07-12-2010, 08:43 | #1 (permalink) |
No Life Poster Join Date: Nov 2007
Member: 624567 Status: Offline Thanks Meter: 256 | Nokia 5130c-2 super dongle key invalid repair success here is the scan log Phone Type: RM-495 (Nokia 5130c-2) SW Version: V 07.96 20-05-10 RM-495 (c) Nokia Imei plain: 35604003205909-5 Product Code: 0571580 Language Pack: - not available. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 356040032059095 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF log after repair sd Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010) Product: V 07.96 20-05-10 RM-495 (c) Nokia Using cached productData[16500218DCDB8956FEFBAAA6396E250095470900] ... Calculating SUPERDONGLE using security server ... SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.1 Completed in 4.609 s RPL saved to "C:\mobileEx\3.4\data\backup\BB5_RM-495_356040032059095_SD.RPL" Updating SUPERDONGLE_KEY ...OK Scan log after sd repair Phone Type: RM-495 (Nokia 5130c-2) SW Version: V 07.96 20-05-10 RM-495 (c) Nokia Imei plain: 35604003205909-5 Product Code: 0571584 Language Pack: - not available. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 356040032059095 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF here is PM writing log Writing PM from Node ... Section: 1 Warning: failed to write 1 - 0 (12 bytes) Warning: failed to write 1 - 1 (70 bytes) Warning: failed to write 1 - 2 (70 bytes) Warning: failed to write 1 - 3 (70 bytes) Warning: failed to write 1 - 4 (70 bytes) Warning: failed to write 1 - 5 (276 bytes) Warning: failed to write 1 - 6 (276 bytes) Warning: failed to write 1 - 7 (276 bytes) Warning: failed to write 1 - 8 (276 bytes) Warning: failed to write 1 - 9 (384 bytes) Warning: failed to write 1 - 10 (384 bytes) Warning: failed to write 1 - 11 (384 bytes) Warning: failed to write 1 - 12 (384 bytes) Warning: failed to write 1 - 13 (384 bytes) Warning: failed to write 1 - 14 (384 bytes) Warning: failed to write 1 - 15 (384 bytes) Warning: failed to write 1 - 16 (384 bytes) Warning: failed to write 1 - 17 (32 bytes) Warning: failed to write 1 - 19 (16 bytes) Warning: failed to write 1 - 20 (32 bytes) Section: 2 - Key: 0, size 440 bytes written. Section: 4 - Key: 1, size 800 bytes written. - Key: 3, size 10 bytes written. - Key: 4, size 8 bytes written. - Key: 5, size 8 bytes written. - Key: 6, size 8 bytes written. - Key: 9, size 5 bytes written. - Key: 18, size 80 bytes written. - Key: 19, size 4 bytes written. - Key: 28, size 2 bytes written. Section: 8 - Key: 0, size 2 bytes written. - Key: 1, size 16 bytes written. - Key: 2, size 16 bytes written. - Key: 3, size 128 bytes written. - Key: 4, size 128 bytes written. - Key: 7, size 4 bytes written. - Key: 8, size 8 bytes written. - Key: 9, size 8 bytes written. - Key: 10, size 24 bytes written. Section: 11 - Key: 0, size 4 bytes written. - Key: 1, size 4 bytes written. - Key: 2, size 4 bytes written. - Key: 3, size 4 bytes written. - Key: 4, size 1 bytes written. - Key: 5, size 6 bytes written. - Key: 6, size 2 bytes written. - Key: 7, size 1 bytes written. - Key: 8, size 1 bytes written. - Key: 9, size 1 bytes written. - Key: 10, size 1 bytes written. - Key: 11, size 1 bytes written. - Key: 12, size 1 bytes written. - Key: 13, size 1 bytes written. - Key: 14, size 2 bytes written. - Key: 15, size 2 bytes written. - Key: 16, size 2 bytes written. - Key: 17, size 2 bytes written. - Key: 18, size 16 bytes