Old 04-12-2011, 07:28   #1 (permalink)
Member: 1080792
Sonork: 4d0ddc25d0db862fb2f2b62f1
Thanks Meter: 31
nokia 5130 set dead
nokia 5130 set is connected to another chaina set via bluetooth after some time set is dead. Then i try to flash it set is sometime show rap flash loader missing. and some times show below log file.
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.9169(08-01-2011), 1.0.0.15868(10-03-2011)
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 16800014EF190056B75BC24749B7D2752D5EB190
ASIC MODE ID: 00
ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
ROM ID: 273F6D55DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 00EC 2400 - 0000 8A31 [Samsung ] type: NOR,CMT
ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
TransmissionMode: 16Bit
Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10
Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
CMT PAPUBKEYS is blank/erased.
TransmissionMode: DDR&TX2
Original Imei: 00000000000000
Original Product code:
please help me about this problem how to solved?
Old 04-12-2011, 08:40   #2 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
Thanks Meter: 10,377
Your Log Showing that MCU flashing not completed ( Terminated ) so you cant Flash with DEAD USB .
Try with Again with a Good 7 Pin cable & if Possible Change Interface
Old 04-12-2011, 08:55   #3 (permalink)
Member: 850148
Thanks Meter: 36
try another cable, or any flashing device
or try srinibas's suggestion.
GL
Old 04-12-2011, 08:58   #4 (permalink)
Member: 1217358
Sonork: 100.1605541
Thanks Meter: 156
than flash UFS try.................
Old 04-12-2011, 09:08   #5 (permalink)
Member: 851193
Sonork: 100.1615313
Thanks Meter: 348
you need backup else no solution
hardware side heating may help but mostly as CMT papubkeys erased = rpl issue for sl3 phones specially
Old 04-12-2011, 09:28   #6 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
Hello , During MCU flashing if it terminated then next time if you do BUS check CMT PAPUBKEYS will show BLANK & IMEI WILL SHOW 000000000000000
After successful flash, set will back to its original condition
Old 04-12-2011, 09:31   #7 (permalink)
Member: 851193
Sonork: 100.1615313
Thanks Meter: 348
it could be (I did 3110c for that but)
sl3 most chance less
as it never start to flash(not allowing by software box) give always error.
cmt not ready or 2nd boot loader error
hope he can do flash successfully and revive phone
good luck.
Old 04-12-2011, 10:28   #8 (permalink)
rana_g_mobiles's Avatar
Member: 1421704
Thanks Meter: 64
this log is dead set
100% after flash imei is back and normal
Page generated in 0.25259 seconds with 9 queries
