04-30-2011, 09:50 | #1 (permalink) |
No Life Poster Join Date: Jul 2004 Location: KOLHAPUR, MAHARASTRA,INDIA
Member: 71502 Status: Offline Sonork: 100.1650667 Thanks Meter: 587 | Nokia 5130c contact service????? SW Version: V 07.97 13-09-10 RM-495 (c) Nokia Imei plain: 35*************** Product Code: 0577793 Battery voltage: 4510 mV, current: 49 mA Language Pack: - not available. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 35**************** Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FF I HEAT AVILMA & POWER SUPPLY IC BUT SAME PROBLEM |
04-30-2011, 09:52 | #2 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Hell..... Bcoz i am devil_king Age: 38
Member: 696623 Status: Offline Sonork: 100.1601050 Thanks Meter: 526 | make self test and post here ............... |
The Following User Says Thank You to ..:: Devil_king ::.. For This Useful Post: |
04-30-2011, 10:13 | #5 (permalink) |
Member: 696623 Status: Offline Sonork: 100.1601050 Thanks Meter: 526 | first ear data loop failed , seemes like problem in hardware ... |
04-30-2011, 10:16 | #6 (permalink) | |
Registered User Join Date: Mar 2008
Member: 728111 Status: Offline Thanks Meter: 14 | Quote:
remove the camera and check and reply me | |
04-30-2011, 10:26 | #8 (permalink) |
Member: 696623 Status: Offline Sonork: 100.1601050 Thanks Meter: 526 | it's hardware problem ... see here some info about self test ...... Display Information: “Contact Service”When this error appears in the display it means that one or more of the internal baseband tests has failed. The baseband tests (self tests) are performed each time the phone is powered on. The self tests are divided into those performed while powering up (Start up tests) and the ones that can be executed with a PC using Phoenix (Runtime tests). The following Start-up tests are performed during power up: UEM CBUS IF TEST SLEEP X LOOP TEST AUX DA LOOP TEST EAR DATA LOOP TEST TX IDP LOOP TEST TX IQ DP LOOP TEST SIM CLK LOOP TEST SIM IO CTRL LOOP TEST MBUS RX TX LOOP TEST BACKUP BATT TEST RADIO TEST WARRANTY TEST PA TEMP TEST SIM LOCK TEST PPM VALIDITY TEST KEYBOARD STUCK TEST LPRF IF TEST FLASH CHECKSUM TEST CAMERA IF TEST EXT RAM DATA BUS TEST EXT RAM ADDR BUS TEST NAND FLASH ID TEST BT WAKEUP TEST IR IF_TEST If all these self tests are passed, the phone will start up. orignal post :- http://forum.gsmhosting.com/vbb/3121305-post1.html Last edited by ..:: Devil_king ::..; 04-30-2011 at 10:31. |
