Old 02-22-2010, 08:17   #1 (permalink)
susmoy's Avatar
Member: 688285
Thanks Meter: 275
Red face Nokia 5130c-2---- Please help
Phone Type: RM-495 (Nokia 5130c-2)
SW Version: V 05.80 18-12-08 RM-495 (c) Nokia
Imei plain: 35422303521565-6
Product Code: 0579268
Language Pack:
- not available.
This phone have PM308 protected, SD security in not restorable.
This is SL3 phone(Simlock2 format).
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 35XXXXXXXXXX..ok
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
Old 02-22-2010, 08:18   #2 (permalink)
Faheem Anjum's Avatar
Member: 399832
Sonork: Faheem Anjum
Thanks Meter: 24,310
what the problem mate :
Old 02-22-2010, 08:19   #3 (permalink)
Member: 554531
Thanks Meter: 85
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
what is the problem bro ?
The Following User Says Thank You to dilipnachna For This Useful Post:
Old 02-22-2010, 08:32   #4 (permalink)
susmoy's Avatar
Member: 688285
Thanks Meter: 275
problem bro
Old 02-22-2010, 08:37   #5 (permalink)
quasim0438's Avatar
Member: 237155
Thanks Meter: 415
it is not a problem..it is only a precaution to avoid these steps through software......
The Following User Says Thank You to quasim0438 For This Useful Post:
Old 02-22-2010, 08:52   #6 (permalink)
susmoy's Avatar
Member: 688285
Thanks Meter: 275
But i am Falsh set
after set dead any solution
Plz help
Old 02-22-2010, 08:56   #7 (permalink)
sajidali's Avatar
Member: 181886
Sonork: 100.1579817
Thanks Meter: 1,007
flash it with latest ver.
The Following User Says Thank You to sajidali For This Useful Post:
Old 02-22-2010, 09:00   #8 (permalink)
Registered User
Member: 703967
Thanks Meter: 53
flash with same version or higher....
The Following User Says Thank You to clyderz88 For This Useful Post:
I need Connectivity Cable Driver 5130c-2 please aland1234 Nokia Base Band 5 ( BB-5 ) 3 08-26-2009 22:20
Page generated in 0.16225 seconds with 10 queries
