm auth > than write good or modified pm ( must need pm 1 & 309)
7. erase pm again
8. Recover CERT ( go>imei and security tab> imei rebuild > recover cert)
9. give full factory reset
your phone must come back from security test failed
it is 100% tasted by me.
Old 12-22-2010, 08:16   #12 (permalink)
Haider Ali's Avatar
Member: 756333
Thanks Meter: 152
Yes its working fine
Old 12-26-2010, 22:52   #13 (permalink)
UU2
Member: 21987
Thanks Meter: 27
From what this problem may be?
Write pm 1-309
SUPERDONGLE authorized.
Writing PM from Node ...
Section: 1
- Key: 0, size 12 bytes written.
- Key: 1, size 70 bytes written.
- Key: 2, size 70 bytes written.
- Key: 3, size 70 bytes written.
- Key: 4, size 70 bytes written.
- Key: 5, size 276 bytes written.
- Key: 6, size 276 bytes written.
- Key: 7, size 276 bytes written.
- Key: 8, size 276 bytes written.
- Key: 9, size 384 bytes written.
- Key: 10, size 384 bytes written.
- Key: 11, size 384 bytes written.
- Key: 12, size 384 bytes written.
- Key: 13, size 384 bytes written.
- Key: 14, size 384 bytes written.
- Key: 15, size 384 bytes written.
- Key: 16, size 384 bytes written.
- Key: 17, size 32 bytes written.
- Key: 19, size 16 bytes written.
- Key: 20, size 32 bytes written.
- 120 skipped
Section: 309
- Key: 0, size 4 bytes written.
- Key: 1, size 2 bytes written.
- Key: 2, size 12 bytes written.
- Key: 4, size 12 bytes written.
- Key: 5, size 12 bytes written.
- Key: 7, size 12 bytes written.
- Key: 8, size 12 bytes written.
- Key: 17, size 12 bytes written.
- Key: 22, size 12 bytes written.
Completed in 5.453 s
-308 skipped not!!!
Old 12-27-2010, 08:08   #14 (permalink)
UU2
Member: 21987
Thanks Meter: 27
I tested it repeatedly.....everything is the sixth until a step properly!
The pm /1-309/ his writing not good for something!
I used this:
Free File Hosting & Video Downloads, Free File Sharing, Online Friends Network - Ziddu
Old 12-27-2010, 09:16   #15 (permalink)
iftikhar_246's Avatar
Member: 384949
Sonork: 1611265
Thanks Meter: 352
go pm tab
and mark LOAD RFBB from server
and just write
without any pm file
New Nokia Software!!!!!!! Jefferson Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 52 12-30-2016 07:17
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 30 02-24-2016 09:21
Page generated in 0.40263 seconds with 9 queries