written. - Key: 19, size 32 bytes written. - Key: 20, size 32 bytes written. - Key: 21, size 2 bytes written. - Key: 22, size 2 bytes written. - Key: 23, size 2 bytes written. - Key: 24, size 2 bytes written. - Key: 25, size 2 bytes written. - Key: 26, size 2 bytes written. - Key: 27, size 2 bytes written. - Key: 28, size 2 bytes written. - Key: 29, size 2 bytes written. - Key: 30, size 2 bytes written. - Key: 31, size 2 bytes written. - Key: 32, size 2 bytes written. - Key: 33, size 2 bytes written. - Key: 34, size 2 bytes written. - Key: 35, size 2 bytes written. - Key: 36, size 2 bytes written. - Key: 37, size 2 bytes written. - Key: 38, size 2 bytes written. - Key: 39, size 2 bytes written. - Key: 40, size 2 bytes written. - Key: 41, size 2 bytes written. - Key: 42, size 2 bytes written. - Key: 43, size 2 bytes written. - Key: 44, size 2 bytes written. - Key: 45, size 2 bytes written. - Key: 46, size 2 bytes written. - Key: 47, size 2 bytes written. - Key: 48, size 2 bytes written. - Key: 49, size 2 bytes written. - Key: 50, size 2 bytes written. - Key: 51, size 2 bytes written. - Key: 52, size 2 bytes written. - Key: 53, size 2 bytes written. - Key: 54, size 2 bytes written. - Key: 55, size 2 bytes written. - Key: 56, size 2 bytes written. - Key: 57, size 2 bytes written. - Key: 58, size 2 bytes written. - Key: 59, size 2 bytes written. - Key: 60, size 2 bytes written. - Key: 61, size 2 bytes written. - Key: 62, size 2 bytes written. - Key: 63, size 2 bytes written. - Key: 64, size 2 bytes written. - Key: 65, size 2 bytes written. - Key: 66, size 4 bytes written. - Key: 67, size 1 bytes written. - Key: 68, size 4 bytes written. - Key: 69, size 4 bytes written. - Key: 70, size 4 bytes written. - Key: 71, size 4 bytes written. - Key: 72, size 16 bytes written. - Key: 73, size 4 bytes written. - Key: 74, size 2 bytes written. - Key: 75, size 13 bytes written. Section: 12 - Key: 0, size 102 bytes written. Section: 13 - Key: 0, size 1 bytes written. - Key: 1, size 2 bytes written. - Key: 2, size 1 bytes written. - Key: 3, size 2 bytes written. - Key: 4, size 1 bytes written. - Key: 5, size 1 bytes written. - Key: 6, size 1 bytes written. - Key: 7, size 1 bytes written. - Key: 8, size 2 bytes written. - Key: 9, size 1 bytes written. - Key: 10, size 1 bytes written. - Key: 11, size 48 bytes written. - Key: 12, size 4 bytes written. - Key: 13, size 1 bytes written. - Key: 14, size 1 bytes written. - Key: 15, size 886 bytes written. - Key: 16, size 2 bytes written. - Key: 17, size 1 bytes written. - Key: 18, size 1 bytes written. - Key: 19, size 8 bytes written. - Key: 20, size 1 bytes written. - Key: 21, size 1 bytes written. - Key: 22, size 1 bytes written. - Key: 23, size 1 bytes written. - Key: 24, size 1 bytes written. - Key: 25, size 2 bytes written. - Key: 26, size 1 bytes written. - Key: 27, size 1 bytes written. - Key: 28, size 1 bytes written. - Key: 29, size 1 bytes written. - Key: 30, size 1 bytes written. - Key: 31, size 1 bytes written. - Key: 32, size 1 bytes written. - Key: 33, size 1 bytes written. - Key: 34, size 1 bytes written. - Key: 35, size 1 bytes written. - Key: 36, size 1 bytes written. - Key: 37, size 4 bytes written. - Key: 38, size 1 bytes written. - Key: 39, size 1 bytes written. - Key: 40, size 1 bytes written. - Key: 41, size 1 bytes written. - Key: 42, size 4 bytes written. - Key: 43, size 4 bytes written. - Key: 44, size 1 bytes written. - Key: 