04-05-2010, 15:21 | #1 (permalink) |
No Life Poster Join Date: Jul 2009 Location: chandigarh INDIA
Member: 1066865 Status: Offline Thanks Meter: 593 | nokia 5130c-2 still in contact service plz check log Processing file: rm495__07.95.mcusw as MCU [BB5,BB5 ALGORITHM] size: 18.20 MB Supported RAP Ids: 010C192101013000, 0103192101003000, 0303192101033000, 030C192101033000 Make sure USB cable, Battery and charger are removed from device. Insert USB cable,Battery back to device. Insert Charger or Press phone's power button Waiting for USB device ... [ADL] Pooling for ADL device [ADL] Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 139F6567 RAP SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] RAP EM0 ID: 00000296 RAP EM1 ID: 00000B22 RAP PUBLIC ID: 15D001116CC263503CC62D32AE98D695C5999DD8 RAP ASIC MODE ID: 00 RAP ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 RAP ROM ID: 273F6D55DFAAF68F [ADL] Flashing CMT Update Server Data, ULO: 0x3900 bytes [ADL] Update Server code succesfully sent to phone. [ADL] Flashing CMT Update Server Data, UPDAPP: 0x4B340 bytes [ADL] Update Server code succesfully sent to phone. [ADL] Flashing CMT Update Server Data, PASUBTOC: 0x59940 bytes [ADL] Update Server code succesfully sent to phone. [ADL] Pooling for ADL device [ADL] Device found: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, ID: 147160D3 [ADL] Verifying communication to device OK. Erase size: 21.00 MB CMT NOR area [00000000-000006BF] erased in 0.922 s CMT NOR area [000006C0-0001FFFF] erased in 0.890 s CMT NOR area [00040000-000BFFFF] erased in 2.984 s CMT NOR area [000C0000-0013FFFF] erased in 2.782 s CMT NOR area [00140000-0137FFFF] erased in 1 min 47.203 s CMT NOR area [01380000-0151FFFF] erased in 9.859 s Flash programming ... CMT PAPUBKEYS: 0C917F11196FDB7378C18EF7260698CA4489DCA0 (RAP Certificate 164 v.1) written. Programming completed in 1 min 13.031 s Processing file: rm495__07.95.ppm_u as PPM [BB5,BB5 ALGORITHM] size: 7.44 MB Supported RAP Ids: 010C192101013000, 0103192101003000, 0303192101033000, 030C192101033000 Erase size: 8.62 MB CMT NOR area [01520000-01DBFFFF] erased in 50.141 s Flash programming ... Programming completed in 30.110 s Processing file: rm495__07.95.image_u_blu as CNT [BB5,BB5 ALGORITHM] page size: 128 K size: 10.26 MB Supported RAP Ids: 010C192101013000, 0103192101003000, 0303192101033000, 030C192101033000 Erase size: 34.00 MB CMT NOR area [01DC0000-0215FFFF] erased in 22.156 s CMT NOR area [02160000-03FBFFFF] erased in 3 min 4.219 s Flash programming ... Programming completed in 40.906 s [ADL] Pooling for ADL device [ADL] Device found: nmwcdc\Nokia 5130 XPressMusic USB Generic, ID: 24930E7E [ADL] Verifying communication to device OK. Flashing completed in 9 min 31.031 s Phone Type: RM-495 (Nokia 5130c-2) SW Version: V 07.95 03-02-10 RM-495 (c) Nokia Imei plain: 35800603895807-5 Product Code: 0571272 Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 358006038958075 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Total time to process is 9 min 34.875 s |
04-05-2010, 16:10 | #7 (permalink) |
Member: 1066865 Status: Offline Thanks Meter: 593 | Phone Type: RM-495 SW version: V 07.95 03-02-10 RM-495 (c) Nokia ID Test name Startup Result 3 EAR_DATA_LOOP Y !failed ! 12 SIM_CLK_LOOP Y passed 13 SIM_IO_CTRL_LOOP Y passed 15 SLEEP_X_LOOP Y passed 46 UEM_CBUS_IF Y passed 7 KEYBOARD_STUCK N passed 22 CAMERA_IF N !no signal 20 BACKUP_BATT N passed 43 LCD N !no signal 21 LPRF_IF N !no signal 44 LPRF_AUDIO_LINES N !no signal 2 CURRENT_CONS N passed 42 RADIO N !no signal 69 BACKLIGHT Y passed 33 SIM_LOCK N !no signal 93 SECURITY N passed 71 BT_WAKEUP N !no signal 96 HOOKINT N passed 88 TAHVOINT Y passed 101 BTEMP N passed 119 IIC N passed 108 EXT_DEVICE N !no signal 56 CDSP_SLEEPCLK_FREQ N !no signal 128 CDSP_SLEEPCLOCK_FREQ N !no signal 86 CDSP_RF_BB_IF N !no signal 83 CDSP_RF_SUPPLY N !no signal 80 CDSP_TX_PLL_PHASE_LOCK N !no signal 81 CDSP_RX_IQ_LOOP_BACK N !no signal 77 CDSP_GSM_TX_POWER N !no signal |
04-05-2010, 16:14 | #8 (permalink) | |
No Life Poster Join Date: Feb 2005 Location: AD
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | you have this Quote:
br, | |
The Following User Says Thank You to Andra For This Useful Post: |
5130c all ok still contact service plz check moderators | sunny_luthras99 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 03-24-2010 08:41 |
5220 contact service-repaired sd-write pm-still in contact service | zonetrichur | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 02-07-2010 13:21 |
5130c-2 rm-495 contact service plz help | pethu | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 01-18-2010 12:10 |
nokia 5130c type-RH-112 contact service | sathvik71052 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 0 | 10-15-2009 19:48 |
Nokia 5130c-2 RM-495 Contact service. | mounir_2006 | Nokia Hardware & Hardware Repair | 2 | 10-10-2009 15:30 |
