04-15-2012, 13:53 | #1 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Under Blue
Member: 569925 Status: Offline Sonork: 100.1624057 Thanks Meter: 6,313 | Nokia 5130c ,contact service.?????????? (ANSWERED) Log shows every thing ok but phone is on contact service . Here is log. MXKEY [MxKey Team HTI PLUS Flasher Interface 4], SN: xxxxxxxF Using device: HTI, FW ver: 00.50, SN:xxxxx Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.20766(30-03-2012), Library ver: 1.0.0.14016(30-03-2012) CMT Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.0] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 1170001027F70156C4FDB94ECFFC713657388133 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: RAP3Gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 eBB5ProtocolType: OLD Storage0: 0089 8982 - 0000 8A31 [Intel NU48F512,512 Mbits] type: FLASH,NOR, asic:CMT Storage content: 0000 0000 0000 0000 0000 0000 0000 0000 Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.50.0 revision: 0.0 size: 0x23010 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0 TransmissionMode: DDR&TX2 Selected firmware certificate matched. Original Imei: 35434404012559 Original Product code: 0576616 Bluetooth ID: 303855919149 SIMLOCK PA identifier: [0] PA_SL3 Phone type: RM-495 (Nokia 5130c-2) SW version: V 07.91 29-10-09 RM-495 (c) Nokia Imei plain: 35434404012559-7 Product code: 0576616 Battery voltage: 4871 mV, current: 61 mA Language Pack: - not available. SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! Camera config: NIMMIIIIRRFF094B2F01, ver: 002.014 SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 354344040125597 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN What is the solution for this prob? |
04-15-2012, 15:32 | #2 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | bro. post selftest logs, if Sim Clk Loop: failed! in selftest, then change RETU ic will do the job, have a nice day. |
04-15-2012, 20:28 | #4 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | seems all fine from software side. see phone HW for any possible damage, by running self test feature. |
The Following User Says Thank You to gbluez For This Useful Post: |
04-16-2012, 08:58 | #5 (permalink) |
Registered User Join Date: Mar 2008 Location: karachi
Member: 726546 Status: Offline Sonork: 100.1578784 Thanks Meter: 555 | just changed power ic ( avilma ) urs ph will be ok 1000% i can tell u some thing 4 urs help when u power up urs ph if it shown start without sim card then contact service appear its a software and if contact service direct come then its a hardware check and share urs experience |
04-16-2012, 09:51 | #6 (permalink) | |
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Quote:
04-16-2012, 12:19 | #7 (permalink) |
Member: 569925 Status: Offline Sonork: 100.1624057 Thanks Meter: 6,313 | Thanks to all ,fone was water damaged ,Cleaned its pcb ,Applied some paste and rehot its every chip.Set became alive now. Thanks again. |