45, size 4 bytes written. - Key: 46, size 4 bytes written. - Key: 47, size 1 bytes written. - Key: 48, size 4 bytes written. - Key: 49, size 1 bytes written. - Key: 50, size 1 bytes written. - Key: 51, size 1 bytes written. - Key: 52, size 2 bytes written. - Key: 53, size 4 bytes written. - Key: 54, size 4 bytes written. - Key: 55, size 1 bytes written. - Key: 56, size 1 bytes written. - Key: 57, size 1 bytes written. - Key: 58, size 2 bytes written. - Key: 59, size 1 bytes written. - Key: 60, size 4 bytes written. - Key: 61, size 4 bytes written. - Key: 62, size 1 bytes written. - Key: 63, size 4 bytes written. - Key: 64, size 4 bytes written. - Key: 65, size 1 bytes written. - Key: 66, size 4 bytes written. - Key: 67, size 4 bytes written. - Key: 68, size 1 bytes written. - Key: 69, size 1 bytes written. - Key: 70, size 1 bytes written. - Key: 71, size 4 bytes written. - Key: 72, size 4 bytes written. - Key: 73, size 1 bytes written. - Key: 74, size 4 bytes written. - Key: 75, size 2 bytes written. - Key: 76, size 2 bytes written. - Key: 77, size 2 bytes written. - Key: 78, size 1 bytes written. - Key: 79, size 1 bytes written. - Key: 80, size 1 bytes written. - Key: 81, size 1 bytes written. - Key: 82, size 1 bytes written. - Key: 83, size 2 bytes written. - Key: 84, size 1 bytes written. - Key: 85, size 4 bytes written. - Key: 86, size 4 bytes written. - Key: 87, size 2 bytes written. - Key: 88, size 1 bytes written. - Key: 89, size 4 bytes written. - Key: 90, size 4 bytes written. - Key: 91, size 2 bytes written. - Key: 92, size 1 bytes written. - Key: 93, size 4 bytes written. - Key: 94, size 4 bytes written. - Key: 95, size 2 bytes written. - Key: 96, size 1 bytes written. - Key: 97, size 4 bytes written. - Key: 98, size 4 bytes written. - Key: 99, size 2 bytes written. - Key: 100, size 4 bytes written. - Key: 101, size 2 bytes written. - Key: 102, size 1 bytes written. - Key: 103, size 4 bytes written. - Key: 104, size 4 bytes written. - Key: 105, size 4 bytes written. - Key: 106, size 4 bytes written. - Key: 107, size 4 bytes written. - Key: 108, size 2 bytes written. - Key: 109, size 4 bytes written. - Key: 110, size 4 bytes written. - Key: 111, size 4 bytes written. - Key: 112, size 2 bytes written. - Key: 113, size 4 bytes written. - Key: 114, size 4 bytes written. - Key: 115, size 1 bytes written. - Key: 116, size 1 bytes written. - Key: 117, size 1 bytes written. - Key: 118, size 4 bytes written. - Key: 119, size 4 bytes written. - Key: 120, size 1 bytes written. - Key: 121, size 1 bytes written. - Key: 122, size 1 bytes written. - Key: 123, size 8 bytes written. - Key: 124, size 1 bytes written. - Key: 125, size 1 bytes written. - Key: 126, size 1 bytes written. - Key: 127, size 1 bytes written. - Key: 128, size 1 bytes written. - Key: 129, size 4 bytes written. - Key: 130, size 4 bytes written. - Key: 131, size 1 bytes written. - Key: 132, size 1 bytes written. - Key: 133, size 2 bytes written. - Key: 134, size 1 bytes written. - Key: 135, size 2 bytes written. - Key: 136, size 1 bytes written. - Key: 137, size 1 bytes written. - Key: 138, size 4 bytes written. - Key: 139, size 4 bytes written. - Key: 140, size 1 bytes written. - Key: 141, size 1 bytes written. - Key: 142, size 1 bytes written. - Key: 143, size 1 bytes written. - Key: 144, size 4 bytes written. - Key: 145, size 8 bytes written. - Key: 146, size 4 bytes written. - Key: 147, size 