Nokia 5130c sd repair for mxkey yes or no?????? Nokia 5130c sd repair for mxkey yes or no?????? |
s.u can do.........just reppair sd.then writ rpl pm............. |
no sl3 not supported at yet |
Not sim lock only superdongle key BUT SERVER IS DWON |
mxkey software. Please read news about last update: http://forum.gsmhosting.com/vbb/5793184-post85.html - Due to keep the server stability, older server will be removed and all older releases are obsolete. BR, Manole |
but after repair sd u need to write the fields of pm(1 & 309) use super sd auth to write pm not pmm auth |
Please help me my repair sd,simlock repair,sign application is working but sd auth and pmm is not working for past 9 days,is my dongle or ip or what please help me. |
remove any old mx old software and install the latest and try many times with ppm auth or super pm auth sometimes srever busy if not solve use recover cert or edit rpl manual and try again |
after update sd ihave wright pm but see this Using device: POTATO BOX, FW ver: 01.B4 Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010) Product: V 06.65 01-04-09 RM-495 (c) Nokia Using cached productData[0F50021836027D5667F882089014A071BA4F68C4] ... Authenticating to SUPERDONGLE using security server ... Bad phones ack on step1, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request |
then retry to reconnect to server again & again tell phone respond to super sd auth & write the 2 fields of pm post result |
Follow manole steps You need to write CORRECT PM or as alternative use 'Load RF/BB from Server' so sw will request PM from server and write to the phone. |
