04-06-2010, 20:17 | #1 (permalink) |
Freak Poster Join Date: Jul 2008
Member: 813493 Status: Offline Thanks Meter: 85 | Nokia 5200 RM-174 Flash problem What can be this? Code: Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.7931(21-03-2010), 1.0.0.12676(21-03-2010) Processing file: rm174__07.20.mcusw as MCU [BB5,BB5 ALGORITHM] size: 14.55 MB Supported RAP Ids: 0103192101001101, 010C192101001101 RAP Data : SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] EM0 ID: 00000232 EM1 ID: 00000353 PUBLIC ID: 29C00016E6EC6056A362C0A8A9961E95CBAAB001 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 00EC 2208 - 0000 6921 [Samsung K8F5615ETM,256 Mbits] type: NOR,RAP ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS is blank/erased. Storing certificate ...OK Erase size: 16.37 MB CMT NOR area [00000000-000006BF] erased in 0.172 s CMT NOR area [000006C0-0001FFFF] erased in 0.391 s CMT NOR area [00020000-0007FFFF] erased in 0.359 s CMT NOR area [00080000-000DFFFF] erased in 0.266 s CMT NOR area [00100000-001FFFFF] erased in 0.407 s CMT NOR area [00200000-0031FFFF] erased in 0.469 s CMT NOR area [00320000-0105FFFF] erased in 3.218 s CMT NOR area [01060000-01067FFF] erased in 0.328 s CMT NOR area [01068000-0107FFFF] erased in 0.219 s Flash programming ... Error chk C7012D0103CD000010000000F1 RX2 not responding, please check BSI/cable/pinout ! Error while programming [00] at 0x00020000, Result: 0010 Flashing terminated with error(s) in 15.937 s RX Buffer: C7012D0103CD000010000000F172 |
04-06-2010, 20:34 | #3 (permalink) |
Member: 813493 Status: Offline Thanks Meter: 85 | Thats was in Normal Flash (wihtout any option selected), but ive try FAST FLASH and SAFE FALSH too. But i got error always on that step: Code: Flash programming ... Error chk C7012D0103CD000090000000F1 RX2 not responding, please check BSI/cable/pinout ! Error while programming [00] at 0x00000400, Result: 0090 Flashing terminated with error(s) in 40.874 s RX Buffer: C7012D0103CD000090000000F172 |
04-13-2010, 23:32 | #9 (permalink) |
Member: 813493 Status: Offline Thanks Meter: 85 | Hey alasmar, See this Now i'm on good way It's a cable problem, the pins don't do the correct contact. So i have to take the mainboard out and program it Best Reggard from Portugal |
04-13-2010, 23:42 | #10 (permalink) |
Member: 813493 Status: Offline Thanks Meter: 85 | hehehe Flashing Sucessfull!!! But now i have bad IMEI : Code: Imei plain is invalid !!! Imei net: 12345610654321? Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 |
04-13-2010, 23:53 | #11 (permalink) |
Member: 813493 Status: Offline Thanks Meter: 85 | Hooooooooo yeeeeesssss!!!! With the my RPL backup i have restored my IMEI So great! Code: Imei net: 3555**01***8**4 Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 8000000000000000 |
Nokia 5200 Rm-174 Error Loading Loader | tio dan bilqis | Nokia Hardware & Hardware Repair | 2 | 05-14-2009 16:48 |
Nokia 5200 rm 174 | benootoo | Universalbox | 2 | 11-28-2008 19:01 |
I need help with nokia 5200 rm 174 | siscel | J.A.F. V-SPEC | 0 | 10-01-2008 03:39 |
Nokia 5200 Rm 174 | starcell | BB5BOX | 1 | 01-20-2008 00:53 |