4 bytes written. - Key: 148, size 1 bytes written. - Key: 149, size 1 bytes written. - Key: 150, size 1 bytes written. - Key: 151, size 1 bytes written. - Key: 152, size 1 bytes written. - Key: 153, size 1 bytes written. - Key: 154, size 1 bytes written. - Key: 155, size 1 bytes written. - Key: 156, size 1 bytes written. - Key: 157, size 1 bytes written. - Key: 158, size 1 bytes written. - Key: 159, size 2 bytes written. - Key: 160, size 2 bytes written. - Key: 161, size 1 bytes written. - Key: 162, size 1 bytes written. - Key: 163, size 1 bytes written. - Key: 164, size 1 bytes written. - Key: 165, size 1 bytes written. - Key: 166, size 1 bytes written. - Key: 167, size 8 bytes written. - Key: 168, size 4 bytes written. - Key: 169, size 1 bytes written. - Key: 170, size 1 bytes written. - Key: 171, size 1 bytes written. - Key: 172, size 1 bytes written. - Key: 173, size 1 bytes written. - Key: 174, size 1 bytes written. - Key: 175, size 1 bytes written. - Key: 176, size 1 bytes written. - Key: 177, size 4 bytes written. - Key: 178, size 2 bytes written. - Key: 179, size 1 bytes written. - Key: 180, size 1 bytes written. - Key: 181, size 1 bytes written. - Key: 182, size 1 bytes written. - Key: 183, size 1 bytes written. - Key: 184, size 1 bytes written. - Key: 185, size 1 bytes written. - Key: 186, size 1 bytes written. - Key: 187, size 1 bytes written. - Key: 188, size 1 bytes written. - Key: 189, size 1 bytes written. - Key: 190, size 4 bytes written. - Key: 191, size 2 bytes written. - Key: 192, size 1 bytes written. - Key: 193, size 4 bytes written. - Key: 194, size 1 bytes written. - Key: 195, size 1 bytes written. - Key: 196, size 10 bytes written. Section: 31 - Key: 4, size 14 bytes written. Section: 42 - Key: 0, size 2 bytes written. - Key: 1, size 12 bytes written. - Key: 2, size 36 bytes written. - Key: 3, size 36 bytes written. - Key: 4, size 36 bytes written. - Key: 5, size 36 bytes written. - Key: 6, size 36 bytes written. - Key: 7, size 40 bytes written. - Key: 8, size 40 bytes written. - Key: 9, size 40 bytes written. - Key: 10, size 40 bytes written. - Key: 11, size 40 bytes written. - Key: 12, size 40 bytes written. - Key: 13, size 40 bytes written. - Key: 14, size 40 bytes written. Section: 44 - Key: 0, size 1 bytes written. Section: 50 - Key: 0, size 2 bytes written. Section: 54 - Key: 0, size 2 bytes written. Section: 66 - Key: 0, size 481 bytes written. - Key: 1, size 240 bytes written. - Key: 2, size 240 bytes written. - Key: 3, size 1 bytes written. - Key: 4, size 1 bytes written. - Key: 5, size 240 bytes written. - Key: 6, size 4 bytes written. - Key: 7, size 4 bytes written. - Key: 8, size 4 bytes written. - Key: 9, size 4 bytes written. - Key: 10, size 240 bytes written. - Key: 11, size 240 bytes written. - Key: 16, size 4 bytes written. - Key: 18, size 4 bytes written. - Key: 20, size 4 bytes written. - Key: 22, size 4 bytes written. - Key: 24, size 4 bytes written. - Key: 26, size 4 bytes written. - Key: 28, size 4 bytes written. - Key: 30, size 4 bytes written. - Key: 32, size 4 bytes written. - Key: 89, size 4 bytes written. - Key: 97, size 4 bytes written. - Key: 101, size 4 bytes written. - Key: 115, size 1 bytes written. - Key: 122, size 7 bytes written. Section: 88 - Key: 0, size 36 bytes written. Section: 96 - Key: 0, size 2 bytes written. - Key: 1, size 20 bytes written. Section: 107 - Key: 0, size 21 bytes written. - Key: 1, size 