04-23-2010, 19:35 | #1 (permalink) |
No Life Poster Join Date: Mar 2008 Location: Irvinestown
Member: 719399 Status: Offline Thanks Meter: 228 | Nokia 5200 dead How can I restore this phone nokia 5200 which is completely dead. Using device: POTATO BOX, FW ver: 01.B1 Library version: 1.0.0.8069(22-04-2010), 1.0.0.12811(22-04-2010) Processing file: rm174__07.20.mcusw as MCU [BB5,BB5 ALGORITHM] size: 14.55 MB Supported RAP Ids: 0103192101001101, 010C192101001101 RAP Data : SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] EM0 ID: 00000232 EM1 ID: 00000353 PUBLIC ID: 2E30010907146D56FDCB8CE7EFB2630A3D198690 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 00EC 2208 - 0000 6921 [Samsung K8F5615ETM,256 Mbits] type: NOR,RAP ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.47.0 revision: 0.0 size: 0x23000 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS is blank/erased. Storing certificate ...OK Erase size: 16.37 MB CMT NOR area [00000000-000006BF] CMT NOR area [000006C0-0001FFFF] CMT NOR area [00020000-0007FFFF] CMT NOR area [00080000-000DFFFF] CMT NOR area [00100000-001FFFFF] CMT NOR area [00200000-0031FFFF] CMT NOR area [00320000-0105FFFF] CMT NOR area [01060000-01067FFF] CMT NOR area [01068000-0107FFFF] erased in 3.859 s Flash programming ... Error chk C7012D0103CD RX2 not responding, please check BSI/cable/pinout ! Error while programming [00] at 0x00000400, Result: 0000 Please try to use newer flashloader. Flashing terminated with error(s) in 18.032 s RX Buffer: C7012D0103CD00 |
04-23-2010, 19:41 | #2 (permalink) | |
Major Poster Join Date: Jun 2007
Member: 530622 Status: Offline Thanks Meter: 12 | usb mode Quote:
flash it with usb mode your problem with cable usb mode will solve your problem | |
04-23-2010, 20:32 | #4 (permalink) |
No Life Poster Join Date: Feb 2006 Location: syria Age: 46
Member: 231153 Status: Offline Thanks Meter: 313 | use ded usb open mxkey>nokia usb rom step 1 Make sure USB cable, Battery and charger are removed from device. press flash > step 2 Insert USB cable, insert Battery back to device. step 3 Press phone's power button |
The Following User Says Thank You to alasmmar For This Useful Post: |
04-23-2010, 21:46 | #5 (permalink) | |
Member: 719399 Status: Offline Thanks Meter: 228 | Quote:
Library version: 1.0.0.8069(22-04-2010), 1.0.0.12811(22-04-2010) Processing file: rm174__07.20.mcusw as MCU [BB5,BB5 ALGORITHM] size: 14.55 MB Supported RAP Ids: 0103192101001101, 010C192101001101 Make sure USB cable, Battery and charger are removed from device. Insert USB cable,Battery back to device. Insert Charger or Press phone's power button Waiting for USB device ... [ADL] Pooling for ADL device [ADL] Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 472EEA3 RAP SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] RAP EM0 ID: 00000232 RAP EM1 ID: 00000353 RAP PUBLIC ID: 2E30010907146D56FDCB8CE7EFB2630A3D198690 RAP ASIC MODE ID: 00 RAP ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 RAP ROM ID: 191EC665DFAAF68F [ADL] Flashing CMT Update Server Data, ULO: 0x3880 bytes [ADL] Update Server code succesfully sent to phone. [ADL] Flashing CMT Update Server Data, UPDAPP: 0x3DFC0 bytes [ADL] Update Server code succesfully sent to phone. [ADL] Flashing CMT Update Server Data, PASUBTOC: 0x4BF80 bytes [ADL] Update Server code succesfully sent to phone. [ADL] Pooling for ADL device [ADL] Timeout, no usb device found. Flashing terminated with error(s) in 37.765 s | |
04-23-2010, 21:56 | #6 (permalink) |
Member: 231153 Status: Offline Thanks Meter: 313 | bro, just try agin or flash phone with fbus cable tick fast flash and skip erase |
04-23-2010, 23:04 | #8 (permalink) |
Member: 719399 Status: Offline Thanks Meter: 228 | Yes you are right and thank you for your knowledge dear. Phone alive again thanks to You. I used UFSHWK on it's own without mx key 1ST BOOT : C0,07 [Rm-174] [2.1.0.0] RAPx ID : 000000010000022600010006010C192101001101 EM 1 ID : 00000232 EM 2 ID : 00000353 RAPx PBID : 2E30010907146D56FDCB8CE7EFB2630A3D198690 RAPx MODE : 00 RAPx HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 RAPx ROID : 191EC665DFAAF68F CMT 1ST Boot OK CMT 2ND Bt: RAP3Gv3_2nd.fg, Ver: 9.11.1 CMT FLID0 : 00EC2208-00006921, Sam K8F5615ETM CMT FLCNT : 00000000000000000000000000000000000000 CMT MCID0 : FFFF0000-00000000 CMT 2ND Boot OK CMT ALGO : RAP3Gv3_algo.fg, Ver: 9.17.0 CMT KSIG0 : D6D07E588DC4E06DEE7012A3C0ECC4E35D3CE263 CMT VPP : Internal DUAL LINE : True CMT ALG Boot OK IMAGE : rm174__07.20.mcusw ERASE Skipped Written: 10 Certificate(s) CMT FLASH WRITE OK, Time: 03:21 Chip SECTOR_SIZE: 128k Warning, Must be Used 128Kb Sector_Size CNT File IMAGE : rm174__07.20.image_i_black_128 ERASE Skipped CNT FLASH WRITE OK, Time: 03:50 IMAGE : rm174__07.20.ppm_i ERASE Skipped PPM FLASH WRITE OK, Time: 04:10 Flashing Completed, Rebooting Mobile |
The Following 2 Users Say Thank You to gerdzio For This Useful Post: |
