02-14-2010, 14:06 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: lucknow
Member: 275643 Status: Offline Thanks Meter: 360 | Nokia 5130 sl data corrupt MAX INFO- Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.7687(12-02-2010), 1.0.0.12095(13-02-2010) RAP Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 1AA00105F6B17D56736D492DB06517158557BA03 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0 Original Imei: 35523203292397 Original Product code: 0577793 Bluetooth ID: 0025D0A26591 Phone Type: RM-495 (Nokia 5130c-2) SW Version: V 07.91 29-10-09 RM-495 (c) Nokia Imei plain: 35523203292397-1 Product Code: 0571584 Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 355232032923971 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF HWK MIKRO INFO- MCU SW : V 07.91 29-10-09 RM-495 (c) Nokia PPM SW : V 07.91 29-10-09 RM-495 (c) Nokia MR Prd.Code: 0571584 Bpr.Code: 0567773 Prod.Sn : HEC345703 HW Vers : 1000 EM VILMA: 16 EM BETTY: 22 RFIC Ver: 06540601 DSP Vers: ICPR72_09w33 LCD Type: SEIKO IMEI : 355232-03-292397-1 SL Serv : SIMLOCK SERVER SL Conf : 244-07-00000000000 SL Prof : 0000000000000000 SL Count: 00 00 SL Data Corrupted Provider: Nokia Test;Finland HOW CAN I REPAIR SL DATA FROM MAX KEY, PLZ HELP ANYONE |
The Following User Says Thank You to compue For This Useful Post: |
02-14-2010, 14:08 | #2 (permalink) |
No Life Poster Join Date: Apr 2008 Location: PROTECTED BY 308
Member: 750001 Status: Offline Sonork: 100.1641021 Thanks Meter: 1,269 | try to update splock if ur luck it wolud b done........ but 99% it cant b solved at the moment BCOZ its Sl3 u have to wait for it BR, Akashub |
The Following User Says Thank You to akashub For This Useful Post: |
02-14-2010, 14:12 | #3 (permalink) | |
No Life Poster Join Date: May 2008 Location: P@Ki$t@n
Member: 777415 Status: Offline Sonork: 1589702 Thanks Meter: 1,420 | Quote:
SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed all things ok whats problem with ur hand est | |
The Following User Says Thank You to ..::Rizwan::.. For This Useful Post: |
02-14-2010, 15:19 | #4 (permalink) | |
Member: 275643 Status: Offline Thanks Meter: 360 | Quote:
if u check ufs info it clear that sl data corroupted, also set restart after nokia logo with white light. | |
02-14-2010, 15:35 | #9 (permalink) |
Member: 777415 Status: Offline Sonork: 1589702 Thanks Meter: 1,420 | brother if ur sl data crrupted then no solution yet i think you know or if u have backup full rpl then write again with mx key or write pm with super sd auth |
02-14-2010, 17:17 | #10 (permalink) |
Member: 275643 Status: Offline Thanks Meter: 360 | actually sl3 sets is yet mistry in sl data case i did all with mx key but problem remain same so we'll wating for new updates of mx key, may be some miracle will done in future. |
06-08-2010, 07:54 | #13 (permalink) |
Junior Member Join Date: Oct 2009
Member: 1144849 Status: Offline Thanks Meter: 0 | Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010) RAP Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 0AB00118CA887D561013209B2F16A449C681337D ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0 Original Imei: 35322303415650 Original Product code: 0577794 Bluetooth ID: 002547195D86 Phone Type: RM-495 (Nokia 5130c-2) SW Version: V 07.91 29-10-09 RM-495 (c) Nokia Imei plain: 35322303415650-6 Product Code: 0577793 Language Pack: - not available. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST failed! SECURITY_TEST passed SIMLOCK_DATA corrupted! plzzzzzzzzzzzz any solusations tell me |
06-08-2010, 08:38 | #14 (permalink) | |
No Life Poster Join Date: May 2006 Location: Pakistan Age: 41
Member: 278548 Status: Offline Sonork: 100.1583183 Thanks Meter: 948 | Quote:
nokia 1202 SL Data Corrupted | batka88 | Nokia Digital Core Technology 4 ( DCT-4 ) | 3 | 02-15-2010 04:32 |
Nokia 5130 SL Data Corrupted. | omtanwer1 | Nokia Base Band 5 ( BB-5 ) | 1 | 02-05-2010 18:48 |
how to repair Nokia 5220 xm contact service, SL data corrupted! | svchost | Universalbox | 0 | 07-17-2009 10:39 |
SL DATA CORRUPT in 6680 | denard | Nokia Base Band 5 ( BB-5 ) | 6 | 11-23-2007 11:53 |