89 bytes written. - Key: 2, size 69 bytes written. - Key: 3, size 70 bytes written. - Key: 25, size 132 bytes written. - Key: 26, size 12 bytes written. Section: 116 - Key: 0, size 2 bytes written. - Key: 1, size 12 bytes written. - Key: 2, size 36 bytes written. - Key: 3, size 36 bytes written. - Key: 4, size 36 bytes written. - Key: 5, size 36 bytes written. - Key: 6, size 36 bytes written. - Key: 7, size 40 bytes written. - Key: 8, size 40 bytes written. - Key: 9, size 40 bytes written. - Key: 10, size 40 bytes written. - Key: 11, size 40 bytes written. - Key: 12, size 40 bytes written. - Key: 13, size 40 bytes written. - Key: 14, size 40 bytes written. - Key: 15, size 40 bytes written. - Key: 16, size 40 bytes written. Section: 153 - Key: 0, size 68 bytes written. - Key: 1, size 68 bytes written. - Key: 2, size 68 bytes written. - Key: 3, size 68 bytes written. - Key: 4, size 68 bytes written. - Key: 5, size 68 bytes written. Section: 193 - Key: 2, size 8 bytes written. - Key: 3, size 32 bytes written. - Key: 4, size 32 bytes written. - Key: 9, size 64 bytes written. Section: 217 - Key: 0, size 32 bytes written. Section: 232 - Key: 0, size 20 bytes written. - Key: 2, size 1 bytes written. - Key: 3, size 1 bytes written. Section: 238 - Key: 1, size 1 bytes written. Section: 250 - Key: 1, size 2128 bytes written. - Key: 2, size 128 bytes written. - Key: 3, size 744 bytes written. - Key: 4, size 40 bytes written. Section: 301 - Key: 0, size 2 bytes written. - Key: 1, size 12 bytes written. - Key: 2, size 36 bytes written. - Key: 3, size 36 bytes written. - Key: 4, size 36 bytes written. - Key: 5, size 36 bytes written. - Key: 6, size 36 bytes written. - Key: 7, size 40 bytes written. - Key: 8, size 40 bytes written. - Key: 9, size 40 bytes written. - Key: 10, size 40 bytes written. - Key: 11, size 40 bytes written. - Key: 12, size 40 bytes written. - Key: 13, size 40 bytes written. - Key: 14, size 40 bytes written. - Key: 15, size 40 bytes written. - Key: 16, size 40 bytes written. Section: 309 Warning: failed to write 309 - 0 (4 bytes) Warning: failed to write 309 - 1 (2 bytes) Warning: failed to write 309 - 2 (12 bytes) Warning: failed to write 309 - 4 (12 bytes) Warning: failed to write 309 - 5 (12 bytes) Warning: failed to write 309 - 7 (12 bytes) Warning: failed to write 309 - 8 (12 bytes) Warning: failed to write 309 - 17 (12 bytes) Warning: failed to write 309 - 22 (12 bytes) Section: 320 - Key: 0, size 148 bytes written. - Key: 1, size 148 bytes written. - Key: 2, size 148 bytes written. - Key: 3, size 148 bytes written. - Key: 4, size 148 bytes written. - Key: 5, size 148 bytes written. - Key: 6, size 148 bytes written. - Key: 7, size 148 bytes written. - Key: 8, size 148 bytes written. - Key: 9, size 148 bytes written. - Key: 10, size 148 bytes written. - Key: 11, size 148 bytes written. - Key: 12, size 148 bytes written. - Key: 13, size 148 bytes written. - Key: 14, size 148 bytes written. - Key: 15, size 148 bytes written. - Key: 16, size 148 bytes written. - Key: 17, size 148 bytes written. - Key: 18, size 148 bytes written. - Key: 19, size 148 bytes written. - Key: 20, size 148 bytes written. - Key: 21, size 148 bytes written. - Key: 22, size 148 bytes written. - Key: 23, size 148 bytes written. - Key: 24, size 148 bytes written. - Key: 25, size 148 bytes written. - Key: 26, size 148 bytes written. - Key: 27, size 148 bytes written. - Key: 28, size 