02-09-2010, 21:36 | #1 (permalink) |
Freak Poster Join Date: Apr 2005 Age: 51
Member: 133320 Status: Offline Thanks Meter: 0 | nokia 5220 SW Version: V 07.23 17-07-09 RM-411 (c) Nokia Imei plain: Product Code: 0564104 Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
02-09-2010, 21:59 | #2 (permalink) |
Member: 133320 Status: Offline Thanks Meter: 0 | JAF version 1.98.64 Detected PKEY: 9000C30D Card life counter: 81.89% P-key nokia module version 01.02 Detected JAF INTERFACE version: 01.B1, Driver version: 40000, Library version: 30107 JAF DCT4/BB5 LOADERS DIR: C:\Program Files\ODEON\JAF\Flash\ JAF DCT4/BB5 PRODUCT DIR: C:\Program Files\Nokia\Phoenix\Products\ JAF USB LOADERS DIR: C:\Program Files\ODEON\JAF\FlashUSB\ JAF DCT3/DCTL LOADERS DIR: C:\Program Files\ODEON\JAF\Flash3\ USB Cable Driver version: 7.1.16.0 Changing mode...Done! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V 07.23 17-07-09 RM-411 (c) Nokia HW version: 1000 PCI version: RFIC version: 064c0601 DSP version: ICPR72_09w17 LCD version: SHARP PPM version: V 07.23 17-07-09 RM-411 (c) Nokia MA BT MCM version: 2222-143C Retu version: 15 Tahvo version: 22 Content Pack version: Content: ma_a_blue V 07.23 17-07-09 RM-411 (c) Nokia Production serial number: DTB829661 Product code: 0564104 Module code: 0203661 Basic production code: 0554881 Flash code: Order number: Product specific data: Long production SN: 0 ATO: Default SN type: IMEI plain: 353662010399558 IMEI spare to net: 3A 35 66 02 01 93 59 05 IMEI SV to net: 33 35 66 02 01 93 59 45 F0 LOCK STATUS: CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider: AT&T;U.S.A. (3650) Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 2: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 3: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 4: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 5: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 6: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 7: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Searching for saved ini... Checking for file C:\Program Files\ODEON\JAF\JAF_RM-411.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0564104 Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-411\ Searching for default location of ini... Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-411\ Scanning ini files... Searching for default location of ini... Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-411\ FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-411\rm411__07.23.mcusw PPM Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-411\rm411__07.23.ppm_ma CNT Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-411\rm411__07.23.image_ma_a_blue APE Variant file: NONE Languages in ppm: English,Arabic,French Done! |
02-10-2010, 00:59 | #5 (permalink) |
No Life Poster Join Date: Feb 2005 Location: AD
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | 1.do SX-4 and write PM without [308] area in case after Superdongle repair , please use "SUPER SD Auth" 2.Check BB5 Secure Validation [MXKEY - INFO] !!! NEW magic button inside mxkey !!! 3."Recover CERT" doesn't work ?? Code: Begin Certificate Request ... Connecting to server ...OK, Login ... ERROR: No certificate found in the database ! need more file about CCC,HWC and VARIANT [MXKEY - SERVER UPDATE] Solved "SECURITY_TEST failed!" after SD repair br, |
nokia 5220 show nokia only | alialjorany | Nokia Base Band 5 ( BB-5 ) | 8 | 02-09-2012 15:20 |
unlock nokia 5220 and nokia n96 | polocell | Cyclonebox | 5 | 03-23-2010 22:41 |
nokia 5220 nokia then screen white | muhned | Nokia Base Band 5 ( BB-5 ) | 2 | 03-25-2009 00:52 |