148 bytes written. - Key: 29, size 148 bytes written. - Key: 30, size 148 bytes written. - Key: 31, size 148 bytes written. - Key: 32, size 148 bytes written. - Key: 33, size 148 bytes written. - Key: 34, size 148 bytes written. - Key: 35, size 148 bytes written. - Key: 36, size 148 bytes written. - Key: 37, size 148 bytes written. - Key: 38, size 148 bytes written. Section: 322 - Key: 0, size 1 bytes written. Section: 341 - Key: 0, size 1 bytes written. - Key: 3, size 4 bytes written. - Key: 4, size 4424 bytes written. Section: 354 - Key: 0, size 33 bytes written. Section: 355 - Key: 1, size 2028 bytes written. Section: 356 - Key: 0, size 2 bytes written. Section: 362 - Key: 0, size 1 bytes written. - Key: 1, size 144 bytes written. Section: 364 - Key: 0, size 2 bytes written. - Key: 1, size 12 bytes written. - Key: 2, size 36 bytes written. - Key: 3, size 36 bytes written. - Key: 4, size 36 bytes written. - Key: 5, size 36 bytes written. - Key: 6, size 36 bytes written. - Key: 7, size 40 bytes written. - Key: 8, size 40 bytes written. - Key: 9, size 40 bytes written. - Key: 10, size 40 bytes written. - Key: 11, size 40 bytes written. - Key: 12, size 40 bytes written. - Key: 13, size 40 bytes written. - Key: 14, size 40 bytes written. Section: 365 - Key: 0, size 2 bytes written. - Key: 1, size 12 bytes written. - Key: 2, size 36 bytes written. - Key: 3, size 36 bytes written. - Key: 4, size 36 bytes written. - Key: 5, size 36 bytes written. - Key: 6, size 36 bytes written. - Key: 7, size 40 bytes written. - Key: 8, size 40 bytes written. - Key: 9, size 40 bytes written. - Key: 10, size 40 bytes written. - Key: 11, size 40 bytes written. - Key: 12, size 40 bytes written. - Key: 13, size 40 bytes written. - Key: 14, size 40 bytes written. Completed in 1 min 26.094 s here is super sd auth log SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.1 Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010) Product: V 07.96 20-05-10 RM-495 (c) Nokia Using cached productData[16500218DCDB8956FEFBAAA6396E250095470900] ... Authenticating to SUPERDONGLE using security server ... SUPERDONGLE authorized ! here is load RBF from server tick and write log SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.1 Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010) Product: V 07.96 20-05-10 RM-495 (c) Nokia Using cached productData[16500218DCDB8956FEFBAAA6396E250095470900] ... Authenticating to SUPERDONGLE using security server ... SUPERDONGLE authorized ! SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.1 Updating RFBB data ... Writing section 1... Writing section 309... Done. And Here Is Final SCAN LOG Phone Type: RM-495 (Nokia 5130c-2) SW Version: V 07.96 20-05-10 RM-495 (c) Nokia Imei plain: 35604003205909-5 Product Code: 0571584 Language Pack: - not available. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 356040032059095 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF dont forget to thanks |
The Following 4 Users Say Thank You to sahil00150 For This Useful Post: |
07-12-2010, 09:01 | #2 (permalink) |
No Life Poster Join Date: Apr 2009 Location: Mizoram>>Aizawl
Member: 1014781 Status: Offline Thanks Meter: 177 | Bro, Post in the correct section so that others can find it easily, right here http://forum.gsmhosting.com/vbb/f550...-mxkey-767051/ BR curvenger |
DES key Driver | black | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 02-08-2014 04:50 |
